Looking for wall framing advice.
MopardudeWI
Whitewater, WI
Going to be framing out the inside of my shop soon in order to insulate it. I have 2 wall sections like this (see my attachment) where the window is up tight to the post so i can't run any full length studs on that side. I also plan on putting ceiling joists that will sit on top of this wall. Can I make up the strength by lag bolting the top of the wall to the post or is there a better way to go about this?
19Vert64
Had same issue and did mine like this
The Cobbler
probably depends on how much weight you want the joists to hold? is it just for a ceiling, or is it for storage above?
You could probably run a header over the window and use a joist hanger at the post
if you do like the above poster, and you're using it for storage above, I would run a built up beam along the wall to run your joists off of
K'ledgeBldr
Johns Creek, GA
Put a header in to span the window opening- a double hanger with inside nail flange on the post and a double stud on the other side of the window.
19Vert64
Should add that I was not adding joists on top and don’t need it to hold any significant loads
Daniel Dudley
If you went with spray foam you could just hang inner girts and put your sheet goods on those after spraying. There are a lot of ways to skin a cat. The barn is already built, so you don't need major structural wall framing. Some guys would use foam sheets and screw furring strips through to the outer girts.
MopardudeWI
Whitewater, WI
Yea it is just to create a ceiling so I can insulate it. Your thinking along the same ways I was kinda thinking, didn't realize I could use a joist hanger to accomplish this, good idea.
MopardudeWI
Whitewater, WI
Off topic but this seems to be one of the reasons to stick frame vs pole barn?
I would say no. The previous home owner built this polebarn, so his needs were probably not the same as mine if he never insulated it. If i was building new I would just make sure the windows weren't placed so stupidly. lol I have 3 windows in this pole barn and only 2 of are tight to post like this was just the way the spaced them out.
MopardudeWI
Whitewater, WI
True, I contemplated going foam the main reason I didn't I am just going to go around doing each section between the beams as I can afford and when I have time to do it. I run a side business out of this shop so even though I don't really take on jobs this time of year because its cold as hell out there and burn a lot of propane to do so, plus I still have jobs going on I am finally getting too. It would just be a pain in the **** to have a crew come spray a section or 2 or 3 at a time or to even dismantle my whole shop to make it happen.
19Vert64
Interesting I contemplated this as well, the only thing is I want the insulation covered up. I am not sure how much weight can be hung from a truss.
Going with a ribbed pvc panel for the ceiling to reduce weight
TractorJeff
Elkhorn, WI
Seen as you are in Whitewater. That maybe a Menards building? Either way whomever designed it (Cleary?) should be able to tell you what the truss can handle for ceiling loads. I bought Trusses from Menards and the End Trusses had the ratings stamped on them.
MopardudeWI
Whitewater, WI
Sorry guy I didn't see your reply. Yes it is a Menards building built by A&K of Elkhorn. What kind of tractors and trucks you building down there in Elkhorn?
