Is it worth $20?
Big_Jim
nw ct
Just picked this up for $20. Is it worth $20?:D Haven't plugged it in yet but it has to be worth $200 in just parts alone.
Big_Jim
nw ct
^^^ interesting "steal your face"
If it works, its worth it. If it dont work and you make something more than $20.00 on parts.....
Kind of a moot point because I plan on restoring it and using it. I'm pretty handy at fixing stuff (just not electrical). Should be fun to bring it back from the dead. My Mom's next door neighbor picked it up at a storage auction. Damn thing is heavy as hell.
Dan in Pasadena
Pasadena, CA
Hell yes.
I'd love to fimd a deal like that.
I'd suggest you try to manually turn it over, spray moable parts with some lube before applying power.
Big_Jim
nw ct
Hell yes.
I spun it and everything moves freely. Table adjusts, the blade guide works (the bearing needs to be replaced), The motor pulley is dented but I found one on "the bay". If the motor doesn't work that would be a bit to replace so I hope it works. He also had a delta scroll saw for the same price. I didn't need one but how can you pass up a deal like that so I will just flip the scroll saw.
toomanytoyzz
Malvern, PA
Not sure yet. It's in the garage and I have no lights or power yet. I will plug it in in the morning and let you know.
Long extension cord:dunno:???? I'm assuming you have a house near the garage.
Sorry, but I am not one to sit around and look at something that MAY work in hopes that I got a good deal.
ihateminimumwage
Why replace it? Open it up, fine sand all the copper you see on the rotor and stator until it looks new, clean it all out with brake cleaner, grease the bearings/bushings and put it back together. Should take an hour, and it'll run fine. Worst case you might have to put new brushes in.
Done it with the starter, window motors and generator on my Thunderbird. As well as countless other starters, alternators, generators, fridge fan motors, vent motors, dryer motors, etc. The guts are all the same.
Big_Jim
nw ct
Yeah just a little busy at the moment. Check my garage build thread.
http://www.garagejournal.com/forum/showthread.php?t=138187
Even if it don't work I can make a ton of money on parting it out. I'm forever coming across deals so if this one don't work another one will be along soon (Probably not for $20 though)
You are assuming an AC/DC motor and odds on its not...
Nice score! Suckage meters are registering in your town tonight!
Big_Jim
nw ct
Yeah that I can handle. I used to do that on my Chevy starters & alternators all the time. The funny thing is it has some kind of safety plug on it. It has a little black button.:dunno:
You have already checked the essentials, so all it can really need is a motor. that has the slow speed pulley jack shaft, so worth a lot more than the average band saw without it, as you can cut metal with it...
Big_Jim
nw ct
That's what I have planed for it. I build hotrods and do a fair amount of fabricating so it should come in handy.
TireTracks
Yakima,Washington.
Theres nothing to sand in a a Induction motor. If you sand anything, you will probably ruin it. There are no brushes/commutator to need cleaning.
DC motors are nothing like AC induction motors.
The ONLY thing that may possibly need sanding, would be the contacts on the centrifual switch, but that may depend on if the switch assmebly is sealed. if it doesnt work, check the start/run cap with a multimeter, or replace it, and check the resistance of the windings( to see if you have continuity).
Edit: Well actualy, there is 1 kind of induction motor with brushes, but I really doubt thats a repulsion/induction motor.
Big_Jim
nw ct
you do know that has the reduction pulley on it for metal ???
Yes it was mentioned earlier in the thread but no up to that point I did not know it. That's a good thing as I'm going to be using it for metal.
ihateminimumwage
Sorry I opened my mouth! :lol_hitti
Never worked on an AC induction motor, I'll have to do some learning about them...
TireTracks
Yakima,Washington.
I wansnt trying to be mean, I just had horrible images running though my mind of someone reading that and going out and sanding all the insulation off of the stator, and then frying the motor.:lol_hitti
kb2tha
Delaware County, NYS
Clean it up and repaint, its worth $250 easy. I ts a top notch machine.
Around here that would bring twice that amount cleaned up, painted and running. I once sold a Powermatic 14" wood/metal bandsaw for $900.
Also parted out a Delta/Rockwell belt/disc sander for over $500. Paid $10 because it was incomplete. :lol:
This qualifies for the Usuck of the month award so far. :thumbup:
Big_Jim
nw ct
I did the math on the deal. I picked up a rolling storage box (Kinda roached out), the delta scroll saw, & the band saw; all for $50 delivered so that would come to $16.67 each! This guy has a bunch (About 6 and 3 regulators) of torches as well for $40 Some are for cutting and some for welding. Just didn't have the $40 on me or I would have gotten those too.
zuk123
Houston TX via Chicago, Phoenix, LA, and San Diego
This is a really desirable machine. The gearbox reducer models are great. I don't see the oil fill, so maybe this is just a jack shaft model, but it looks like the model with the gears. Google for the manual to be sure.
There should be 2 belts to allow you to adjust a full range of speeds. The big pulley should slide in and out to engage the different gears.
I paid $480 for one, in good cosmetic shape, but with the gearbox bypassed. (This was common.) Took belts and lube to get it running.
Clean it up, replace the belts, get the gearbox running (if it's that model.) The motor might just be a jammed switch. Try bypassing that first.
If you need new tires on the wheels, get some urethane ones on ebay.
Good machine, simple fixes, great score. MAJOR SUCKAGE!
zuk
Big_Jim
nw ct
Well I plugged it in and the motor runs great only thing is it won't run unless I press the button on the plug. If I let the button go it stops.:headscrat I'm going to pull off that safety plug and put a regular plug on it. I'll post a picture of the safety plug later. On a side note the scroll saw works as well.
ihateminimumwage
I didn't take it as mean at all, just ignorance on my part, which is now corrected.:thumbup:
spongerich
Monroe, NY
That thing is a death trap.
I'll take it off your hands and make sure that nobody gets hurt :)
Hit me with a PM with the pulley size. I think I have one that might fit that I'd let go for a couple bucks... shipping should be cheap since I'm nearby.
Big_Jim
nw ct
zuk
More pictures of the gear box and the bent pulley. You guy's probably know more about it then me (make that definitely). You guy's will have to show me how to use it once I get it fixed up. I also took pictures of the saf-start plug. I'll have to do a little research on that. I'm thinking it may be bad. Can I just remove it & put a regular plug on it? I engaged the gear & spun it and everything feels tight and smooth (no slop).
Big_Jim
nw ct
I guess the rumors are true: The ACME store is closing and Wile E Coyote is selling all his tools.
Coach
Coach, don't tell me that. Now every time I go to use it I'm going to be wondering if it's going to blow up or will a safe fall on me!:lol_hitti
darkk
Willimantic, Ct.
$20? just several parts alone are worth a couple hundred for guys restoring them. Nice score...oh, and you ****!
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
you might not even need that pulley.
That is the one that goes on the motor right?
If so, that's the fastest speed, depending on what you want to set up to cut,
either that or I bet you could lay in on a wooded bench and straighten it with another piece of wood and a hammer.
Yes
Glacial_Speed
Massachusetts
You can put a regular plug on the end, as long as you aren't required to abide by OSHA regulations.
The plug is a safety thing, in case you lose power it won't just start up when the power comes back on.
