My Beacon Morris install
92nsx
Minnesota
Just wanted to share my install to give others ideas or motivation to your garage's heated. :thumbup:
I went with the Beacon Morris 75K in my detached garage (22x45 with 12'8" ceiling). I have had great luck with them. First one I installed in my attached garage 7 or 8 years ago and zero issues. This is now my 5th unit installing (helping friends install there's) All ZERO issues).
One friend bought a Mr.Heater 80k unit.... Guess what nothing but problems. After the 3rd fail (2 different sensors, then the circuit board took a ****) he returned it and bought the BM like I told him to start with. :thumbup:
Ran the gas line and electrical to the aprox location I would be installing the unit. ( shout out to Amcrest WIFI camera's, they work great :rocker: )
First get your self a sheet rock jack. Makes the job 1000 times easier. They can be bought cheap on ebay or just rent one. I bought mine for $120 shipped, and have used it quite a bit.
Escalade works good if your to lazy like me to drag out the extension ladder :lol_hitti
From there it is pretty self explanatory. Hang unit, cut hole for exhaust, hook up gas and electric.
Last I went with a Honeywell WIFI 8000 thermostat. Side note if you need a "C" wire for your thermostat (most if not all wifi or smart thermostat need it to power it up). It is there on the circuit board in the unit just isn't hooked up. Take your self a white piece of wire and run it from the board to w2 terminal on the back side of the unit (W2 isn't used).
danbuff
Western NY
Pictures???
I am installing a 60k unit now.
Built a makeshift 'shelf', then hoisted to the shelf with a H.F hand winch and pulley attached to upper joist.
Planning the hole cutting now.
Thanks for your feedback on the Beacon Morris line
92nsx
Minnesota
The pictures didn't show up for you? Ugh. :-(
Ill post the photobucket photos in the morning. Hopefully everyone downloaded the fix/mod so they show up.
TTA89
New Hampshire
Use flickr instead.... Photobucket is dead....
My 120K BM is getting venting tomorrow, can't wait!
92nsx
Minnesota
Sweet! Awaiting pics. Planning on going with a BM 45k...
Hopefully you downloaded the photobucket fix / plug in. I Changed the photo's in the first thread.
120k! That's a big unit...(that is what she said :lol_hitti)
Ya bucket is dead. However my Garage or as I call it "Shed" has been in progress the last 3 years and that is where all the photo's are at. Would be a PITA to have them in 3 different areas.
I wonder if one of the hoisting places has a way to transfer photos:headscrat
All 252 photos are here form start to finish. Along with a few more to come. The last set of indoor LED lights should be here today.
http://s212.photobucket.com/user/92nsx/library/Baja Shed?sort=3&hotlinkfix=1508933577897&page=1
92nsx
Minnesota
This ^^^^^ Same thing I did. works great.
Yes I have a Flickr account. The only Photos I upload to Bucket is on the Garage so they are all still in the same place. Nice to use the story option when sharing the complete build. Start to finish.
D45
NW INDIANA
Pictures???
For the hole in the roof, I just hooked up the vent elbow on the heater and hung a plumb to find the center of the vent hole
I marked the hole and drilled an 1/8" bit up through the roof. I then got up on the roof and cut a 6" circle around the bit
Here is my install of the 45K heater, which I just recently switched out to a 75K, I did everything myself from the electrical, to the heater install, to the gas pipe, to the venting. No issues.
https://www.garagejournal.com/forum/showthread.php?t=325943
danbuff
Western NY
Very nice install... Looks better than professional..
My vent is going thru the side wall.. Metal siding..
I picked up a pipe boot for the vent pipe.
The vent pipe is concentric vent/fresh air.. 2 pipes in one.
https://www.amazon.com/gp/product/B005MZEOT6/?tag=atomicindus08-20
