gunner_bear
USF holland just called and said they have my hose reel and are delivering it on a semi? How big is this thing ? will see tomorrow
Length x Width x Height = 24" x 10.5" x 25.4"
Don't know about the weight, but it's a big boy. Probably need to mount it on a meaty 2x4 fastened to a concrete wall or to a roof truss for ceiling mount.
elronin,
looks modular. is there a ****** piece between the segments, standard npt?
yea there is I didn't take it apart, but it has hex screws you can loosen up and comes apart in 3 pieces. 3/8 nip
Can the flush mounted gauge be replaced with a wider faced pressure gauge?
No don't think so looks like it's built in.
Here is the gauge off the base the back side is same sorry
How about the no gauge options? Does it mean a gauge can be mounted and if yes will it take 1/8" or 1/4" NPT.
ARO Filter-Regulator "Piggyback" PGYBK,2000SRS,NPT P39334-114
3 – 2000 Series
3 – 3/8” NPT
4 – 5 micron
1 – 0 - 140 (No gauge)
1 – Relieving / Metal w/sight glass
4 – Standard Knob / Automatic
Just to be clear ... can the Lubricator be taken off the F-R-L setup leaving only the F-R for use?
How about changing the setup to R-F?
tks
tks
OK so I got my first round in.
I was hoping one could interchange the filters and drain bowls. You cannot.
What you order you are stuck with.
I figured out the manual drain, but not the auto drain. Not quite sure how it works.
I bought the F/R-L combo, and it arrives today.
I plan on removing the Lubricator, and just using the F/R. I'm 99.999% certain they are just regular NPT fittings between them. When they are used as a unit, there is an o-ring between each component, and then that connector fits between them. I'll let you know 100% once mine get here and I disassemble them.
Also, when you look in the IR catalog, it even lists the individual component numbers that make up the combo unit. The combos are just individual components strung together.
How about this unit?
http://shop.ingersollrandproducts.c...r-piggyback-pgybk-2000srs-npt-p39333-314.aspx
3 – 10 - 175 (No gauge) (available on 2000 & 3000 Series only)
No Gauge ... does it have a gauge mount on the F/R body and what size hole ... 1/4 NPT????
I just need one more for spray painting to wrap my purchases and I'll spring for this ...
http://shop.ingersollrandproducts.c...r-piggyback-pgybk-2000srs-npt-p39333-614.aspx
I hope the carbide burrs are good too as I decided to get a few more sets. These are cheaper than the generic Chinese made ones.
Is that a 1/8" NPT plug in that center hole?
It looks like the gauge has a flange. Does it seal in that area with a gasket vs a male threaded stub?
Anyone else having their order sit in fulfillment for a long time? I hope I don't get more notifications that things are out of stock and getting refunded.
I made three orders:
Tuesday Afternoon - Status updated with one product that was out of stock and will be refunded, still in fulfillment
Thursday Morning - In fulfillment
Thursday Afternoon - Shipped
OK. I lied. This is working out like I expected after playing around with it some more.
I wanted a 3/8" manual drain w/ metal bowl & sight glass and 5 micron filter w/ built in gauge (334-610). None exist on sale. Either they have a .3 micron and sight glass or 5 micron and no sight glass no gauge.
The units are split, the first 3 #'s are the top unit, bottom 3 #'s are the bottom unit.
I purchased:
333 (.3 micron) -610 (metal bowl sight glass manual drain)
334 (5 micron) -624 (metal bowl no sight glass auto drain)
I swapped the -610 to the 334 and now I have a 334-610 which did not exist on the IR site.
I also now have a 333-624 which will be perfect for painting.
Still no idea how the auto drain works. There is no additional plumbing involved. Maybe when the water hits a certain level it's automatically blown off? That would be pretty neat.
Have you figured out how the auto drain works yet?
I bought one 1/2" Piggyback and 2 3/4" Piggybacks.
They are all -624 series
There is a little float in the bottom that looks like it floats up and opens the valve. But I blew on the intake a little and the it blows straight out then bottom. Maybe I didn't pressurize it enough to seal?
Hell of a deal though. These 1/2" and 3/4 inch regulators are monsters. I am in the running for baddest garage on my Block now!
Hmm, I bought 3/4 inch ones, will be interested to see what they are like
