Jake's Projects ...... or, .... How I waste my time
J
jakemac
New England
Ok, so here's the reason why I'm giving Fretters the squinty eyeball right now.
I've been looking for a clamp-on vise for my clean bench that will fit the 1-1/2" thick table. I found one at the FM on sunday. The plan was to paint it Kona Brown like the smaller one posted earlier in this thread. But .......................
................... That damned limey put Burgundy in my brain and I can't get it out ! :lol:
The can I used on the Stillson wrench started whispering to me, and before I knew it,
I had a Fretters Special sitting on my bench. :wtf:
The vise is a MODERN #M743 made in Milwaukee. The jaws are 2" and will open to 2". There is a little slop in the jaws that can't be adjusted. The screw collar is pressed on the spindle and I didn't want to risk hammering it out. In addition, the main nut wasn't designed to be removed. Instead of a pin holding it in, there is a tab on the back of the nut casting that was hammered down into the hole to hold it in place. Once again, I didn't want to risk using a hammer and snapping the tab off the casting. So, the vise was restored in two pieces, making it a bit awkward to work with. It's a good thing it's small.
The color is Krylon Satin Burgundy, with the cast-in medallion Krylon Carmel Latte (I wanted to see what it looked like, so I could decide if I wanted to use it as a substitute for Craftsman Power Bronze). The letters are a little messy, but considering that I was using a 1" foam brush dipped in a yogurt cup filled with paint from a spray can, I think they came out ok. The paint was then sealed with Krylon Clear to give it a shine and protect the lettering.
I left the file marks in the jaws to keep the history, and will glue some sheet rubber in the clamping area to keep the paint from sticking to my bench. The vise won't stay on the bench, it will come out only when needed.
Next up : an update on an earlier issue discussed in previous posts.
J
jakemac
New England
As promised, here's an update on a tragedy I suffered a few weeks ago.
While sanding the face on a homemade body spoon I was trying to save, I accidentally caught it under the rest on my belt sander and snapped the rest off. Since welding isn't one of my skills, Nine4gmc graciously offered to weld it back together for me. So, off to the post office it went.
The rest came back yesterday, and was immediately assaulted with a spray can. This morning, after the paint had dried overnight, I sanded the paint off the face (by hand :D) and installed it back on the sander.
Now, I no longer need to feel the burning hatred directed at the back of my head from a disgruntled power tool in the corner of my shop.
The closest spray paint I've found (so far) to the old Craftsman blue is Valspar's #85205 Classic Royal Blue. It's a little brighter than the original color, and is a touch redder, but I think it comes close to the original factory color before 75+ years of fading.
I like Valspar paint, but don't use it often because it seems to give off more and stronger fumes than other brands and takes twice as long to fully dry. It seems to stay tacky forever (well, at least longer than my patience can stand).
I didn't think to get a before picture of the broken pieces, but here are pictures of the repair, and of the rest back on the sander.
A million thanks to Nine4gmc for his generosity and skill set in helping me get an old sander back to work (again). :bowdown:
Fretters
South Yorkshire, England
:D :bounce: That's a **** looking little vice there Jake. Dashed good colour choice. :D The caramel relief on the lettering sets it off nicely.
nine4gmc
Dallas
Glad I could help, you did a great job finishing it!! That color is really, really close for such an age difference. :beer:
J
jakemac
New England
I looks better in the picture, in real life you can see the color difference better. But, everything else I tried (I sampled about 5 or 6 brands/colors) was instantly noticeable. The Valspar blends in unless you take a good look at it.
drivesitfar
Jake: nice vise and gotta love that burgundy colour don't you. next you'll be asking for the green paint colour that Fretters also uses on his old English iron.
seems like just a few days ago when you busted that piece on your sander. nice job Nines and can't even tell it was welded now. :bowdown:
thanks for the painting tip and i'll be asking for the green colour's brand and color soon i'm thinking. :D
since you started this thread you are doing a ton of shop time and projects and Nines is buying new non rusty stuff and doing less in his shop on his thread. interesting and might we call that the cycle of life at GJ?
J
jakemac
New England
Not so much a cycle, more like a pendulum.
