What does this accomplish?When installing radiator hose, I use Permatex Aviation Form A Gasket #3 on the inside of the hose
I use a piece of electrical tape for that job.if you need to hold a nut or bolt into a socket ...a scrap of newspaper /tissue over the head then fit the socket works like magic
I like to put bolts back into the hole they came out of if at all possible.I like to put my bolts to different components, in sandwich bags, and label them when doing big jobs.
I'd say the larger point is to pay close attention to the condition of the hoses, clamps, and the fittings on the radiator and engine, and to make sure you look closely at the underside of the fittings with a mirror or whatever to catch any hidden corrosion or damage.When installing radiator hose, I use Permatex Aviation Form A Gasket #3 on the inside of the hose
Shade tree mechanic here so this may be old news to the pros. When dealing with an older car, especially one new to me, if I find myself at a loss to understand a problem, it helps to consider that there may be two broken/defective parts rather than just one. Isn't common but it has happened more than once. This is especially true when dealing with vacuum leaks.
Always assume you'll be the next guy to work on it. If you dont, its 100% certain you WILL be the next guy, and get to deal with what you left for him.
For example, had to put a wheel bearing hub in a Chrysler 200 yesterday for false ABS activation. Between the Hub shocker and a 498 air hammer, it took about 5 minutes to coax it out. Before reinstalling I took my carbide burrs to the inside of the knuckle to remove as much rust as possible. Hub slipped in easily with tons of grease everywhere. Hopefully the next guy will have an easier time than i did.
Only way to do it in the rust belt. I use a 2.5lb hammer to beat brake pads out of the brackets when I replace them. Sometimes it takes more than one hit!It's amazing what a little fore thought doing a repair now and putting in a few extra moments to apply some silicone lube to a slide pin, grind down the caliper bracket and apply anti-seize, anti-seize behind a rotor hat, grind corrosion from center wheel hub to make sure it torques down secure and evenly makes things go smoothly later. The quality of the repair is much greater when you take the required time to do it right.
I did the rear brakes on my wife's car a couple months ago, which we bought used. I was very pleasantly surprised to find liberal use of anti-seize and grease on the slide pins. Hardest part of the job was getting one of the wheels off. I was expecting a fight.It's amazing what a little fore thought doing a repair now and putting in a few extra moments to apply some silicone lube to a slide pin, grind down the caliper bracket and apply anti-seize, anti-seize behind a rotor hat, grind corrosion from center wheel hub to make sure it torques down secure and evenly makes things go smoothly later. The quality of the repair is much greater when you take the required time to do it right.
There's your problem.split washers are worthless - use the right kind of locking chemical
the top sentence is based on some new info - engineers actually measured split-washer function several years ago
I clean off the pointer and harmonic balancer where you shine your timing light super clean and put on different colors of reflective tape to see the strobe reflection brightly even in full sunlight. I put the reflective tape on with high precision by locating top dead center accurately. The first time I used a dial indicator graduated in thousandths of an inch and a helper for precision, but while doing that and having made a precise mark I tried out a super easy method that proved to be just as accurate and didn't need a helper watching the dial indicator. I used clear tubing on a spark plug hole (leak down tester or even a tapered rubber stopper with the tube) to a clear glass jar of water in front of my face as I turned the engine ever so slowly from below while watching the flow of bubbles on the compression stroke. As the bubble flow slows as it approaches top dead center, I continue ever so slowly until I see the last tiny bubble and then make my mark for precision timing mark made with two colors of reflective tape -- one for advance and one for retard.They make a TDC whistle adapter, with a rubber cone on it for the same purpose. IPA tools. You can also just throw a leak down on it, when you meet resistance, youre coming up on tdc.
Like freeze spray sold to janitor firms for chewing gum from carpet removal?Using a can of key board cleaner to loosen rusted bolts
Sent from my SM-G973U using Tapatalk
#1 thing I took away from My schooling.... The pen gets you paid "Found bad Wire, repaired" IS no where as appetizing as every circuit you tried before getting there written in a paragraph or more..My buddy, who runs his own shop, reminded me of one. If you wrench for a living, your pen is your most important tool. Whether to explain what needs to be done or what's been done and why, to either your service adviser or customer depending on your situation. (Of course in more digital shops, the pen may be replaced with a keyboard.)
