pizza
Resting your thumb on that wouldn't do anything, as your thumb would rotate with the ratchet. It would only do something if you held it steady with your other thumb...and at that point you could just hold the socket.
It's there because it's easier to manufacture the ratchet with that design. Instead of needing to precisely machine a pocket/recess into the ratchet body, you just have a die punch a hole right through the forging in a split second. It's a design that can trace its origins back to Plumb/Proto ratchets of the early 1900s.
tbh not sure if it's intended to be used that way, but it does work.
https://www.garagejournal.com/forum/showthread.php?p=8768533#post8768533
i didn't get what FT was talking about at first either. but that and the next few posts explain it.
I didn't take any offense
