Maxjax Installs: Post Here
Acuratechva
Virginia Beach VA
boneccrusher, any issue with mounting that drivers side post that close to your footing. I am in the same boat you are with installing it in my 3rd bay and was told it would be too close to the footing seam/crack?
I was in the same boat. Serj advised me to do 6", which is the recommended length between holes(when moving mounting points).
Now trust me, if you are a bit big....it will be tight to squeez between the wall and maxjax. Issue i overlooked but wasn't an option due to space restrictions.
My garage is right around 12'. Its a tight fit but beats trying to lift a car with 2 jacks, several 2x4's stacked for hight, then jack stands. I wish to forget those days for ever.
bonecrrusher
Charlotte, NC
I haven't had an issue - I was about that close with my last install and had the lift there for 2 years with no issue.
monty007
For those lifting cars on pinch welds, what are you using? Mine came with the round rubber lift pads.
I also have the round rubber pads. I'm using 4 hockey pucks with slots cut into them so the pinch welds don't bend and deform the body.
I just got my MaxJax installed and was a bit concerned about the torque. My first lift was a 2015 Mazda 3 sedan about a week ago. Lifted great and level. I checked the torque this morning and one bolt was quite loose. The rest were quite good and only needed a slight turn to reach full torque of 95lbs.
How often are you guys checking torque on the bolts? Finding it a bit loose made me feel a bit uneasy going under it. I know I'm probably just being paranoid but I thought I would post up and check with the guys who have had this lift for a while.
Thanks in advance.
dflesburg
How did you figure how far in (from the garage door) to put the posts?
I am guessing they don't have to be absolutely centered between the jack points?
My cars include Porsche 914, VW GTI and late model Tundra
monty007
I just measured from the front of my garage to the back and put them into the middle. I did make sure they were parallel and the lift pads (more importantly) were parallel. I chose 125" apart. I wish I would have gone bigger like 130".
I'm lifting: 2009 Porsche 911 turbo (very wide); 2014 Acura MDX; 1998 Honda Civic (turd box) and 2012 Mercedes C 250 Coupe.
JohnnyK8
Illinois
My lift is not a max jax but is very similar (C7000). The outside of my columns are 127" just worked out that way) and the garage door to the midpoint of the posts is 10 feet. Since my post is 10 inches off the wall it is not centered in the doorway but it works.
Considering setting another series of holes(wider than minimal distance apart) for another position.
I check torque once a week and use modded hockey pucks for the pinch welds and frame cradles for my old truck.
Sent from my Nexus 7 using Tapatalk
Acuratechva
Virginia Beach VA
Can anyone think of an alternative to teflon tape?
As a cost saving measure I am considering recycling supplied jax hoses and connecting two 12 footers, only problem is the coupling would end up in the attic. None of my threaded connections are leaking now.......yet. Still not 100% comfortable with the idea though.
Anyone care to comment?
monty007
So I finally got my flow diverter and hoses installed on the ceiling. I had a custom made line made (22') with 90 degree attachments put on either end. Cost me about $100 at Princess auto for the line. My entire garage is concrete including the ceiling. I'm not happy with the way it looks but I'm happy about not tripping on the damn lines on the floor.
085fdfd03535acf907fdcc558ef78686.jpg257297ea83138e0a2e7156fc018d4235.jpg7420acd9ba36e0da8f7f8e82cdd2afb8.jpg5544d27bd310325eea6df6e5a86ca3e2.jpg
I have mounted the power unit on the wall now so that I'm not bending down to operate the lift. I have also put it up quite high in case my daughter decides she wants to play with it.
I'm hoping to one day have a beautiful looking garage like Denwood and so many others on GJ. I'm happy that my garage is at least a lot more functional. Love having the lift.
JohnnyK8
Illinois
You garage has reached the next level by a big increase. There's always going to be better but having a lift is MASSIVE!!!!
shortykorte
Tallahassee, Fl
Monty007
Nice install and nice idea of remote mounting diverter. Denwood's garage is definitely a great guide. Remember something as simple as paint makes anything go from zero to hero in no time flat.
syclone50
Just ordered my maxjax from summit racing. I have done a lot of reading and it seems that the epoxy anchors are the way to go vs the wedge ones that come with the lift.
It seems that the wej-it epoxy anchors are on back order. i have checked with several distributors and no one has them in stock. Anyone have an extra kit they are willing to sell, or know someone who has them in stock.
Thanks
Jeremy
JohnnyK8
Illinois
Check with @pilotgeorge747. He might have some
BTW epoxy is the way to go.
Grainger will have some ($$$$$$!) also check fastenal stores.
JohnnyK8
Illinois
Yep!
I used them for my C7000 Triumph install. Good luck with your drilling and setting. Measure 4 times drill once.
PDM
Coquitlam, B.C. Canada
Quick Question for those with these units...
1. How long do the arms extend ? From fully shortened to fully extended how long from the angle brace do the arms extend ?
2. What is the width of the arms from outside to outside when they are pushed "together" like when they are set up for using with the motorcycle lift attachment ?
3. Do the extensions slide in or do they have a safety latch/bolt to prevent them from "slipping" out ?
4. Can you operate the lift independantly ? (meaning in "motorcycle-mode" can you lock out the opposite side so only one side lifts ?
(sorry, I already have a lightly used Max Jack purchased but it's in storage with my other hoists - but I finally went through this entire thread and started to have evil thoughts on how I can use this unit in multiple areas in my shop I'm building at the moment...)
don
Jason280
I ordered mine directly from MaxJax a few months back. If they don't have them, check eBay.
Jason280
What's the point of the diverter? Also, what is the maximum length of hose you can use with the pump? I have all the hose I need to route the hydraulics over the top of the lift, and my plan is to hang the pump off one of the columns. I still need mine to be portable, though, as my boat and trailers won't quite clear the columns as they sit now.
Jason280
I can't remember the exact width, but I believe it is around 18-20" or so.
Yes, they simply slide in an out...my arms have a nut welded to the top, and you can thread a bolt through to lock the extending arms in place.
Yes, simply remove one of the hoses off the pump.
don
See above in red...
PDM
Thanx Jason...
I'm thinking of setting up separate mounting locations for the Max Jack to lift flat bottom formula race cars - and since they are so light (under 1000 lbs) I could theoretically lift 2 of my formula cars with a single Max Jack end to end or just do one at a time if you can simply not hook up the 2nd side.....
I was originally looking at adding another in-floor scissor lift in this area of my shop to lift flat bottom race cars - but I think I may be able to save a whack of money and just use the Max Jack in "motorcycle mode"
don
monty007
The diverter splits the flow of hydraulic fluid to the two cylinders. It also regulates the speed of the fluid returning to the reservoir.
Jason280
I don't know, can't really tell from the pic. I'm just really curious of there is a benefit to this set up...
JohnnyK8
Illinois
I have a similar system for the c7000 Triumph and after using it for a few months I can see how having the hoses off the floor would be nice. I think it's purely a convenience.
monty007
I understand that, but why not just use the one that comes with the pump?
It is because I was tired of tripping on the hoses and I wanted them off the floor. I have used all of the hoses that come with it but I got a custom made one done to move the diverter and save on having to get two hoses done versus one long one. The one that comes with it is less than 1 foot long and is meant to be close to the pump unit.
Hope all of this makes sense. I wanted a more permanent install. I'm not moving it around. I also wanted to keep things away from my daughter in case she came into the garage and started playing with stuff while I wasn't looking.
Jason280
Makes sense, its pretty much what I am doing with mine....except my plan is to leave the diverter where it is on the pump, mount the pump to the side of one of the columns, and run the hose overhead to the 2nd column. I'll leave a quick connect on the opposite side, that way I can still move one of the columns out of the way.
My only concern is, one column will basically have a hose run of less than a 3-4', whereas the other side will be closer to 20-22' from the pump. Any potential problems with this set up?
monty007
should be fine Jason. Just make sure you bleed the system several times. I have not noticed any issues with my setup. I did have to bleed about 3-4 times - long line means lots of trapped air.
As a cost saving measure, double up the 2 x 12' hoses using a proper coupler for the long side and just get one custom small hose for the short side. Will save you quite a bit of money that way.
tjc1965
Nothing to add here yet but thanks, I mostly lurk on GJ but really appreciate the ideas and advice that's found here.
Finally getting around to upgrading my barely 2 car attached garage/workshop, now that the rest of the house is done. Replacing the too-thin concrete floor, and just ordered a MaxJax after much reading and nearly going the in-floor scissors route.
Since the floor's all-new, it was a good time to do the scissors lift also. However, after adding up the extra work to raise the ceiling a bit and re-hang the garage door I decided to invest the "savings" in a new welder and better table saw instead....
Once there's something to see I'll post a few pics.
Anyone want to buy some jackstands? :D
JohnnyK8
Illinois
Lol! You'll still need them if you do anything suspension related!
Sent from my SCH-I545 using Tapatalk
Acuratechva
Virginia Beach VA
Anyone know psi ratings for SS L/M pipe? Tried googling but had no definitive info.
These seem very hard to find and ebay.....meh feels a bit sktch.
Local shop wants 30 to cut and thread a 4-6" piece...wtf.
http://www.ebay.com/itm/3-8-X-6-Thr...16-/200467119387?_trksid=p2141725.m3641.l6368
I have seen people use brass ans SS, if you have please share your source and cost.
PS : looks like schedule S/40 is rated at 3000 psi at 100 degrees....
Sp2Pilot
Vegas
Hey guys, I tried to search through this thread a bit but didn't find the exact answer regarding power.
I understand this works on a standard 110v outlet, with a 20amp breaker(per maxjax website).
Does this 110v outlet need to have it's OWN 20amp breaker, and the rest of the outlets in my garage need to be on a separate breaker?
cookiemech
West Newton, PA
I'm not going to claim this is the APPROVED method, but mine is just plugged into the nearest 120 volt outlet and it works just fine. This is on a 15A circuit, not a 20A circuit, and is not a dedicated line. Note that there is nothing else that draws significant current on that line; maybe a stereo, but nothing else.
I have used it many times without issue.
I think that MaxJax is using CYA instructions (not that there's anything wrong with that). Probably if I were installing the unit in a new construction garage, I would run a separate 20A circuit for the lift. But this is not a continuous load, and if the pump were drawing more than about 15A, the breaker would open. It does not.
syclone50
Just got my epoxy anchors installed and I am very nervous about the result.
My question is how do you know if they are set good enough?
I was going to wait 24 hours before torquing the bolts down, but if they dont spin in the whole are they good enough?
I ask because I had the typical 4.5" deep concrete so my wholes went through into the gravel/dirt underneath. I used some coffee filters to fill the void under the concrete but I dont think it was good enough. I BARELY had enough epoxy on the 10th anchor and non of it really squeezed out the top. I feel like it all pushed out the bottom into the gravel.
Anyone else had this issue and been ok?
Thanks
ymurf
Steelville,Mo
Thanks
I had the same issue on a few of mine and they held fine.
syclone50
ymurf, that helps hearing yours are ok.
I guess if they torque down then they should work?!?!!?
Is it 90lbs they torque to?
