I really like the way it looks but I wonder how it would hold up to hard use. It really is unique and pretty cool.
That is beautiful!
Bench looks nice but the wiring of the lights needs some work.
That looks so awesome!My Habitat Restore $10 per cabinet score:
Top is 2 12' pieces of laminate, so that gives you a hint on the scaleI have 4 cabinets leftover as well.
I also have a rolling 4x8 with a vise I use for normal "workshop" tasks, with a OSB top I can replace when necessary.
It is as think as most garage floors. I would bet it holds up quite well, especially if it is re-enforced. I would be more concerned about how much it weighs. I am guessing around 800 lbs.
Looks really good and solves a lot of problems with traditional work benches. You could add some dye or and make it look really cool too.
LOL that's got better reinforcement in it than most peoples garage floors
Here is mine, Work in progress. there is a 2x4 mounted to the wall, and then the 4x4 posts are notched to fit in to the 2x4 top frame so the frame rests on the wood and the screws are only holding the post in the right location, all the weight is transferred directly to the wall studs or the 4x4 posts.
The radio shack cabinet is built into the right side, and the toolbox that was left at the house when i bought it is built into the left side, Ill be mounting my hose reel above it and have it coming through a board that will fill in the area above that toolbox (like Jack Olsen did) Still need to mount my costco LED light under the cabinets to improve the lighting at the bench.
Thats alot of OSB! Maybe paint it??
here is my new workbench. I weld a steelframe and adjustable legs.Top is made re used oak parquett and covered with 1mm steel plate. And power socket too.
Dimensions are 75 x 200 x 90 cm or 2,46 x 6,56 x 2,95 feet
Vice is 4 inch old russian made and it is very sturdy. They don't make these any more.
Sorry my english.
Very nice!
Nice bench- how do the wheels work on the bench- your English is way better than my Finnish!
Built a nice folding work bench for my one car garage. I will be building a second longer one once the weather warms up a little bit.
How old is your building viikinki?
Is it a hundred years old? The windows look ancient.
Your English is very well!![]()
