kazlx
For those that are interested, I figured I would post up my fab table build, which is still under construction, but finally getting close. It is built from a 5/8" plate that I salvaged from a CL table find. I think I paid $100 for the table. Cheaper than I could have bought the steel for. I'm using 5x5x.250 for the legs and 4x4x.250 for the frame, all bought as drops.
Here's how it came home:
The whole thing had been sitting in a back yard. The frame wasn't even close to level or square and looked like ****. I want something I'm proud of and that will serve me for years to come...and then some.
So I went to work with my Powermax 30 and removed the frame that was welded to the top. At least it was only stitch welded in a few spots. The frame was I-beam, so I just cut the beams down the center and was able to get under them with a pry bar:
Done and cleaned up a bit:
Since I got the steel for a song, I decided to splurge. Had the top blanchard ground, then took it to get squared up and have clamping holes put in with a water jet:
Some frame material:
I wanted to do something a little different and like the hitch stock for being able to use the table as an anchor point for different tools. I decided to french the hitch stock through the frame, two on each of the sides. So I went to work with a template, the plasma cutter and a carbide burr.
