M.Brane
I remember many years ago walking into the Ford dealer to get one of those for my Ranchero. Before I was done describing what I needed the parts guy had one in his hand.
I know a guy...Other than that, find someone with a slip roll.
Larry, you can bump a curve that size pretty easy. That is how I did the fenders for the rolling tool bench- 1/8" x4" flat bar. I just clamped a piece of angle to the bench frame and bent it by hand.How would you go about manually bending a 1x3/16” flat steel bar into a hoop with 22.5” inside diameter without a roller? Bbq project for a friend.
Take your time, and use a radius template to ensure you don't overbend it. I would do it in two halves , calculate the diameter thru the neutral axis and trim each piece to half that length. Allow an extra 4" on each end for the flats that get trimmed off.
Sorry for the thread hijack, Robert. We now return to our regularly scheduled excellence.Sorry for the thread hijack, Robert….
Robert, any update on the wagon? Is the milk truck still in the queue?We went to the show about three years ago, very impressed. Even got in a tour of the plantation while we were there.
Looks great, I weld a piece of rod stock to bend the sheet metal around.Thanks for the comments!
And here's the benefit of posting pictures online of your work. Ted (tb33anda3rd on the HAMB) had seen pictures of the rear fenders and reached out to see if we needed any other parts. He put me in contact with someone who had an original tail pan. It has a couple of minor repairs, but for 93 years old was pretty straight and solid, much better than the ripped sample we had.
The smack in the rear end didn't bode well for the exhaust hangers either, the rubber isolators had ripped
So the hangers were replaced and the tailpipes pulled upward a bit so we could add some relief openings for a more finished appearance.
This "anvil" was fabricated to add the cutouts in the tail pan. The notch provides relief area for the side flanges while hammering the opening.
For the long chrome tips, I think this makes it look more finished and less an afterthought.
We turned in about 5/16 to add some strength across the opening. Still needs a bit of fine tuning.
We had the tail pan and two fenders media blasted to get a better view of what we had to work with. Both fenders were bent up, although the drivers side took the brunt of it. There were some previous repairs to the running board attachment area that we'll address while we're here. These pics are after some hammer work to rough out the damage and get a better sense of where to proceed.
You are reading my playbook!Now all I want to do is get to retirement so I can build a few more cars while I'm above ground.![]()
