jeepinerdeep's shop fab n project thread.
zmotorsports
Northern Utah
Jeep looks great. Nice to see you mount the winch down between the frame rails as to allow plenty of air flow for that Hemi.
As for the axle shafts, seeing as how you have additional power on tap I would upgrade to some chromoly shafts or even RCV's in your D44. Normal driving shouldn't be an issue but I would worry about getting a front tire lodged or wedged into a rock and then bumping it with that kind of torque behind it you may break a shaft.
Keep the pics of your mods coming.:beer:
J
jeepinerdeep
South Central PA
Thanks Mike. Yeah I'm kind of the same opinion on the front shafts. I'll look around at options. I'm not 100 % sold on the RCV, might just do traditional alloys.
So far, the C and R radiator has already showed the most improvement of anything, I've yet to run it warm. A good summer day wheeling deep in the woods will really be the test though. Can't believe the number of parts and mods out there that block the rad, even on stock power trains, it doesn't make sense!
zmotorsports
Northern Utah
Agreed. I have had to work on several stock drivetrain Wranglers with overheating issues and the owners don't like to be told they need to go with a different bumper to mount the winch down low or to get rid of some lights that are blocking the grille.
As for shafts, I've installed quite a few Ten Factory shafts and a few Superior and haven't had any issues with either of them. I've also had great results with the RCV's that I have installed and I had over 100k on them before rebuilding them.
J
jeepinerdeep
South Central PA
Finally getting around to working on my stairs again. Treads (bolt in) were done over the summer.
This week I got to layout, cutting and drilling the stringers. More to come.
I spent a few hours doing layout and then transfered the hole locations with primer from a spare end plate. I did 26 holes tonight, will finish tommorow. Trying to be easy on the cutter.
J
jeepinerdeep
South Central PA
Got the stair project finished up. I'll be slapping up a basic handrail on the wall out of some angle I got at the same time I picked up all this material.
J
jeepinerdeep
South Central PA
wow, nice job on the stairs!
Thank you. It certainly took some head scratching to layout correctly. I am pleased with the result given the strange dimensions and using all previously owned material.
I would have the handrail done by now but I got a tiny piece of grinding wheel in my good eye ( I think when taking off my sweatshirt or maybe from my brow ), so that was a distraction to say the least ! Maybe Saturday I'll get to it.
J
jeepinerdeep
South Central PA
Got started on the next project, a coffee table.
Picked up the top from my wood guy last week. I will need to add 1/16 radius and finish. ( I believe he just wiped it down with mineral spirits or water for the pic ) It's black and english walnut, both very local again. Both, but the black especially have a little of the "flame" in it. Should be killer. Another 2 weeks to acclimate at the house and I should be able to final sand/finish.
I had some CNC parts I cut at one time for a bench, and between them and some tubing drops I had, cut the parts needed.
Will need to wait on the right weather to patina and satin 2K clear the base. You kinda have to strip the scale, weld and finish it all within a day or 2 to get the patina to come out right. ( Due to humidity/temps )
J
jeepinerdeep
South Central PA
Looks like weather will be nice tomorrow for finishing, so I am moving ahead with the coffee table base. Got the fab in tonight.
J
jeepinerdeep
South Central PA
Thanks guys.
Got the patina and satin 2K clear on today during a brief warm and sunny spell.IMG_2324.jpg
Monza Harry
Windsor ON
Jeep that top and table is Killer!:thumbup:
Nice work there! I offered to build a coffee table for the basement, my girl says ok, one condition....you must be able to carry it down the stairs by yourself..... fk!
Phantom did she get bit with that one before? My wife just got one of those bites this weekend, she wanted some carpet removed, No Problem! Cleaning deteriorated foam backing/pad from floor a big problem, only 1/4 of that rooms floor is "sorta cleaned up". I explained I am not wearing blue tights with a red S on my chest and I have no red-cape [so no superman x-ray vision]. I hate fixer uppers, why did I buy this? Oh yeah I can fix anything :wtf: :mad: :rolleyes2 :lol_hitti
Harry
J
jeepinerdeep
South Central PA
While I'm waiting on my wood top to dry, my buddy gave me a hand checking clearances/bumpstops. We also tensioned my winchline on the hill.
All that remains on the JK is for me to install my CB, which I look forward to the least of anything. Its been on the workbench since October.IMG_2337.jpg
sqznby
Coastal NC
Nice work on the stairs, came out great. Stair/stringer lay out is fun work and very satisfying when completed. You did a great job.
Cool coffee table base. What material are you going to use for the top?
I like your Jeep. You have a thread on it?
J
jeepinerdeep
South Central PA
Thanks. Don't tell anyone, but there is .030" stackup error in the stairs !
The table top is pictured about half way up the page. Black and English Walnut. I hope to work on finishing it in about a week.
I do not have a specific Jeep thread. I bought it and did mostly mechanical repair work and bolt on additions. Not a lot of fab except the basket I made some posts on.
J
jeepinerdeep
South Central PA
Had some opportunity to finish up the coffee table project. Pardon my living room lights, they have a little yellow tinge.:(IMG_2365.JPG
C_F
Utah...SNOW BLOWS!
First time coming across your thread & I must admit that I selfishly landed on this current page...(edit) errr page 5, no thanks to my babbling post. I promise to go back & see what you've been up to prior to page 5. :D
The shop stairs look great!
Regarding your coffee table...the photo of the top looked really cool, but when I came across this photo...
