abstamaria
Robot Legs
I understand, thanks. Great work, Alan.
Andy
thanks for the compliments guys.
I like my vice as close to the edge of a bench as possible. Also, with the way i mounted the legs, i did not want them to get in the way of vertical work pieces clamped in the vice. With my last bench, If i put a piece of work vertically, and it extended down past the bench, it would hit the bench. As far as strength, The vise will break before the bench fails. The extension on the bench is solid 2" thick steel. All mounting bolts are LE (USA made) grade 8. The 4 vice mounting bolts are 5/8" diameter. The side extension is held on with three 1/2" bolts. All bolts are threaded deep in the steel block.
Andy
