Lowe's Clearance Thread 2016
Status
Not open for further replies.
06GMC5.3L
Classic Lowe's.. Got cancellation call, we don't have.. No wonder I haven't been to Lowe's in for 4 months. Lowes ****
Sent from my SM-N920V using Tapatalk
Go to the store and check if you are nearby. It's probably behind something else.
honda pc
I ordered it inside the store.. I first checked in store, even had electrical dept guy checked.. None to be found. He told me order it, maybe pc system will order it and Yu get it, then pick up. 10 mins after I order it, famous cancelation notice phone call. Even talked to supervisor, tuff luck, we don't have it..
Too much bs to argue with no service Lowe's bs.. Left and headed for HD store penny deals.
swoyer
Pennsylvania
On the other side of things if you just need some supplies you can get a decent deal over HD, if you stack the sales they are having, renovo power coupon and store pickup you can make out pretty good. Just ordered like 300 in grass seed and such. Pine trees are coming down, and grass will start to grow!
xriderbc
I've been in the store, item found and in my cart, ordered online to use renovo coupon, and bam!- cancelled before i got to go to order pickup. THEY DONT LOOK VERY HARD, if at all (actually that time, someone came to the isle looking AFTER they cancelled to get it for himself, but that's another common lowes story...)
harleybuilder
Southern IL
Did you happen to ask him if he was looking for your canceled order? I sure h!%l would have. ...
xriderbc
Actually, i DID! :evil: I watched him looking around the exact area (extension cords, but they were in the overhead behind the sliding panels-there were 10 showing online, and they were actually there, which made it even more obvious it wasn't out of stock ). I watched for a minute, then pointed to my cart and said "looking for these?" He got excited, and said "yeah, where did you find them? Those are a really good deal... you know how good a deal that is, right?" Ugh, yep. I then asked "are you looking for an online order?" and without thinking he says "nope". That's when i knew for sure that employees there were grabbing anything that was a huge clearance markdown. I had several orders before that get "cancelled" which is why i hurried to find it myself that time.
Mac339th
Northwest Arkansas
The hard handle Kobalt screwdrivers that are being clearanced out. You know the ones made in USA with striking caps (decorative probably)
Are there 8 total, 4 slotted 4 Phillips, or am I missing any?
I just got these yesterday. I have 9, not sure if this is all or not.
Flat: 3/8x8. 5/16x6. 1/4x4. 3/16x4. 1/4x 1.5 stubby
Phillips: #3x6. #2x4. #1x3. And #2x1.5 stubby
goodysgotacuda
DFW
Today's haul.
39714 Channel Lock Dykes - $9.99ea
525789 Kobalt #3 Philips - $3.59
525785 Kobalt 3/8" Flathead - $4.39
424988 Kobalt #10 Welding Lens - $1.69
165005 Kobalt Autodarkening Hood Clear Covers - $1.69
17897 Lincoln 0.025" Welding Wire - $3.91/2# spool (Usually about $12)
367249 Kobalt Scraper $1.50
4576 10pk replacement blades $1
425011 0.030" Mig Tips $2.37
464638 Kobalt 9.5" Cable Cutters $8.49
464643 24" Al Pipe Wrench $17.99
464652 10" Al Pipe Wrench $7.99
Above mentioned welding cart $17
krouchchocolate
Can you post up the sku numbers so I can check the inventory at my store. I know someone else posted it up, but the picture got blurry once u enlarged the picture.
firworks
IL
I bought an extra one to cut open and check how the bolster is done. When I get around to it we'll see what secrets lie within.
Mac339th
Northwest Arkansas
E
Don't have the SKU # but the UPC is below if that helps.
#3x6 - 76812 10530
#2x 4 - 76812 09575
#1x3 - 76812 09574
#2x1.5 - 76812 09576
3/8x8 - 76812 10532
5/16x6 - 76812 10531
1/4x4 - 76812 09573
3/16x4 - 76812 09572
1/4x1.5 - 76812 09577
dh1
Found a mailbox on clearance. Picked on up as I've been meaning to replace mine. Should have bought 2 since the mail post is shared with a neighbor.
And since IMGUR is acting up:
http://i.imgur.com/M2wDHga.jpg?1
CNGsaves
KS and OK
^ ^ ^ IMGUR pic's are NOT working.
Likely ought to just push file onto GJ under Manage Attachments after you click on Go Advanced.
firworks
IL
imgur has blocked GJ for terms of service violation because it has a classified section and people post images here. If there was no classifieds section they'd be fine with us all posting imgur images on here.
06GMC5.3L
I put together the welding cart yesterday and am happy with it. It is very sturdy IMO and fits the 140 Lincoln decently. Only complaints are that the top shelf could be longer and that one if the hooks on the side get in the way when trying to open the side of the welder.
Sent from my iPhone using Tapatalk.
06GMC5.3L
They did you a favor those are junk
Sent from my Nexus 6P using Tapatalk
False...You should do a little research and read some reviews before throwing out blanket statements.
They are great thermostats at a much lower price point than Honeywell. Super easy to program, most models also have a user defined "swing" temperature where you can set the swing to say 1 degree or something so if the stat is set at 68, it won't turn on heat until the temp drops to 67, then keeps it on to 69. Whereas Honeywell has like .1 degree non-settable swing which caused my equipment to continuously cycle trying to maintain the set temperature. These are also great in that they are battery operated, so for all of us with no "C" wire who can't use the fancy touchscreen wi/fi thermostats, these are a great option.
I have 2 of 7 days programmable units in my house and picked up 2 more for the other two I haven't replaced yet. Anyone on the fence about putting these in their house, I would not hesitate one bit. Especially at the price they are going for now, it is a no brainer.
drecu4x4
Did my research and got some cheap a few months back. Put them is 6 customers houses and all have failed but one during that time. Mostly inaccurate readings along with display failure.
06GMC5.3L
I must be getting lucky then...
The two I have have been going strong for well over a year now. Have only changed the batteries in one of them (the one that is on more often). The other still shows 50%.
drecu4x4
Nice. I was honestly surprised myself because in have had those kind of quality issues with white Rodgers and lux brand thermostats but honeywell's other models have given me no problems
mmpiano119
Dallas, TX
drwheels
okla. city ok
They are resetting lighting and all displays 50% off. Two different ceiling fans at more than 75% off.Two aluminum pipe wrenches 50% off.
Status
