I doubt it.
Gentlemen, I have my vintage Craftsman grinder on this original stand and the whole thing vibrates and moves around when I turn it on. Short of anchoring it to the concrete do you have any tricks on reducing the vibration and stopping it from dancing around?
Buy a diamond wheel dresser and true up the wheels. In the meantime, make sure the wheels are not wobbling side-to-side---shim the hubs with strips of tape if necessary. Then slowly dress the wheels concentric with the diamond tool and the vibration should disappear.
Thank you exmaxima1, I have a stone wheel on one side and a wire brush on another, do you think that's the problem?
I picked up a 1/3HP pre-block from a local thrift store today for $28. It was too nice to pass up. Dammit, I don't need another grinder!
Brian
Add pics to my Pre-Block thread!
http://www.garagejournal.com/forum/showthread.php?t=339921&highlight=pre+block+love
It seems it's feast or famine here. Yesterday morning I pulled the trigger on a 1/2 HP industrial round top...
...and then two hours later found a 1 HP flat top on Craigslist. I've been chasing a 1 HP block for a while with no luck. I know, I know, it's just a number, but it was still on my list.
The latter came with a lot of extra grinding wheels but may not use them due to their age.
Nice job!Finally had time this week to start restoring my 3/4 cap start. It was actually in decent shape once degreased, but still wanted to strip/paint. Not sure how I survived without a blast cabinet as it makes the stripping process go very quickly. And based on the debris on the top of the pedestal, I doubt the grinder was ever removed.
Also did a quick wipe down of the stand from a recently acquired 1/3 and this one will stay original as it is super clean. The color looks very similar to my CM 150 DP, especially on the head unit which has less fading.
Including a before shot:
Nice job!
Another grand CM Block ready for another few decades of service!
You probably will replace that sketchy grinding stone. Let us know if you need ideas on where to source them; MSC, and Grainger come to mind.
Oh, I fixed Wolfe up with a quench tray when we got together in Jackson, MI. today.
Here's the 150...
I added this little table to the tool rest, so I could use this cutoff wheel.
I find it very useful.
The grinder on the left has a medium and a fine wire wheel.
Those seem to get a lot of use around here too.
The Rockwell grinder in back has two green wheels on it.
(That little old egg beater drill is a fun way to put a point on tungsten for the TIG torch).
All three of these grinders are half horse models.
I have had the block with the wire wheels since I bought it new in the early eighties. That was the first power tool I ever bought and it is still going strong!
Thank you, I think this is one more reason for owning multiple bench grinders.
It does work well for nipping off bolts and things. I also use it to follow the contours of curvy pieces, or putting notches in things....
It is a seven inch cut-off wheel, made by Radnor, for steel, or stainless.
I used a bronze bushing as a spacer.
Do you have a link to the cut off wheel? Also what size arbor hole is on it and what reducing bushing did you use?
yes, that about covers the details that I am aware of.
(exmaxima1 - you have an impressive assortment of belt sanders!)
I've got more at home---I know, I have an appreciation....
... of Poulsbo Machine ....
7-inch cutoff wheels are pretty common, and even available at HF:
http://www.harborfreight.com/7-inch-cut-off-wheel-for-metal-39679.html
Most have 5/8" bore so you will need a reducer bushing if your grinder only has a 1/2" arbor. I find them very useful for small things, as employed on my "Frankenstein" belt grinder. They don't cut real fast at only 3600 rpm, so you have pretty good control as well.
