Installing a 220v outlet in the garage
sberry
Brethren, Michigan
There are some local amendments but they are usually prohibitive or they require extra. I believe Chicago required pipe for a long time, I have heard of a couple in regards to grounding but none that disregard a fundamental principle they adopted when they wrote the first book. Why would they have all these plugs if it didn't matter?
The IRC or whatever it is prohibits even multiples of 240 on the same circuit in excess of the NEC and with good reason obviously, just to prevent some dope from causing a situation like this. They must figure that isolating it to a single outlet reduces the chance for error. Keeps someone from overloading an underwired circuit in relation to the breaker, a welder outlet may come to mind.
There is a safe way to do it but its obvious from this thread that there is a lack of understanding of some general principles, cant insure every installer fully understands complete circuit design so the simple way around it is to rule it out where the maintenance is not under professional supervision.
I am skeptical about a lot of guys that do this work, lots of plant maintenance people learn hand to mouth.
We saw one here where the "electrician" from Dads work wired a 7 1/2 hp comp with a 12 cable. Probably did this at work on 480 3 ph, never been tested or educated in basic install.
I went to a call a while back, the preacher had his bud the maintenance guy did electrical at the church come and do a service install. The inspector must have got tired of looking at it and passed it anyway, when they turned it on it tripped a breaker, dipstick couldn't even run a foot of wire to an outlet without shorting it.
I had a chance to look at a panel a while back and I can count at least 5 electricians that work on it. The last master that went over it is not a fussy type but a brilliant guy, he fixed up some simple stuff but it fooled the maint guys that called me. I recognize a couple guys before me, 2 of them left their 'fingerprints" as I had seen it before and one does dumb stuff because he really knows more about it than most people including the masters before him and the code book.
sberry
Brethren, Michigan
The main reason I am sensitive to this is that I recognize it. I finally figured out I was doing work I didn't understand and made a lot of mistakes, fortunately it didn't end in disater but at some point when I tried to read the book I learned that my education amounted to hearsay and that I had to study. The only thing I really knew was that 14 was good for 15 and 12 for 20. I even passed entrance inspections due to the fact I cherry picked issues relating to inspectors, did a lot wrong after they left.
I actually learned it from the net, got a book and followed from some forums and it took a while before it became a "reaction" for lack of better wording.
Surprisingly it's often harder to splain it to smart people that know a little, idiots seem to realize they don't know or they just scared enough they don't fug with it.
Codes vary by location, as such I'd imagine he has a far better grasp on them than you do. :dunno:
From the NEMA website
"The timing for code adoption varies by locale and may be amended by state and local jurisdictions. The result is that different electrical codes are being enforced in different parts of the U.S."
We are talking about the NRTL (such as U/L) listing of a device which has NOTHING to do with local amendments so the points both of you made are MOOT....
There wont be a local amendment or older code adoption that would allow a non listed device....
and the guy who posted it admitted he could only find it for sale in Canada.... gee I wonder why...
Matt Matt
Ontario
The funny thing is when, I purchase a government military machine that has a special UL listing or amendment to the rule,and it has a special wiring isolated to that machine/location , (hots from two different sources), Do I still comply when I move the machine to the new property/home? Or do I need a new special exclusion to the rule?or would I even be applicable?
