wolfsburged
How can I map out my rebar before drilling? I tried using my stud finder and it did not like the concrete.
Don't worry about it...just pick up a rebar cutter by Relton or Bosch of the correct size.I hit rebar in 3 holes when I put my anchors in....cutter made it easy-peasyHow can I map out my rebar before drilling? I tried using my stud finder and it did not like the concrete.
I think I paid $15 for my Relton on Ebay. Another piece of advice.....DO NOT step drill the holes....start out full size and get the proper size hammer drill.Let it do the work. I think Bosch "Wild Bore" bits work the best http://www.amazon.com/dp/B0000TZY0C/?tag=atomicindus08-20 good luck!Buddy I'm doing my installation right now and running into similar challenges.Ok, I have my SDS drill borrowed, my SDS 7/8" bit and my SDS 7/8" rebar cutter just in case.
Planning on drilling these and installing this weekend.
They included the epoxy anchors as a no-cost adder when I purchased.
I skimmed through this and the other Install thread and saw a little discussion of this, but for my own re-assurance I will ask again.
My test hole came out pretty smack dab at 4" thick concrete. The supplied Wej-It PS2-58 anchors are close to 6" long and indicate a minimum hole depth of 6-1/4". I called Danmar prior to purchase and they had indicated to just put something under the hole to keep the epoxy from leaking out entirely. There are four "nubs" on the anchor, and it appears that from the top of the anchor down 4" will cover only two of the four "nubs". Am I over thinking/worrying about this too much? I don't want to have to cut and repour concrete if I don't need to, but this does seem out of the range of the Wej-it instructions.
Nice!I got my holes drilled and epoxy anchors in today. Hit rebar in half the holes. Luckily I had ordered a Bosch SDS rebar cutter which worked great. Luckily one entire post was over 6" concrete which was much thicker than expected. The other post was 4", and installed the epoxy anchors with coffee filters. Being overly cautious and waiting 24 hours before I try to torque any of the anchors. Got all new hoses and fittings from the local Parker store on Friday but paid dearly for the convenience. Put all the hydraulics together with Loctite 545 so also waiting 24 hours on all that to cure. Got some AW32 hydraulic oil. Hopefully will set posts and bleed hydraulics tomorrow or more likely Monday.
Nice job man. I'm getting some new footings poured soon. I could push all the old ones thru but I am a little suspicious of some of the anchor embed mentioned.Got it finished today, everything went pretty smooth. Took a while to get the 35' hose side bled vs the 10' hose side. Still a tiny bit faster up on the shorter side, I keep getting tiny bits of air out of the slower post so I will keep at the bleeding but only about an inch off by full height so not too bad. All anchors set fine, had to shim three bolts with 1 shin each on one post, and 2 bolts with 1 shim each on the other. Posts are measured and verified parallel. Lift arms are perfectly level front to back. However left to right on pads are about 1/2" off due to concrete. Thinking that I could just make a half inch spacer for under the lift pads for one side to compensate, anyone else run onto this?
I am working on setting mine up as well. I have to pick up some new anchor bolts, but I just had a question about a discussion I had with an engineer. He argued with me that 2 bolts in the concrete would be structurally better than all 5. His claim is that the 5 bolts would weaken the surrounding concrete. Now I completely do not agree with that, as I'm sure dannmar has a lot more R&D and testing regarding this and knows better than this nut, but I just wanted to get your feedback. Thank you!
Did your "engineer"
Use epoxy anchors to help reduce that riskbought mine last December from home depot and just now after finally getting my slabs done. My floor was only 3 to 4 inches thick so i did a 3x3 hole and one and half foot deep footings... now I'm ready to drill for the anchors but a bit worried as to most people saying some wont set in or lock in correctly.
yes I've seen the epoxy type are the most popular to use but a little messy...![]()
ThxYou are supposed to REALLY clean the holes by using a brush, blowing out with compressed air, vacuuming, repeating, etc. Once they are really clean, use the epoxy, and smack them in with a hammer (obviously you are smacking a bolt that is threaded into the anchor). A tight fit is good. You can and should do trial fits; you can fab a method for pulling the anchors back up, since ideally they don't just drop in.
If you use the correct drill bit, yes, it will be a tight fit.
The drop in flush mounts do work well but these epoxy drop ins reduce the tendency for the concrete to crack or spall and also "bite" into the concrete better. Many folks have trouble getting the wedge to set properly and that allows the anchors to spin in the holes.One question I have which is probably silly....these type drop in epoxy anchors with sleeves are used so the posts can be moved often and when needed correct? Normal much cheaper concrete wedge anchor blots aren't advised because once you put those in...you can't take them in and out correct? I know wedge bolts have an extremely high tensile strength...well above the needed strength for the lift. I was just wondering why these type aren't used by anyone. Thanks guys!
Plus 1 on this.Rubber gloves and a tub of wheel bearing grease...be generous...it makes a real difference in how the lift operates.Make sure you grease up the channels.
Have fun! Good job!
Sent from my SCH-I545 using Tapatalk
