richfinn
Yes that one
It had a EGR circuit code not a flow code, TSB applied, no other scan tool showed that MAF code, nor have I seen it , on other Connect ,plus this vehicle does fall under obd2 compliance so it should have the US protocols, but you may be right IDK. But this is just on example of bad codes in generic OBD2 I have seen, I cannot tell you how many times I have seen phantom codes on OBD2 generic, that are not there on the enhanced side. FYI I tried the generic side of IDS, Modis, OTC and Autel code reader on none showed that code, also I had several other times were that app flagged false codes I just do not remember the others off hand
I think EOBD and OBD11 are slightly different, I know they export these vans from Europe with rear seats and windows and then Ford pay someone to convert to cargo vans, I suspect they might not fully comply to OBD11.
Do you have an engine code??
Almost no one in Europe will run a gasoline version, they will 99% be Diesel
