let's see your craftsman block grinders
BTL-A4
Santa Clarita
2. searching 'this thread' for [ replacement rubber feet ] brings up some options, including the part number for the Lowes feet.
Rubber feet make a huge difference. I also have some grinders that sit on rubber pads instead.
Thanks. I found a few references to this in this thread for the grinder feet: Hillman 884633 grommet. The picture doesn't look like it will work, but I'll go check them out in person and see what they look like.
I saw ones on Ebay for $25 for a set. There was reference in the listing for replacement ones that were copies for less, but I could not find it.
BTL-A4
Santa Clarita
It’s very easy to take these apart and no nothing with fly out and fall apart. On those Delco grinders the stator is bolted to the right stator housing. You can see I circled the two screws holding the stator in.
Hammered grey by rustoleum is your closest match for the color.
As for the eye shields, if they are not broken and are just yellowed you can treat them as if they were fogged up headlight lenses. Use a metal polish called white diamond and they will clean up real nice. They are just oxidized from UV. The polish will take off the layer that is oxidized.
Also you asked out the rubber feet. They do sell NOS of them on eBay but you can get gourmets in the electrical section of Lowe’s for a lot cheaper.
Thanks for letting me know the parts won't all fall apart! Ha!
Does it matter what the color is? I'm restoring this for my use. Just curious. I like the darker color on the instruction manual. Hammered finish might cover some of the flaws, too.
I thought that might be the case. I'll give some polish a try. Do you need a particular pad?
BTL-A4
Santa Clarita
UPDATE:
Eye Shields
I tried the polish:
It looks better in the photo than in real life. Both eye shields are cracked and very yellowed. I think even if I do get the yellowing polished out, the crack will be problematic. This grinder will be set up for wire-wheeling. I can make some eye shields later.
Feet
The ones at Lowes are a great match. The image online does not show the proper feet, but the part number given is correct.
Paint
I tried a metallic black on a scrap piece of metal and did not care for it. It went on too lumpy. I think I'll use a plain gloss black or dark gray.
drs3317
Western Maryland
UPDATE:
Eye Shields
I tried the polish:
Feet
Paint
A4, I know everyone has a favorite they like but the best match I have found which I have used on several grinders is Krylon Fusion Metallic Dark Metal. or the center band I have several but prefer Rust-Oleum Universal Satin Nickel.
As for the eye shields I have found no exact replacements. When they are as bad as you have with the cracks, your bets bet is to locate some close replacements that will at least be functional.
Good luck and show us your progress when you can.
tym
@BTL-A4 I've seen generic eye shields on the 'bay that could be made to work.
I also saw only one spark arrestor in your photos. Are both of them there?
doggonedawg
I have a 3/4 hp CM grinder with a serial # of 397.19350. It recently started to need a slight push when starting but then ran fine. Now, it will not even start with help. I was thinking start capacitor but I'm not sure from some very limited research that this model has a capacitor but rather has separate start windings? What do ya'll think could be the issue? Capacitor, Relay?? I haven't torn into it yet. Thanks in advance.
DDOPWD23
Glen Rock, NJ
Those have a sensing relay to start Delco did away with start capacitors. You can see it at the bottom, I know yours is boxed and this is the cast aluminum round but still made by Delco.
FrankLee
seMI, 48317
Check this thread for a possible fix:
https://www.garagejournal.com/forum...nder-not-reaching-speed.515509/#post-10111020
doggonedawg
Is this part still available somewhere or a replacement?
DDOPWD23
Glen Rock, NJ
I am not sure if they do. That’s why I like the capacitors because they are still very common and cheap to find. There should be a numbers on it to help with trying to narrow it down. I might have one but it’s for a 1/3 HP motor so I don’t think it would work. I’m not sure what amps the 3/4 HP draws but I think it’s going to be more than 6amps so I don’t think my would work.
doggonedawg
Update, after researching the issue here, it became apparent that unless the windings were fried, the issue would be the start relay. I removed it and found that it had a good deal of oily residue leaking out of the housing. Upon disassembly, the internals had a good coating of this oil also. After cleaning all the parts good and polishing the contact points, i reassembled it and it worked perfectly!! What does everyone think the oil like substance could have been? Is that little part with the coils inside of the relay filled with oil? I could see no other way in which oil could have gotten there. If so, I'm sure it will leak out again?
59Sled
Santa Clarita, California
This one is currently in the maintenance guys shop at my work. Pushed in the back corner and hasn't been used in a few years.
