MP&C Shop Projects
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Robert....I went back and was looking through the thread with the Fairlane and I have a question. On the sail panel where you repaired everything, you removed the factory lead from the seam. Do you replace it with lead, or do you remove it all together and use some sort of polyester type filler? Maybe I didn't read far enough down to see it.
K13
St. Albert, AB Canada
As I've been over-exerting/exceeding the capacity of my 20 ga apron brake, I think that will be replaced with a new machine. Either going with a box and pan or a magnetic brake....
Those Baileigh magnetic brakes are getting rave reviews from guys that have them. I have seen posts on various sites from 4 or 5 different guys and they all love them. Shane is a super good guy to deal with as well.
MP&C
Leonardtown, MD
Given the rust that occurred from the inside of the roof, I wanted to insure there were no other issues hiding under the lead. I removed all of it, and filled those "lead valleys" back in with marglas.
MP&C
Leonardtown, MD
OK, so I was bored this evening. I have a louver die set for my Lennox that was originally ordered and sized for .09 aluminum. Tonight I thought I'd try them out on some 18 gauge CRS to see how well it performed...
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Robert...you have me lost. This isn't what's cutting the louver, but what does this do? That part with the handle I mean.
The louvers don't look like it distorted the metal at all.
nine4gmc
Dallas
Kevin, if I'm looking at it right, the die cuts straight and the thing with the handle can be swiveled right to finish one rounded end of the louver, then left for the other side after making the straight cut the length you need it. :beer:
MP&C
Leonardtown, MD
^^^^^ Exactly.. Kevin, here's some pics of the upper die....
The process normally uses a couple passes, one to do the initial slit/cut, with subsequent passes made deeper to form the louver. After the final pass, then the handle is swung to the appropriate side on the ends to "coin" or crisp up the detail on the sides..
NASTYZEN
St-Colomban,Que. Canada
Performs darn well Robert. You **** for having that Lennox.
I thought there was only Pullmax that could do that kind of work.
Show us what else that machine can do!
:beer:
MP&C
Leonardtown, MD
:beer:
The Lennox was $1000 from a DC9 maintenance facility that Northwest Airlines was shutting down at Atlanta airport. Couldn't let it pass up for that....
Here's another fabrication done on a roof repair panel...
Time to make up a die to form the roof repair panel on the Lennox. First to make a profile template.....
A sample piece of 19 ga is run through and test fit alongside the "model" car.....
It's real close, but I want to tweak the dies to see if I can get it a little closer
The first sample you had a tendency to flatten out as you progressed to the end, rather than maintain the same radius thoughout. Per the guys at metalmeet I needed to chamfer/radius the coming in and going out of the dies, and by passing it in and out at a slight angle, it would remedy that.
I ran a piece through and "levered down" on the panel as suggested. This does seem to help in carrying the pattern more consistently throughout the length. Then I tightened up the setting just a bit more....................................and judging by the metal waving at me along the top edge, and the marks on the dies, I have some more relief work to do as it looks like the wrong side is tight........(actually planished the top edge and stretched it)
That upper part on the roof is the side that should be shrunk slightly, so I'll give these dies another whirl. I adjusted their shape and set them up in the machine and checked them with feeler gauges, still needed more taken out. Once more was enough, and I polished out the surfaces a little better this time using a scotchbrite pad on the grinder.
The repair panel came out much better this time.....
MP&C
Leonardtown, MD
Well, we had a good streak going, but it was bound to happen sooner or later. Had another bus panel that needed replacing & painting. Today is about 75 degrees, low humidity, what more could you ask for.....
And with this repair, we have used up the rest of the gallon of yellow, so the next bus incident will require new paint!
MP&C
Leonardtown, MD
The other task for today was to fab up a welding fixture for making various tooling for the Lennox.
Next on the list will be to make some generic dies holders.. in 3/4 wide (plywood), 1" (small sheet of phenolic on hand) and 1-1/2 (for the Delrin). I need to continue the rust repair of the 55's upper gate onto the outside skin, which will require duplicating the beltline feature. Something tells me these die holders will come in handy...
MP&C
Leonardtown, MD
Thanks Mike!
Well there is more forming work on the horizon for the upper tailgate, so today I made a road trip to DE and picked up some 19ga CRS as I was fresh out. Dropped off a few sheets in Frederick and brought the rest home. Most was cut into 2' x 4' sheets, as that is plenty big for most of my patch panels, and a few were left in 3' x 4' for some possible hinged hoods/hood sides.
