Looking for simple sealer
ExxWhy
NE Ohio
I'm looking for something simple that goes on over a clean floor to help keep out oil and fluid stains.
40X44 building with 5" of 4000 PSI concrete, hand troweled to a smooth finish. They sprayed on some sort of cure sealer when it was poured, but otherwise it's fresh concrete, poured last May. I'm good with how it looks as is.
I'd like to be able to clean up oil and fluid spills easily, just want something to seal the concrete. Low cost is important.
I was looking at something like Ghost Shield or TrueLock PPC. Either seems to fit the bill, are there other products that anyone would recommend?
Does the cure sealer have any effect on what I can put down? I could find out exactly what they used if it helps, but I don't know at the moment.
LegacyIndustrial
deerfield, IL
It will block sealers. Needs to be stripped or sanded off to allow penetration.
If you want an invisible sealer check out our SilaxSeal. Excellent protection for a better price .
naturalgas
Metrowest Ma.
I don't want to hijack thread ,but how would you strip or sand off cure sealer. I'm looking for same thing . My slab is only two months old.
bdamico
How do you test for sealers that would interfere for unknown slab--water absorption test like you would for epoxy?
Shea
California
Yep. You are basically checking for the same thing as you would before deciding whether to acid etch or have to grind due to a sealer. Cure and seals are the most common reason people can't acid etch.
E
ExxWhy
NE Ohio
The chemical stripper looks like it would blow the budget. To be more specific with "low cost" I mean under $1000 for the whole job.
How much sanding is involved to get the cure sealer off? How do I know when enough is enough? Should I do a water test with taping down plastic?
LegacyIndustrial
deerfield, IL
I can't tell you how much sanding will be needed without seeing it. However, if just a thin sealer as you described, should be a few hours and a stack of screens at worse case.
Note, that this will "scuff" the surface in the process, it's unavoidable.
Garage Flooring
Grand Junction, CO
The two product you mentioned are awesome. Do you know what brand and product was used for a cure n seal? Does water penetrate or bead?
E
ExxWhy
NE Ohio
I would say water penetrates. I do not know what product they used, left em a message to call back with that info. It's a contractor, we'll see if they ever do! ;)
Would good close up pictures help?
Armorpoxy
Hi
We would recommend our SPGX one part polyurea. It sticks to virtually anything. If you contact us we will send you a small sample n/c to test. You may have to lightly scuff it up with a sanding pad. Cost is around 30-35 cents/ sq ft.
Garage Flooring
Grand Junction, CO
Garage Flooring
Grand Junction, CO
Chuck Baggs
If the concrete guys used a fair amount of Curing agent, during the pour, that will likely act like a bond breaker, so if you don't want to put alot into prep, like sanding, grinding or stripper a great option is a floor wax. Floor wax is cheap, easy to apply with a mop and if you don't like how a couple coats of wax looks in a year or two, just strip it off with ammonia & hot water easily!
Wax is cheap and be bought at smart & final, home depot. I did this in my old garage shop ( I did 2 coats). It worked well and was cheap. A gallon of floor goes about 600-800 sq ft per gallon.
Good luck!
E
ExxWhy
NE Ohio
A product called e cure http://www.specchemllc.com/wp-content/uploads/2015/05/E-Cure-Tech-Sheet.pdf was used for the curing. It claims "Will not inhibit adhesion of secondary coatings, topping, or adhesives designed for concrete."
The distributor recommended a product called SLX100. They use it in schools and stores a lot.
The more I look into this, the more I see there are lot's of choices! Getting analysis paralysis!
