Motor rated cord ends.
sparky 1971
Central Iowa
Commonly found, yes. For 3 HP and smaller. 5HP and up, not so common. In fact, I don't recall ever using one and my career goes back to 1994.
Norcal
The Hubbell 60A 240V pin & sleeve interlocked receptacle for a welder is rated for 7.5 HP.
D
Dagny
Northern Wi.
single phase I have 12 3hp fans to wire and thought plug and recep. would be cheaper than disconnects also makes service easier.
Norcal
mike93lx
Richmond, VA
How often is service really needed? If it's stationary, I'd just use the disconnect that Norcal linked. It's done every day for a/c condensers.
alfredeneuman
Fullerton, CA
https://meltric.com makes motor rated plugs and receptacles, but I've never actually seen one in the wild.
Walmart sells them...but check out the prices.:eek:
A pretty strong case for Norcal's disconnect.
The plugs and connector bodies even require a proprietary separately bought cord grip as well.
EDIT: I don't know why the link says robot or human
D
Dagny
Northern Wi.
yeah I thought about the ac disc. but they just seem kinda chincy use them for water heaters an such but not in ag buildings
Norcal
I prefer safety switches over pull out discos, just not the price difference.
mm08822
Is each fan on its own ckt? What about using cb locks? What is the environment these fans will be in?