Recently I've been putting the bug in his ear with the ol' saying "if you ever want to get rid of that. Let me know and I will take it off your hands."
Hopefully he gives in at some point.
Not sure how old it is, but I do know it still works.
bugzilla46310
Demotte, IN
Picked this up today. Found on marketplace for $50. Got it from the daughter of the original owner. Manual from Vintage Machinery for the 397-19590 is dated 1966. Yes, it came with the water trough also. I was amazed how long it took to stop rotating once turned off. Needed to find a new grinder as my 40+ yo made in Taiwan 1/4 hp grinder that I bought new was beginning to squeal now and then.
bugzilla46310
Demotte, IN
If I was closer, I would be happy to get that buffer out of his way also!
Notgrownup
Snow Hill NC
Is this considered a block grinder. A lady at work gave it to me. It still works fine.
DDOPWD23
Glen Rock, NJ
Hi, new member here but I've got an old grinder. I just got it and the previous owner performed motor windings for a living so I know it'll outlive the Bauer grinder behind it as well as me. The bearings need lubed and it needs some wheels but it's cherry:
Nice find, made by Delco electronics right after they replace Packard Electronics. Delco made cast iron grinders for two years and then switched over to cast aluminum. They also switched to a new color and their own designs for their grinders. The only thing that stayed the same for a while is the motor housing. Delco also dropped centrifugal switches in favor of sensing relays. I can’t be certain on the cast iron version but the bearings switched from 6202 to 6203. You will have to check before you order new bears. They are sealed so you won’t be able to clean and repack the grease.
DDOPWD23
Glen Rock, NJ
Unfortunately it is not. Still an uncommon grinder but not what this thread would consider a block grinder. Those were sold separate from a motor. You could purchase the motor that came with yours or an owner could have bought a cheaper one to save money or use a motor they already owned. Granted it ran at the correct RPM.
Sweet_Johnny
Wichita Ks
Good to know, thank you. I've got quite a few irons in the fire right now so I haven't given it any attention and had assumed I could simply solve the squeak.
DDOPWD23
Glen Rock, NJ
You actually don’t have to take it completely apart to change out the bearings. There is enough give on either side to get a bearing puller on and swap them out.
Sweet_Johnny
Wichita Ks
That's the best news I've heard all day! Seriously though, that is good news and it makes it much more likely to happen in the near future.
DDOPWD23
Glen Rock, NJ
Just recently I swapped out bearings on this one in 30 minutes. That’s including disassembling and assembling. I changed out the new Timken bearings for NSK bearings. I find made in Japan bearings are a lot better than ones made in China.
bugzilla46310
Demotte, IN
I ran across this grinder on marketplace when I was looking for the one I just bought. The price was too much but I noticed the oil cups, and the gold color which seems less common. I’m a sucker for old tools, don’t need another grinder, but it looks like a fun project to restore if the price was right. Any info on what model this might be? This is the only picture.
DDOPWD23
Glen Rock, NJ
The badge is early version roughly 1946-1950 but the color is power bronze which didn’t come out until 1956. If you look on vintage machinery website they have all the old catalogs, you can start 1947 or 1948. They don’t have maybe catalogs that took place during the war. Everything was focused on the war effort at that time. You’ll find what you’re looking for.
59Sled
This is so beautiful, If I owned it, I don't know if I could bring myself to use. it. I would probably have it on display inside the house.
DDOPWD23
Glen Rock, NJ
Thank you, I appreciate it! It was my grandfathers and I restored it 5 years ago. It gets used a lot actually. I have been restoring a lot of my grandfather/dad’s machines from their old business. I was gifted a lot of machines and I acquired a lot as well. It’s been used non stop since I restored it.
I have since duplicated every machine I have so that way if my son shows interest he can have them, a nice gift to get. If not I will just sell them. All the battleship gray ones are his. The last two 1/3 HP need to be restored.
I have other vintage machines as well, you can spot some in the background but this thread is for bench grinders. I do realize these down here are not considered “block” either. They are the “tombstone” or “mailbox” style that has been argued over these 340 pages.
Sweet_Johnny
Wichita Ks
Excellent. I really appreciate the great information- thank you. I feel like you're probably going to educate me on more than one thing and that's exactly why I'm here.
Beerhippie
Far NE Oregon
Timken is now MIC? Is nothing sacred?
I was raised on Timken bearings... likely why my teeth look like they do.
DDOPWD23
Glen Rock, NJ
Sorry to say but they are. I still hold onto the original NP bearings that came with the grinders. In fact I hold onto all Made in USA bearings. Most of the time you can clean them out and repack them and they are just as good.
lafester
Northern CO
Those cast iron ones are the best! I believe they are called "pre-block". I have had all three versions but kept the 1/2 HP of course.
BTL-A4
Santa Clarita
I got this today for $40 (asking $50) on FBMP:
The cord needs replacing, the water tray and the lampshade are missing, and the plastic eye shields are all yellowed. Not sure how brittle they are, but they survived a trip home in the back of my truck. We'll see how the rust cleans up. I'm going to use if for wire-wheeling.
Looks like it takes 7" wheels.
QUESTIONS
I'm wondering if I can get a standard lamp to fit in the base?
Does anyone have any ideas for restoring/replacing the eye shields?
UPDATE:
I've repainted it (Rustoleum Charcoal Gray) and Metallic silver, with a reproduction sticker, got new rubber feet, and put wire wheels on it. The lamp is not hooked up, but I may not need it. I will make or get new eye shields later. I mounted it on a wood base that is mounted to the workbench. I've used it once and it works very well.
BTL-A4
Santa Clarita
I'm restoring my grinder and I have a few questions:
1. What happens when you split the two halves apart? Do a bunch of parts and pieces all fall out and become a PITA the reassemble? I have this grinder. It looks like nothing is holding #12 but I thought I'd as before I pulled it apart and parts went everywhere. I unscrewed the bolts. The halves do not separate easily. I might just clean them up and repaint them in place.
2. Do I need the rubber feet? Mine has none. Are parts available? Is there a substitute?
3. Paint Colors. Mine appears to be painted silver/gray. The instructions I have are from 1975. These have a photo of a dark-colored grinder. I like the darker color, but does it really matter? I thought I might go with some sort of metallic dark gray.
4. How do I restore the plastic eye shields? The ones I have are yellowed. Are there replacements? I could fabricate something, too. I will be using this for wire-wheeling. so I may not even put shields on, since I move them out of the way anyway.
5. What is the best way to get the baked-on metal dust off the inside of the wheel cover? I've chipped out what I can, but some is still there.
Thanks!
I'll answer my own questions:
1. The halves appear to come apart fine, but I did not do that. I took off the middle band and was careful when I was cleaning and painting.
2. I found the rubber feet at Lowes. The part number referenced in this thread works perfect. They are in the drawer with all the grommets and were the only ones in there that looked different.
3. I used Rustoleum Charcoal Gray. I had some on hand and it also looked good to me. I wanted some contrast between the silver center band (Rustoleum Metallic) and the rest of the machine. I used gloss, but I think satin would look good as well.
4. I used some metal polish recommended and it worked, but these were too far gone to get clear enough to be useful. After cleaning the eye shields, I saw that they are very cracked and crazed and would not be safe to use anyway.
5. I chipped off the baked-on dust with a sharp chisel then used 400 grit sand paper on a stick with water to sand the rest. I also used picks to get in the corners, and I used a rotary tool with a small steel brush as well.
BTL-A4
Santa Clarita
I want to try this as I’m not sure if it is a close match or not.
I sprayed some hammered metallic dark gray on a scrap piece of metal to see what it looked like. I didn't care for it; it was too lumpy-looking. I would suggest spraying a piece of scrap and seeing if you like it.
Generally I'm done with "tool Grey" (AKA Battleship grey) I started doing everything that color in my late teens, early twenties and it wears, well, but its boring. If it was tool related I painted it; especially tools I made like the cherry picker, H press, benders, Engine stands etc, and my bench tools like my vises, press, grinders, etc.
BTL-A4
Santa Clarita
Yeah, I agree that gray is usually boring. I thought of painting this red with a silver center band. I opted for the dark gray because the manual I have has that color on it and I liked the look. I wanted something metallic, but all the metallic paint was hammered and that looked lumpy. I even thought of painting it gold, but I wasn't sure what to paint the band (black, dark gray, red maybe).
I redid a vise I bought. It was gray. I repainted it a really pretty turquoise blue. I had a Craftsman lathe that was a sparkly lime green (I called it Disco Metallic Green). When I got some new parts, I used auto paint to paint everything the same color since there wasn't a rattle can color even close. I bought a drill press vise and painted it Sage Green. My lumber rack is maroon red and my welding table is Sunflower Yellow.
