CactusS4
Old thread, but a great one!! Just subbing, so I don't lose this great resource
I added some pads to avoid door dings... need to add another set at the common lift height and an additional set of holes for the safety rods.
What are those pads and where did you get them? I like that idea. I thought of using some pipe covering or something but that would look pretty ugly.
Steve
Steve,
I got them from Griot's Garage... only to notice that I overpaid for them... can be found, in yellow, on ebay, for a lot less...
http://www.ebay.com/itm/Complete-Door-Defender-Car-Garage-Protection-Pad-Set-/360381727408
or Black
http://www.ebay.com/itm/Lot-2-Corner-Door-Defender-Car-Garage-Protection-Pad-/230404158265
Now that I think about it... I could have used one of those pads my kids have in their room... cut to size and glued to the tower... The space between the lift arms assembly and the tower is not much, so you can't put a pad that is too thick or the arm will rip it off when lifting the car. Just fyi. These are a tight fit... I put some white grease on them just in caseSo far, so good...
Perfect! Ordered a set in black. Thanks!
Steve
Nice engineering job Andy.
You'll never have to worry about whats under the concrete where your MaxJax is installed. Your baby will never be at risk.
Do you still have the supplied anchors?
Andy, or Alex?
I'd be more worried about the MaxJax failing than the installation failing.
What prevents it from dropping down before I have a chance to install the safety pins?
Still in the box. They make a good paperweight.
I have a question. Assuming the installation is secure, does it matter how the car is positioned fore and aft relative to the posts?
I've had mine for 2 years and the only complaint is that sometimes I've had to shake the car to release the lift from its maximum height.
The only way it would drop is if you had a major hydraulic leak.
Maybe you could sell them cheap? I might be interested.
Wondering why.
Are your columns aligned front to back and at the same height?
Are the columns vertical using a level?
Are the sliders greased?
Cylinder binding because you had the pump running at full extension?
Such as a hydraulic cylinder failing or a hose letting go.
I'll be in MTL end of February.
I was at a car show here recently and spied these very nice adjustable jack pads. The distributor promised to send someone over to my home to see if they have adapters that will fit the MaxJax.
On this topic, Jose in Bogota is making some offset pads that look very useful, too.
Andy
I think that mounting system falls into the category of "that **** ain't no joke". Well done.
Steve, there is nothing wrong with anchors. They are used in commercial installations without issues.
I had this home built and if I would have known I was going to install a lift, as a minimum, I would have poured a 6 inch reinforced slab in the garage.
In fact, MaxJax does specify a reinforced slab amongst a slew of other we are saving our **** against a lawsuit instructions.
I'm just following manufacturer's instructions and they are based on design. It does matter if you want a more securely planted vehicle on the lift while you are working on it.
Interesting, I have not read anything in my manual about a reinforced slab???
Incidentally, I assume you are using the Porsche jack adapters? I need to use them as my car is very low and the square Maxjax pads will foul the rocker covers. The pegs will lock the car even more securely on the Maxjax pads. Here are what I use.
You have a a very secure footing!
Andy
Thanks, Alex. It seems to me that the critical positioning issue is centering the COG between the front and rear lift pads. This is a not an issue with Porsche 993s on, as these models already have the factory designated lift points. Once the car is lifted on these four points, it should be securely planted, regardless of where the posts are relative to the car. I lift my car without regard to the posts, but do try to get even arm extensions.
Who makes these pads and where did you get them? Anything that will crawl under a Porsche is a good thing!
I wonder where the CofG on my 996 GT3 would be though.
I used the same custom anchoring as "In my Garage" did and I feel more safe under the car. I would recommend it to all new maxjax users.
Can you post some photos. I'm curious how you went about it.
There may be issues with having the COG closer to the front or rear arms, thereby inducing some torsional stress (the rear or front arms will be carrying a heavier weight), but the resulting problem would be the more heavily weighted arms bending more than the other set or the columns twisting toward the heavier end. I think (or hope!) these structural problems are unlikely, particularly with the relatively low weight of our cars.
If the lift is well made and secured, the more relevant COG issue in my assessment would be what I first mentioned above. This is all theoretical discussion, very interesting to me, but I appreciate your OC approach to this. I am much the same.
By the way, I have 120” between my posts, measured from the outside of the bottom plates.
Andy
Andres
I see a strange blue creature on the top picture. Why is the jack not red ?
Andres
