Menards has Sylvania drop in bulbs 17 watt 2200 lumens for $55 for a 10 pack.
I installed them in a T8 4 tube fixture and measured 28.1% increase in LUX 55" to the measured work surface with 43% decrease in power consumption.
T8
[/URL][/IMG]
LED
[/URL][/IMG]
[/URL][/IMG]
EDIT
Installed these drop in bulbs in a several Menards T8 shop lights. They work for several minutes and shut off. Appear they over load the ballasts . Turn off reset and it happens again. If have used the FEIT drop in bulbs in theses same fixtures without a problem. They ( Sylvania) did work ok in the four bulb fixture. So the Sylvania bulbs are going back !! . Not worth the hassle at $55 per box even with the good specs when the they worked. Not worth the risk over the long haul.
T8
LED
EDIT