36racin
Gonzales, La
Robert,
You have got to stop posting threads like these(just kidding). Absolutely amazing what you do. I wish I had 1/10th of your skills and a few of your tools too!!! If you were not so far away I'd be waiting to see your skills on my body work. I'm sure there are body men(and women too) closer to my location with your skills. Just finding that person is the problem.
Thank you for taking the time to post your work and projects. We all enjoy seeing the new additions so we can learn alittle.
Todd
MP&C
Leonardtown, MD
Thanks for the comments guys...
Larry, still going to be in NOVA?
Got my care package from TP tools on Friday, so spent a few minutes installing the new glass....
Is there any wonder I couldn't see what I was doing?
Then I used the welding fixture to fab up some Ron Naida inspired insert holders for the Lennox...
Next will be to make some inserts to match the contour of the rear lower edge of the upper tailgate..
MP&C
Leonardtown, MD
The new one has a protective film applied on the inside, came that way. The last one it was an option and I didn't get it. looking through this one, the film does add a wavy distortion to the view. If it was still an option, I probably wouldn't get it just to have a non-distorted view. The last one was a good 5 years old... The "glass" is tempered glass..
36racin
Gonzales, La
Robert,
What kind of media do you use in your cabinet? Just purchased and installed a used Trinco 30" Dry Blast cabinet and vacuum canister yesteday. I was thinking glass beads and not sand. Any suggestions? I have access to a portable sand blaster for heavy corroded items.
Going to replace the glass on front and under the light on it as well and reseal everything. Clean out the vacuum canister and get new media before I start using it.
Todd
MP&C
Leonardtown, MD
Todd, I buy it from a local machine shop, they get it by the pallet load...
Keep in mind that for a machine that recycles from the hopper, the more you put in there, the more weight and compaction, the harder it is for the siphon to pick up the media. Hence, I normally use only about 1/4th of a bag, if that...
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Humidity also makes a difference. If your media gets damp, it won't want to cycle through the blaster. I make sure that if it's really humd, I won't leave the lid or doors open.
We had a great blaster at work, but in the summer, the humidity would just kill things.
ihredo4
100 miles W of Daileyville in Idiotnois
WOW For someone who tries to metalwork and makes scrap what you do kind of makes me sick. Sick of looking at my failed attempts that is. LOL AMAZING work my friend. You talk your way thru the process like we can all replicate what you are doing. I think I can, I think I can, I think I can but KNOW I CAN'T! Thanks man for sharing your knowledge. Its truly inspirational.
36racin
Gonzales, La
Thanks for the help with the blaster guys. This one had been neglected. The media hopper had a 5 gallon bucket of media in it along with alot of big debris and trash. And the vacuum canister had even more dust in it than that. I'm going to give everything a good cleaning, repair what broken then give it a whirl. I was told the regulator was bad so I'll check and replace that as well if its bad. Should I put a water trap just ahead of the regulator?
Thanks,
Todd
MP&C
Leonardtown, MD
The other consideration for a media cabinet is to make sure you have enough compressor to keep up with the cfm consumption of the blast nozzle. If the compressor is too small and constantly running with little chance to cool off, it will put out superheated air, generating even more moisture in the system.
rshadd
Doylestown, PA
I just spent the last two and a half hours reading this thread from the beginning. I'm fascinated at the high level of craftsmanship and all the attention to detail. Thanks for taking the time to explain and show how metalwork is done by a true master. Love all the great pictures.
36racin
Gonzales, La
Robert,
I recently purchased a used Sandborn Black Max 5hp 200 psi two stage compressor. Not really sure of the cfm's of it. Can't really find any infor on it. I'm thinking it should handle quite well.
I saw another GJ thread about air line systems and will install using some of the methods I saw on it for my shop. Trying to get shop in shape to get my car rebuild going.
Todd
MP&C
Leonardtown, MD
Well I got a phone call yesterday (Thurs) from FEDEX letting me know I had a package showing up today at their freight depot... the new brake from Baileigh! On the way back home from picking it up, I remembered I need to make room. One phone call and the old brake was sold, with a truck on the way. Here we are, home safe and sound....
Brake extraction device....
The new owner had shown up in his truck before I even got it to the door....
....and in with the new...
This even gives me a bit more space so I can upgrade the 137L to a larger shear that will cut 48" wide... maybe next year..
I did get the power connected and a small sample bent, but didn't have much time to test it out as we had a Blue Crabs baseball game to attend this evening. More to follow....