Explain??Electrical Tip.
Trying to track down short circuit? Replace the fuse with a light bulb and proceed.
The bulb will light. When you find the short and remove it, the bulb will go out.Explain??
That, and the bulb limits current. Say a typical test light is going to pull .250amps max, a tail lamp bulb 2 to 2.5. If it's a dead short, this is a lot easier. All you need to know is that current can flow to ground. The fact that a 20amp fuse is popping instantly is irrelevant.The bulb will light. When you find the short and remove it, the bulb will go out.
The GM trucks when replacing the alternator,don't use a hammer on those steel sleeves on the mounting bracket.Get a 5/16 bolt,2 1/2 to 3 inches long,a shallow 16mm or 5/8 socket and a nut.Put the head of the bolt toward the rear putting the socket in and the nut.Tighten the nut up watching the sleeves move just enought to get the alternator in.Learned this from youtube subscriber How To Automotive and it works.
Don't have magnetic sockets,put a small dab of grease in the socket
There's one thing I started doing years ago, when I used to work on a lot of cars with friends who didn't always think things through before acting. I purchased a spare rubber wheel chock. Every time I drove the front of a vehicle up service ramps and chocked the rear wheels, I put the spare wheel chock on the floor of the driver's seat next to the pedals. That "reminder" kept anyone from absentmindedly trying to drive the vehicle down off the service ramps without first removing the chocks from the rear wheels when the work was finished. I still do that to this day.
I always keep a small collection of decent quality used pliers sourced from garage sales on hand. Any time I encounter a situation where custom ground plier jaws or custom bent plier jaws would make a job a lot easier, I either make a pair right then or I make one after the job is finished so I have it for the next time I encounter the same situation. Those are some of my favorite pliers, and they usually end up being useful for multiple other tasks as well.
I make small laminated cards for every vehicle or piece of equipment I do regular work on. The cards include all the common info needed for general maintenance. Oil drain plug bolt size/torque, wheel lug size/torque, brake caliper bolt sizes/torque specs, brake rotor minimum thickness, grade and amount of oil for each oil change, oil filter part number, wiper blade lengths and part numbers, headlight and tail light bulb part numbers, etc. I keep those cards in the glove boxes of my own vehicles, or in my shop. For small equipment like my lawnmower, I have info like the blade bolt torque, spark plug gap and spark plug part number, spark plug tightening torque, oil type, oil fill capacity, oil fill plug/drain socket size, air filter part number, etc.
I keep a small spray bottle of water with a tablespoon or so of baking soda dissolved in it on hand. A light spray quickly fizzes away visible corrosion from battery terminals, battery clamps, or the battery tray. It also allows for better inspection of battery wire strands. I usually spray battery terminals about twice a year to keep them looking and working good.
Lastly, I always put anti-seize on the surface of a brake rotor that rests against the hub. I spread a tiny finger dab across the entire surface. The metal surface basically just looks damp and sparkly. If I can visibly see anti-seize there's way too much. The super thin coating prevents the anti-seize from ever migrating onto the brake rotor surfaces over time, but it's enough to prevent the brake rotor from sticking to the hub when it's time to change out the brake rotors.
This is the video l seen,You can also just take a roloc disc or cut off wheel and grind the sleeve flush with the case. Itll pull in when you tighten it. Always be careful trying to press those on a spray-n-pray reman as it might be seized.
I know this is an old-ish post, but this is something I first saw in the writings of Rob Siegel in the BMW CCA magazine ("The Roundel")2. "When you see hoofprints, think horses not zebras". (ie start your trouble shooting with the most likely pareto of possible causes and work your way down the list.)
I have several circuit beakers with wire leads, heat shrunk and took the spades off burnt fuses and soldered to the ends, they have seen much use.That, and the bulb limits current. Say a typical test light is going to pull .250amps max, a tail lamp bulb 2 to 2.5. If it's a dead short, this is a lot easier. All you need to know is that current can flow to ground. The fact that a 20amp fuse is popping instantly is irrelevant.
Circuit breakers are nice as well.
Some aspects have already been mentioned here.Explain??
