espyking83
I just got a Dayton grinder and they're pretty similar to the craftsman one, it runs fine, but is there any type of maintenance that i should do before i run here regularly?
here you go
I think the sand will be to "flat" looking, the original gold was more metallic looking.
Anyone looking for worklights for your block grinders ?]
Brent: better question is why haven't you always wanted one.![]()
Is that color 'pebble', 'almond', or 'bronze'? I don't see a label.
Edit: I think bronze is what another fellow used.
Nice score.Thanks everyone. It was a very good CL find. There hasn't been much of anything around me for the better part of a year when it comes to Block grinders. When I saw it listed late last night, I did a double and triple take. All I can say is "keep looking".
Drives,
I'm getting close to the point where I can start fooling around in the garage again. However, I didn't hesitate to drive out to the hinterland and get this one. It was an hour away - almost into farm country, but who can pass that up? Here is what I'm thinking of bolting on:
http://www.trick-tools.com/Multitool_2_x_36_inch_Belt_Grinder_Attachment_MT362_305#.VFF2KPnF-y4
What tasks are best suited for the different horsepower ratings? I have a 1/3 hp and 1/2 hp. I like to have one grinder with a buffing wheel and wire wheel and the other with stones.
JCM: i'd say you have a good plan with what you are going to use your two block grinders for. the lower HP is fine for sharpening because you don't want to take big chunks of steel off or cause the steel to loose it's temper by turning it blue. also since you are missing the guard for the one side of your 3/4 HP it's a perfect fit for a buffing wheel where you can get better access. some people buff at 1800 RPM and others at 3600 RPM, but i know they all like more HP if they can get it so the 3/4 is also the best choice.
A good wire wheel usually doesn't spit wires out. I like knotted for that reason. If it does, it's time for a new one. A wire wheel (or eye protection) costs a hell of a lot less than eye surgery.
I have the same question. I have a 1/2 and a 3/4 so I'm in much the same boat, with a couple of differences. The 1/2 is a 7" and the 3/4 is an 8", and it's missing the right guard pieces. So the decision for me is pretty easy at this time: 1/2 as a grinder, 3/4 as a wire wheel. I've also reasoned out/self-justified this decision this way:
1/2 7" as a grinder since I tend to do light grinding work and the small wheels give slightly smaller SFPM which will help when I'm sharpening tools on a white wheel.
4/4 8" as a buffer/wire wheel since it has more hp and I can bear down on the buffer a bit more if I need to without slowing down the motor.
I don't know if that is the best way, or if I should be looking for an new right guard for the 3/4 in order to make it a grinder. Any thoughts from the experts?
I should be good rewiring my grinder with 14 gauge stranded wire, right? I think it's 18 or 16 gauge right now.
If you put that on your grinder,you will never go back to wheels. I have one and it's amazing!
I converted mine to accept 2x42 belts, but you might consider buying the more costly 2x48 version. Belts change in seconds, and it just purrs......
exmax,
Why are longer belts better? Do they last longer or run cooler or both? The 2x48 is "only" another $80, but if it is worth it, I might just go that direction. Also, can you share what you like about the belts versus the wheels?
Halloween Weirdness aka "Haunted Block Grinder".
All,
I have a wiring question on my 397.19670 3/4hp Industrial. I spent some time taking the cast iron base off and found a lot of cob webs. I also found some clean shiny windings. So far, so good.What I didn't find was the galvanized base cover and, therefore, no date stamp. That was a minor let down. What else I found was the remnants of the original switch tucked inside. It is hooked up and is only missing the toggle. I was able to flip the contacts by inserting a small screw driver in the hole where the toggle used to be. That was a good find.
However, here is the weird part. Off is On, and On is Off with this switch. In other words, it works backwards. Flip it to Off and the grinder starts up. Flip it to On and the grinder turns off. I double checked the notch in the threaded collar and the switch even has On and OFF stamped on the cover plate. Here is a picture of the wiring:
View media item 44385
Maybe I'm just seeing things, but I can't imagine a switch working backwards even if the wires were switched around. Any ideas or should I just wait for the ghosts to clear out tonight?
EDIT: Mystery solved. Someone had taken the switch apart and put it back together backwards. Another switch worked fine.
i have a 3/4 HP commercial
here is a pic of the panel and wiring label, hope it helps
The longer belts are a standard size and easier/cheaper to get than 2x36. And longer belts last commensurately longer. I like how there is a "softness" on the rubber wheel so you get very little bounce. And you have tremendous access for whatever you are grinding. Lastly, if a belt breaks there is very little stored energy to hurt you----well, you probably know what happens when a wheel explodes....
Good point on the safety issues, I hadn't thought of that. I also took a look at mscdirect.com for replacement belts. There were 6 choices for 2x36 size and 69 choices the 2x48 size. That has me thinking. Buy once, right?