To everything - turn, turn, turn
There is a season - turn, turn, turn
And a time to every purpose under heaven
A time to buy, a time to sell
A time to paint, a time to scrape
A time to forge, a time to weld
A time to laugh, a time to weep
:drink:
J
jakemac
New England
This week I picked up a huge Billings DOE wrench on my way back from closing up my camp for the winter. It's a little over 24" long and weighs 11lbs. This one is wall art (until I need to use it).
After cleaning and de-rusting, I sanded and polished the claw faces. Then painted it with True Value's X-O Rust Satin Black to mimic the original black finish.
J
jakemac
New England
Well, the 24" Stillson was feeling lonely. So I picked up a few siblings for it. I tend to fixate on something until I burn out. My c-clamp fetish seems to be winding down (a bit), so now I guess I'm collecting the whole Walworth/Stillson family. Here's a 6", 8", 14", and the 24" (the only one that's been oiled so far). All four are now wearing the same war paint.
J
jakemac
New England
The latest time waster is a 1-1/2" machinists vise. The original color under the grime was a medium industrial green. There wasn't much rust, so it just got a 24hr soak in Simple Green and then some time on the wire wheel. The bare metal got a rub with Nevr-Dul and then buffed with a clean cloth.
I went with a light blue hammered paint because I had it sitting on the shelf unused and wanted to see it in action. I'm not sure it works on this vise though. :headscrat
I'll have to try living with it for a while before I decide. What are your thoughts ?
MikeF2316
Thornhill, ON
I think you're right. There's not enough contrast between the paint and the bare metal.
As usual, the workmanship is top notch! :thumbup:
Fretters
A colour with a bit more punch would make it more notable, but the current paint does the job. Does look a bit subtle as is. Saying that though, it's there for a purpose and not for drooling over. :D
Those look good. :)
J
jakemac
New England
Just an observation :
A rusty 1-1/4dia ball bearing seems fairly large when you decide to clean it up. But that ******* is really small when you go to hold it up to a polishing wheel !
PING ..... RICOCHET ..... DUCK ..... BOUNCE ..... RICOCHET ..... BOUNCE ..... BOUNCE ..... ROLL ..... CHASE ..... repeat.
:lol_hitti
:lol_hitti
:lol:
Fretters
You're a muppet Jake. :D
J
jakemac
New England
Drives - Yes, the ball bounced around the shop ......... three times.
taumac - No wife, I'm on my own if I want anything polished. (and so are most of the married men I know :lol:)
drivesitfar
Jake: not all married guys. :D
you are still damn funny and happy to hear you weren't injured or hopefully not any of your awesome toolboxes and stuff either.:D:D:D
J
jakemac
New England
Drives - I did say most. :lol:
taumac - as my signature says -
"No job is complete until you've been to the hardware store 3 times and bleed on it ................ twice." :D
taumac
Brooksville, Fl
That's perfect.... Mine said once if your not bleeding your not working hard enough. Hell, my garage didn't get that name by chance. It got earned. LOL
drivesitfar
Jake, Taumac, Craptain and Outlaw: look were bouncing balls puts us. Again. Women can't live with them and can't live without them and they seem to fill the gaps in between all our tool talk. :bounce:
taumac
Brooksville, Fl
:lol_hitti
Honestly I first time I read this I :spit: I think its so funny cause think we all done this at one time or another.
Very true....
drivesitfar
I was expecting Fretters to chime in since he's not far from a good comment about the subject we moved to, so hopefully that DP he had sitting in his shop didn't fall on him. :D
no more bleeding and or bouncing balls and Jake needs to tell us what his next project or adventure will be.
J
jakemac
New England
Next project ? I haven't a clue. :headscrat
I have a bunch of stuff in the line, but I'm not yet set up for large projects. I have a 12" disk sander in pieces, a half dozen or more tool boxes and rollers, a band saw, a few vices, several block grinders needing work, and I may have a line on a pair of small Dakes (I'll know more about tomorrow).
We'll just have to see what the Tool God has in mind for me.
My responsibilities at home only leave me "puttering time" in the shop. Large projects are difficult because I have to keep an eye on things upstairs. And now, I need to find the time to deal with the leaves in the yard, gutters, and make room for the snowblower in the garage. Snow is just around the corner here, and I'm just not ready for it (I never am).
So, it will probably be more fluff projects for now. :dunno:
