my wife has a work bench. Not so much work going on but its used to stage stuff... empty coffee cups... work stuff ect.My girlfriend wanted a small workbench, so I recently built this for her. I removed the wheels from the lower toolbox and mounted the box to the lower shelf of the workbench. I put wheels under the workbench so she can move the workbench and toolbox together wherever she wants. I am not a wood worker, but it turned out ok.
What does your work area look like?
This is very cool. Everything is so clean too! The two chainsaw shelves are particularly impressive.I recently moved (again and for the last time I hope!) and got to build the workbench I wanted to build for a long time! I was given a sheet of bowling lane wood, which is the pine section I believe. I cut it down to 24" depth and belt sanded all the old coating off, then used water based poly for a top coat. Someday I would like to paint the bench frame and legs black but that can wait. The floor is slopped pretty bad so I had to use some furring under the tool cabinets to keep them level.
Thank you!This is very cool. Everything is so clean too! The two chainsaw shelves are particularly impressive.
Thanks Z! The trophies are from autocrossing. The oldest is from 1974, the last from '98. I kept the ones that remind me of a particularly enjoyable event or the very good friends I played with in those days. A couple of them are my wife's!Nice looking bench area.
I still have multiple boxes of trophies, plaques and awards that I had on shelves in my last shop. Can't bring myself to put them up in my new shop.
Really nice setup. I appreciate the gorgeous cabinets and pristine conditions of some who post. But nothing says home like a personalized space that works well and rocks the memories. Well done!
I wouldn’t change a thing. That workbench is a practical tribute your father.
The only issue is that I'm starting to work on insulating the garage so I can use it year round and the current bench is attached to the wall studs. I'll have to do at least a little modifying to work around that, but I've got some ideas.I wouldn’t change a thing. That workbench is a practical tribute your father.
I would consider “adding-on” if you would like drawers, but I’d try to do it in a way that didn’t destroy anything.
Understood. Insulating and covering the walls with sheetrock or plywood after insulating would be a good move. You can adapt the bench to that situation and the essence of your father's workbench would remain. Just put a few legs in where the bench was supported by the studs then cut or remove the nails fixing it to the studs. You will want to add some sort of diagonal bracing to the rear to keep it from racking. 1X stock should be fine for that.The only issue is that I'm starting to work on insulating the garage so I can use it year round and the current bench is attached to the wall studs. I'll have to do at least a little modifying to work around that, but I've got some ideas.
Yeah, I’ve considered it - if only to serve as an example of clutter out of control.
