lilscorpion
Here’s a couple of better pics of the rivnuts and how I install them. Notice I’m clamping it to one of the wall organizers.
this is the backside.
And the front.
I spent the afternoon installing the panels. Got them all up but ran out of both rivnuts and screws which sucked. These panels will straddle the surface mounted conduit so I have to French the conduit into the sides of the panels. I started by leaning the panel up against the wall and marked above and below the conduit. Then I found a washer that’s just a hair bigger than the conduit and traced it with a sharpie.
Cut to the left and the right with a cutoff wheel in a grinder then just kiss the middle of the circle so I can break it off.
From there I make a bunch of little cuts into the circle stopping at the line. After I touched it up a bit with a carbide burr.
This will look so much cleaner and I get my wall back.
…and got my knuckles with the cut off wheel cutting up the scrap of a sheet on the plasma table. Would have been lots worse if I wasn’t wearing gloves.
And the front.
