... Steve
... SteveThink it's just a translation issue. It's a Weldon chuck and I purchased a cheap Weldon to Jacobs chuck to also go in it.Jswain, I just read the description from your link - from that - "Besides, our magnetic drill can only be used with hollow boring bits, not with annular bits."
Chinese descriptions often get lost in the "translation", but to my mind, annular cutters ARE hollow boring bits - then your comment about using an annular cutterCan you clarify what chuck(s) came with your drill?
Personally, if I couldn't use annular cutters I still wouldn't OWN a mag drill - I can drill a 1-1/2" hole thru 1/2" steel in under a minute with no pilot hole, and I've done hundreds of 5/8" holes thru 1/4" steel in under 10 seconds (each, not 10 seconds per 100)![]()
Also, the drill you linked to on Vevor's site is on Amazon for a bit less
Not sayin' I'm obsessed, but I did kinda erect a "shrine"... Steve
Mines heavy but I don't think it's anywhere near 106lbs. I can carry it with one hand, but it is heavy In that hand"weighs 106 lbs." OK, I'll stop bitching about the 48 lbs mine weighs
Jswain, thanks for the quick reply - I'm not sure I'll EVER be able to read Chinglish.
My Hougen came the same way and I added the key'd chuck adapter too... Steve
They sell them in regular Weldon shank or with a drill chuck. Get the Weldon shank version then get a seperate drill chuck w adapterfor the price those Vevors look interesting. I've been wanting a mag drill for a while, but I can't pay a lot for one since my use will be very limited. Tempted to try one of these cheap ones now. Do they take regular weldon-shank cutters? or do they have some funky mount of their own? their "specs" don't seem to clarify that.
Do you use the HSS ones or carbide? Amazon is out of most of the carbide ones it looks like.Amazon also carries Evolution brand annular cutters - I've had really good performance with all of 'em, and I really like their screw top containers - check out page 15 of this catalog
It's a LOT easier to find exactly the size you want by searching Amazon using the EXACT part # from the above catalog. I've found that often using a metric cutter can give you just enough "wiggle room" on an inch size bolt, the catalog is laid out with inch and metric sizes in the same list; makes it easy to find just the right amount of play - Oh, forgot to add that there's also a list of tap drill sizes on page 16 of the catalog.
Here's a partial selection I have, need to make a bigger holder some dayThe holder is just a scrap of 2x6 bored on a DP with depth stop set and probably 3 or 4 sizes of Forstner bits ... Steve
The only people who don’t like mag drills are the people who don’t own one!Well, I finally talked myself into buying the drill in the link; between the 27 lbs, wide speed range and finding out I had more "reward" points saved up than it cost, it'll be here about April 8-10. What can I say, the flesh is weak... Steve
... SteveI believe mine says carbide on the case but the description in the listing said HSS, so maybe carbide tipped... not sure.Wow, my "self incrimination" really woke this thread up
Somewhat in order, starting with Mr. one two - All my cutters are HSS, hasn't been a problem with mild steel/proper lube/following mfg's directions. If I ever get stupid enough to work with stainless (BTDT) I'll probably try a few carbide cutters.
NUTTSGT, I would recommend keeping a close eye on your wife; half the guys on here would try to steal her, the other half are LYING![]()
I started off using motor oil in a squirter. I bought some thread cutting oil and thought it worked much better. I bought it at Ace and is their house brand. Might be a picture of it in the last page or two of my Garage Refurb thread.What cutting fluid do you guys recommend or does it really matter?
I definitely advocate coolant versus cutting oil for this purpose. I bought a gallon of the Hogan rotamagic stuff and you mix it like 10 to one with water so it will last me forever. Meanwhile cutting oil is a mess to clean up and trust me the mag drill will fling it everywhere. Plus, it's more expensive.I've been using the Hougen rotamagic, works great plus it's water solvable and biodegradable so clean up is easy.
Great advice Steve....thank you!I use the Hougen rotamagic also, see my post#4 above - yeah, it gets a little messy but the (HSS) cutters that have over 100 holes STILL cut just as fast as new. I'm a firm believer in NOT messing with success.
If you look at my pic in post#4, even tho the drilled holes are in 1/4" material the drill itself is NOT sitting on that thin material - that surface is the flat side of a piece of 10" channel, with pieces of 1/2 x 4 FB welded to the channel then flattened smooth with a fly cutter - so the actual magnet is pulling on slightly more than 3/4" material.
Another thing the messy pic in post#4 taught me, is that there's a very good reason for magnetic pick-up tools - the floor in that area is gravel, so I keep a 30" rolling magnetic pickup tool handy; also a round "switchable" pickup tool and an air hose - I've found that for operations like the one in the pic, the easiest cleanup is to blow all the swarf onto the floor with air, then use the rolling pickup, dump that into a long plastic "trough" then use the smaller pickup tool for any "stragglers".
For jobs in thin stock that can't "come to the mountain", I have a "helper" piece of 3/4 x 3 FB that gets used BEHIND the "victim" - It can only take ONE PULL-OFF during drilling to destroy a cutter - I've cut holes thru 1/8" steel using that helper on the backside of the thin material, not so much as a twitch ... Steve
Not really, just the way it is. Anything I buy from vevor I always price check Amazon & AliExpress. When I ordered my tube bender it was almost $100 less then both(Amazon & vevor website) from AliExpress & shipped from vevor in Canada.The one in your link is $199...Vevor themselves has the same drill for $170.99? Very confusing![]()
