You can make a pusher tool out of two bolts close to the hole diameter and a rod coupling of the same thread. Run both of the bolts onto the rod coupling and cut the head off of one bolt. Slide that headless shaft into the hole and use two wrenches to undo the top bolt from the coupling. This will put outward pressure on the pin. Spray the hole with a penetrating lube first. Be gentle and take your time. Good luck!