...it looked like your table legs were welded to that 1/4"(~ish) steel plate. I was-a-thinkin' that is going to be FRIGGIN' heavy on moving day!! :lol:
Love the way it turned out though, it looks really nice. :)
J
jeepinerdeep
South Central PA
It's 3/16 plate, and .125 wall tubing, all of which I had around. Between that and the top, the whole assembly has some gravity in it. I enlisted help to carry it upstairs. My dining table is heavier though.:)
Nice work on the stairs and table, both! A coffee table is on my long list of projects to get to eventually.
Thank you.
J
jeepinerdeep
South Central PA
Table and stairs turned out great! Real nice grain in the coffee table top.
:thumbup:
Jay
Thanks!
Had to go back to my kitchen set I made and add some foot rests to the benches. They were strange to sit on without. It's cherry, but I'm not sure how I feel about the exposed screws. Maybe I'll just paint them black with a tiny brush.:headscrat:headscrat
That's enough fooling with wood for now. It drives me nuts. I have some old pipe tools and c clamps from my grandpa that need a little attention.
Jayman17
Seattle, Wa
I see what you're saying about the screws. I agree, either dab some paint or maybe a Sharpie permanent marker will be good enough. I've got some estate/garage sale C-clamps that need some attention too. What do you use?:headscrat
Jay
J
jeepinerdeep
South Central PA
Jay
I'm not a tool restorer by any means. I wire wheeled everything today. Scrubbed with mineral spirits and brake clean. Put some spray enamel on from TSC and my go to for exposed metal is CRC 3-36.
Just a functional re-do.
J
jeepinerdeep
South Central PA
Nothing special but I cleaned up, painted and oiled some of my Pap's old tools. He's come to the realization that he can't handle them, so sent them along. Not a restoration just return to serviceable. I have used the 3/4 threader die, still sharp enough for weekend use.
J
jeepinerdeep
South Central PA
Finally gave up on the old works of my ACCO 40 Ton Press. I replaced it with this setup I got online. A little rough around the edges but US made.
J
jeepinerdeep
South Central PA
Picked up another Lista, the DW 1350 in the middle. (tall and wide)
Quite a job swapping around drawers, getting it loaded and labeled.
I'm a little frustrated ordering first quality Lista at this point, I think I'm going to have to just stick to the wrecked ones on ebay should I desire any more in the future. Time will tell if I change my mind.
LXCam
Congrats on the new box bud, the collection is getting damn impressive! Btw, was this provided by our buddy once again?
J
jeepinerdeep
South Central PA
Yeah. They are nice enough I guess.
This one has an infuriating locking issue that I'm going to need help from Joe or a Lista rep with on Monday.
You can operate a drawer, come back 10 seconds later and the whole key needs to be recycled. Does it with new or old drawers, seems to be trigger most in the bottom half of the cabinet.
Dealing with Lista mostly as far as, their poor skimpy packaging for LTL truck freight (duh?) and premium prices have worn on me.
Lista on the secondary market is a good value. First quality, not so much.
nutjob
NE, PA
I have one cabinet that does this. In the lock bar, which is in the back mounted vertical, it has a small flat curved spring metal piece which is suppose to keep the lock bar in the open position. Mine got bent and fell out. Last I checked this part is not available separately, need to get the complete lock bar. Let us know if this has changed.
Kevin
J
jeepinerdeep
South Central PA
Kevin
I remember seeing them in there, and no loose ones floating around.
I just emailed american workspace and let them know to connect me with someone to diag. If we need the whole bar, I mentioned that. Thanks.
J
jeepinerdeep
South Central PA
Unfortunately I don't have a ton of fun projects going on. Being off the road with the rona situation has me unsure of how to proceed.:dunno:
I have been working thru a list of maintenance projects. To go with the stairs I made above...... Most recently, I cleaned out junk, pressure washed, painted walls, installed LED hardwire lights and a new fire extinguisher. This is the basement of my shop, only a 7' door and 8' under the beams. Mostly use for storage, painting and trailer storage in the winter months.
On to the main level for new LED high bays and a coat of white next month.IMG_2499.JPG
Clemson13
Just found your thread tonnight and it is fantasatic. Hopefully you have some updates?
Just wondering why you got rid of the CNC plasma & side hustle. I have been considering picking one up for home hobby use, not a business and would definitely want to know any issues before i spent 8k on a setup i know I wont use that often. I have dreams of making myself a cool fire pit like yours. I probably wouldnt start a side hustle as i am on the road (consultant) 25+ wk/yr.
J
jeepinerdeep
South Central PA
I'll post a meager update after this reply.
I traveled the same amount as you and still hustled. It's painful, but possible. After a lot of work and investment making nice things, I wasn't paying the capital back for the table and just made a few dollars. Literally a few dollars. But that was doing it all above board. Insurance, shows, adverts, nice material etc. If you want to make some beer and consumable money from a few close buddies cash only, you can do it easy. Just don't cut any trademarks or make anything that can maim you.
Having a CNC table is freaking awesome. I would really only look at Arclight and JD squared based on what I know now. I went with the Arclight, which was great, but only a water pan. In the light machine category, the water pan is a messy pain the ****. I would look at air for weekend use if I did it again. JD squared's table is wicked rigid and they have air options.
J
jeepinerdeep
South Central PA
Meager update. Still a little lost as what to start, work is weird. Just laying low.
Installed CB and mesh top in the JK, painted and LED'd the main level of the shop to match the basement, picked up an M18 portaband with hotel points, spent a few PTO days at the range with a pair of Tikka's and my P365.
I've got to take a better picture of the shop now and do some toolbox inventory pics.
