My Florida metal building and spray foam with mini-split
ryanx1776
I have designed a 30x55x16 metal building pictured here. I am wondering two things:
1- What would you recommend for spray foam in Florida on walls and ceilings? (depth and type)
2- After spray foaming it- might I be able to expect a 3 ton mini-split to keep it comfortable? I'm not talking 68...just NOT blazing!
EDIT: Building is up!
front
back
chinboys
Have a or get a Manual J calculation done based on your usage, location, building materials, and insulation ratings.
Get a blower door test done to see how many air exchanges per hour the building is getting.
Install a big ceiling fan or make sure the vents are high enough or the indoor evaporator unit install height is set high enough as cold air sinks and hot air rises.
Heat removal via HVAC is accomplished by first removing the latent heat. Your money or cost to operate an AC is primarily used to remove the humidity from the air before the lowering of the temperature can occur (sensible heat removal).
This means you need to prevent humidity from entering as much as possible if you want your AC to create a 20-25 degree delta in temperature between the outside and inside of your garage.
Too small a unit and you will never get humidity or cooling relief.
Too large a unit... the new minisplit units have variable frequency drive compressors and will adjust according to the load but you want a system that is running at or near or slightly above its cooling capacity.
R
ryanx1776
thank you for the reply. valuable insight!
FL Guy
I’m in Florida also. Building is almost 1000sf with 12’ walls.
I have foam on ceiling and walls. I installed a 36k btu mini split and have no issues keeping the garage at 70°.
Building gets full sun from 11-7
R
ryanx1776
Appreciate the reply. did you go with open or closed cell? I'm now considering two (2 ton) minisplits. One on either end of the building.
FL Guy
Closed cell.
Here's my topic on it. I am happy with it. Its a garage after all.
TheEquineFencer
Farmville, NC 27828
I just another thread from a couple of guys that had their metal buildings sprayed. If it gets behind the ribs, it'll push the metal out and distort the siding. Here's the link!
