kythri
So, can these jacks using the o-ring be retrofitted with a U-cup when a rebuild is needed?
This pump is the same as the one used by the MEGA jack. See the picture of the MEGA jack, model T2X. Also, see a picture of the TORIN T820028D with four wheels and a picture of the optional four wheels for the Mega T2. Also, a picture the OTC 5200.So, tell me HIBALL, would you pay $500 + for that jack knowing what is inside the pump?
How do you tear down a OTC 5200? I don't see a tank nut.
Link to diagram:
http://www2.otctools.com/otctools.com/newcatalog/products/553737_E.pdf
If you remove the C-clip, then you can just pull out the seals? Do you have to place the hydraulic unit on a vice and then use a pipe wrench and twist off the cap?
Wow, it sounds too easy to get to the OTC 5200 o-rings. Even if the OTC 5200 o-rings last only half as long as u-cups, it looks like it is easier to rebuild the OTC 5200.
I never get under a car with out jack stands.
Arcan has a new 2 ton extra long low lift jack with higher lift. Check below the current Arcan offering of steel jacks.
http://www.powerstationusa.com/brands/Arcan/?s2=Steel Service Jacks&s1=Lifting Equipment
Also, check the aluminun jacks now sold under the NOS brand. Some of these are also sold by Harbor Freight under the Pittsburgh Automotive brand.
http://www.powerstationusa.com/brands/NOS/?s2=Aluminum Service Jacks&s1=Lifting Equipment
It is not uncommon for a manufacturer to modify jacks per the buyer's (distributor) specifications.
I unboxed the HF 68050 last night. I installed the handle. bled the pump and jacked up the front of my Jeep. It worked, and raised it pretty darn high. It also seemed to lower the Jeep in a fairly controlled manner, but I did seem to have to keep opening the valve a little to keep lowering. It seemed like it would lower a little bit and stop, lower a little and stop. That hasn't really been my experience in the past. Most jacks have usually lowered the car, or whatever you're lifting, until it's on the ground once the valve has been opened. Does that sound normal? I only raised and lowered my Jeep once just to see if the jack worked.
Now to get some jack stands, and maybe some sort of pad for the saddle.
What is a better quality o-ring? What is a quality o-ring made out of?
Edgar mentioned that you can not get a retainer unless the jack manufacture sell it. Hiball, can you acquire and sell us a retainer?
This is easy to solve, just call your local hydraulic shop and ask them if they sell single retainers (not in kit form from the original jack manufacturer or distributor ) as an aftermarket replacement seal not directed towards any specific brand or model. Also google "HYDRAULIC SEALS" and call all of the companies selling aftermarket replacement seals and aks them if they sell aftermarket replacement o-ring retainers. If you find one selling them, please let me know.
