let's see your craftsman block grinders
JoeLee1
Hi guys......... this is my first post here.
I have an old Craftsman bench grinder, I don't think it's what would be referred to as the block. It's a model 115-6965.
I'm not sure what year this was made. The tag says 01 48. January 1948 ??
Anyway, I'm looking for any information, parts lists and parts for this.
TNX......... JL
I would like to find some decent inner flanges and a clean motor shroud.
cajunfirehawk
Ms Gulf Coast
TNX......... JL
Not sure if you know, but their just so happens to be one on ebay currently, he wants big money for it and its been restored, I collect a lot of these and yours is only the second I have seen like this, Torqueman may have seen this before thought? Very nice!
Do you still have the metal band? if you can get the image from a clean one having new graphics printed would be more practical than finding a donor. Those are near unobtainuim...
115 was originally Packard Electric, then about 1932/33, Delco bought both Packard and sunlight Electrical, then in January of 1940 the Sunlight Electrical operations were separated from Delco (this has a Conflict with other info..._)
"It is believed that both Sunlight and Packard built motors and grinders for Sears" apparently under er the same number? then: in 1943, Sunlight Electric's small motor production was consolidated with Packard... So almost certainly under The Delco "umbrella" but exactly who was who is not known to me...
Nice find and restore so far!
cajunfirehawk
Ms Gulf Coast
The metal band is that polished stripped like chrome metal, the label/tag is actually on the back with just a small simple emblem on the front, see the one on ebay, no, not mine but tempting :wtf: Love those thumb screws and eye shields!
https://www.ebay.com/itm/Craftsman-Bench-Grinder-1-3-H-P-115-Volt/142738950715?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
torqueman2002
I've only seen a couple of these 'pre-pre'-Blocks.
They are all CI and very heavy.
Note the lights above the wheels.
This 1/3-HP is awaiting it's turn in my shop. The tag says 'E3 51'. I do think it could be March 51.
JoeLee1
I saw the one on ebay. It's a different model even though it looks the same, that one is 1/3 HP. I think mine is 1/2 HP. That may be the reason for the difference in model numbers.
So I must have a rare one ?? They probably didn't make many of them before they changed the design.
I started restoring mine about 10 years ago or so and couldn't find a nice motor shroud or inner wheel flanges so I put it on the back shelf. Now I would like to finish it up.
I would also like to get a pedestal for it.
JL............
JoeLee1
Yes, I have the metal band or shroud.
I was thinking of having it re-chromed but there isn't any one around me that does any plating. I looked into the home use kits but I don't think you get the same results from them. I don't know how I would reproduce the striping, mask it off and bead blast after chroming???
JL..............
JoeLee1
Thanks for the info and history.
I have an old Delco 6" grinder. I'll post a picture of it tomorrow.
JL............
JoeLee1
Is the band steel or aluminum? If aluminum you can simply polish and as you suggested media blast the stripes.
The band is steel and it's pictured in my first post, not the best picture.
It has some surface rust and pitting. I started to buff some of it off in one spot.
You can see the copper flash under the chrome, probably a couple tenths of nickel plating between the copper and chrome.
I can make new inner flanges, that's easy. The safety glass frames are pitted also but they are die cast. I could sand and polish them to bright finish aluminum.
JL..........
JoeLee1
I messed up both the flanges trying to remove them from the shaft. I know they are supposed to slide off but these woldn't budge. I could turn them freely but couldn't pull them off. No where to grab them with a puller and no way to press them off. I had to use a lot of heat and wooden wedges behind them. Finally I was able to remove them.
What had happened is there is a small groove in the shaft right in front of the bearing surface, like a relief cut or snap ring groove. It has a sharp edge and over the years of probably slipping and being tightened and pressed up against the inner race of the bearing where it seats, the ID of the flange kinda roll formed itself down into that groove locking the flange on the shaft.
JL.............
lafester
Northern CO
Ok there are a total of 2 block grinders for sale in my area (if they are even still available). Both 1/3 hp, one industrial on a 2 pedestal stand with one pedestal empty. The other being non industrial on a single pedestal stand and looks a few years newer. Both in great shape and of course premium pricing @ 150 & 170 respectively. Other then the plate they both look identical and neither have a light, so it really comes down to pedestal value as I would resell that to make it reasonable.
Thoughts? If they were under $100 they would be in my garage already.
I do like the look of that industrial plate and have an inquiry placed to check it out, but the pedestal on the other one is cool and seems like there would be higher demand for it.
JoeLee1
The long pedestal in the picture on the left is actually the base to a Craftsman jointer, I have in my wood shop.
JL...............
EOC_Jason
Bentonville, AR
^^^^ That... But I have seen a few people mount 2 x grinders on that pedestal...
