MIG Pliers
Wamsutta
Amarillo, Texas
The last thread for MIG pliers was 2018. I checked.
It's the nozzle that I need them for. Which brand cleans the nozzle the best?
whateg01
doo dah, kansas, usa
Nothing to compare to but mine from tractor supply 15 or 20 years ago work well. They look exactly like these except with black and yellow grips.
goldtang
Western Australia
not sure how long I have had these but I think they were about $20 (aus) , boss mig pliers
Terra Nova
I have the Channellock 360 MIG pliers and am 100% satisfied.
danielbuck
the nickle plated nozzle's that came with my Lincoln 260 give me the opposite problem. I'll be welding, and then the ring of spatter on the inside of the nozzle will just fall out into the weld puddle. :LOL: To get around this, I'll bang the side of the nozzle on a leg of the welding table to knock it out every so often.
I like the strong-hand mig pliers, I keep one of them chained to the welding machine, and the other loose on the welding table. But I've used several cheap mig pliers as well, and honestly they all seem to be about the same to me, at least so far as how they function. If you have a favorite brand you like, pick them up.
NUTTSGT
Northern Central Ohio
I bought a pair of Irwins because I probably got them at Menard's or where ever I was at the time I needed a set. They're okay but I'm digging those CL pliers.
imagineer
Honestly, I've got a pair of the cheapy HF MIG pliars that work just fine.
Had a coupon so got them cheaper.
Same here, 3 pair. I have a 1/2" conduit strap affixed to all 3 weld carts for a place to keep them.
dr_clyde
Holland, MI
I use the Pearson or Anchor YS-50. I'm pretty sure the Pearson Welper was the original design.
I had the Channellock ones and I gave them to my dad and went back to the original Welper. I can't remember what I didn't like about them, but something bugged me enough to give them away.
PCustoms
VT
I think mine are Hobart from tractor supply.
Can't say they make me a better, or worse, welder so it's good enough for me.
ALinCarolina
NC Piedmont
Mine are the ChannelLocks and are ok but what I don't like is that the cutting area doesn't work when the wire is far back deep in the cutting area.
JradM
Alberta
Why don't they cut at the back of the jaws? Do they have a hard wire cutter there?
MoonRise
Had/have some HF ones, they work OK.
But they are a little roughly finished and just plain black oxide-ish.
So saw and picked up some plated (nickel?) Lincoln ones. Lincoln Matador IIRC. Looks much nicer, smoother action on the pivot, much nicer fit and finish than the HF ones. So I use those ones now. The HF are stuck in the drawer as back-ups or 'loaners'.
Gutman
ENC
I found a nozzle reamer like this is useful to clean deeper within the nozzle. Don't recall how I found it, but you can google them. Think I paid 6 $.
finn
The UP, God's country
Mine like that is from HF. Another fail, as the plastic broke during the first use. I disassembled it and reversed the plastic, (I think) and it functions again.
My original pliers were no names from Farm and a fleet. I bought a pair of the Channelock brand at the Miller booth at the Iola swap meet that are a little better, but both do the job. The Channelocks cut better, but that could be an age thing.
W
Wamsutta
Amarillo, Texas
I've been using one half of a pair of nose pliers to pull the slag out of the nozzle. Sometimes that works and sometimes it don't.
All I know is I need something better for cleaning the gas nozzle.
W
Wamsutta
Amarillo, Texas
All the MIG pliers look like they got itty bitty handles. Why tool manufacturers put such small handles on their pliers is beyond me.
ATC
VA
I have the Channellocks, a no-name pair, and nozzle dip. They all work well.
scooby074
Nova Scotia
Itty bitty? Youre trying to snip 030 wire or unscrew a tip lol. You could cut the wire w with scissors if you wanted. Of all the complaints, handle size never crossed my mind.
JradM
Alberta
If you find the handles too small, the Channellock pliers are also available with their "Code Blue" comfort grips. My personal preference is generally comfort grip handles on > 6inch pliers and dipped on anything larger. I don't want small handles, but I don't like having to stretch either.
Steve_P
I have the "original" Pearson Welpers, made in Japan; they're great. I bought them 10+ years ago, before the Channellock welper was made, and they were hard to find online in the US at that time- I think I got them from Amazon Japan. Strangely, the Channellock costs about 1.5X what the "original" do on Amazon.
FigN⋅m
I get that they aren't directly answering your question, but sheesh.
All of the above will work fine. There is no M18 Fuel rotary nozzle cleaner (yet),
These options are the current standard formula, so pick you favorite handle color and go for it.
I can't help but feel that the weld prep itself is possibly contributing to your issue?
Also don't wait until the nozzle is super choked - ounce of prevention and all that...;)
Ericmacc
MN
I’m a full time welder. That’s all we use. They clean the nozzle really well.