Not sure what the resale vale of either is, I've seen a lot more of the single ones with grinders on them than the doubles with jointers... and I'm sure it is missing the motor mount and guard (for a jointer).
lafester
Northern CO
Almost every craftsman jointer I see is either on the rectangle stand or a home made one.
So does industrial make any difference between these two?
Sent from my ZTE Axon 7 using Tapatalk
lafester
Northern CO
No. The difference between the steel frame stand and the pedestal stand was personal preference and budget. The pedestal stands were more expensive.
There were two different double pedestal stands. One was intended for jointers and the other intended for wood lathes. I believe the bases and columns were identical between the two. The jointer tool mounts were uniquely shaped to match the bottom of the jointer. The lathe mounts are identical to the single bench grinder mount.
'68 catalog: http://vintagemachinery.org/pubs/222/6895.pdf#page=29
benches and stands brochure: http://vintagemachinery.org/pubs/222/4362.pdf
Thanks, good info as always but I was referring to the grinders. What is the difference between the two?
lafester
Northern CO
Here is a better pic of the double pedestal. I'm thinking it is for a lathe.
They probably had a 1HP mounted on the empty spot.
I'm going to look at it tonight... anything I should look for?
Been doing some research and it seems these pedestals are pretty rare. The grinder itself is fairly common but in great condition and complete. Pretty sure I will pick this one up and hopefully the stand will cover the cost.
lafester
Northern CO
It's mine... Can I join the club now?
I let it run for 15 min and I could barely tell it was on. Would like this to be a soft wire brush and polisher if I can figure out what to get.
So thinking about the stand a bit more and it sure would look nice with a top board and three grinders mounted on it. I'll probably put it up at an 'I don't want to sell it' price while I continue the hunt.
chrisnazzy
Arizona
Just let it run for 15 min and you can barely tell it on. Would like this to be a soft wire brush and polisher if I can figure out what to get.
Awesome!! I have the same industrial rated model grinder. I would have been all over that deal for a matching grinder and double pedestal stand.
John T
Limited edition
Miller welding model.
John T
lafester
Northern CO
Took off the stones and everything looks pretty nice. I assume the extra washer on the right side was for balancing. I know nothing about grinders, yet.
lafester
Northern CO
Can anyone recommend a good caster for these bases? I don't suppose sears parts still carries them. I'll probably end up making a 2x4 base anyway to protect the iron and raise it up a bit.
I would make a wider base if you put asters on it. With casters these get top heavy and can be tipsy. Having a top heavy tool go over can be the end of the tool. (the demise of a jigsaw I gave a friend when his son knocked it over and it crashed...)
lafester
Northern CO
One more question for the block heads... is there an acceptable lamp replacement out there that doesn't look modern? I've seen a few posts but nobody ever shows the final result or how to install.
To Outlawmws:
You know I had it set up to be wider and then I was thinking I needed the space so I put it on top of the long 2x4s and made it narrow. Now I don't have any bolts long enough to go through everything and it is a bit more unstable.
I'll see how it works out once I get it bolted down and level. The stand itself weighs 74 lbs so it's not really top heavy, although once I get a second grinder on there it may become so.
lafester
Northern CO
Worth $50? If I had the parts laying around I would jump but since I have nothing I hesitate.
trijeff
Northern Cali
Worth it for sure, you could just use for wire wheeling or buffing and then the missing bits become moot. But 3/4s ain't that easy to find, I personally would be all over it. Not a you **** deal but definitely a solid one.
lafester
Northern CO
Still waiting to hear back. This was a make me an offer deal and he accepted but hasn't set up a pick up time yet. Honestly I would rather pay more and have a complete piece then trying to find the parts after. This one would be flipped (minus the light if its good) after I find a 1/2 or greater round top.
After thinking about it some more I think I'm going to pass on this one.
Anybody near Denver that is interested should check it out on letgo.
lafester
Northern CO
I've seen some of your posts... you definitely have a serious problem.
I only see one double in your collection though so at least I have you matched there. Maybe there is another in your new in box section?
My plan is a 1/2 hp commercial on the other post and stopping there, at least for my own use.
Whats this club you guys speak of, something about double stands? :rocker:
cajunfirehawk
Ms Gulf Coast
Well YES, I do have a problem, lol
Cool thing about those bases IS, a lot of them had the "ball transfer studs" IE; round adjustable wheels on bearings that screwed into threaded holds on those bases, most were removed but a few of mine have them, they make those stands awesome to move around!
1PDY5_AS01
lafester
Northern CO
So I made an offer on the single pedestal and I may end up with both of these. I think they will look great side by side on the double stand until I can find a 1/2 or 3/4 round top worthy of that spot.
The single pedestal will be sold to pay for the second grinder. Curious if any of you run the power cord down through the column? I have mine that way but I think I need to put some small spacers in so I don't crush it.
