My shop/barn build thread
sfd524
Clay, NY
Looking very nice Dan. Do you know where the trusses came from? I am rethinking my barn design nd was wondering if they could do 50' attic trusses. Keep the pictures coming.
J
juicedz4
Rochester, NY
I will dig up the truss sheet and see what info is on it.
Been getting a ton of framing done the last few days.
Finished up the purlins, window blocking and outlet box mounts on the southern wall.
Half wall going up the stairs
Wall at the top of the stairs
Im hoping to have the rest of the purlins up by the end of the weekend, then time to crank on the electrical.
Dan
J
juicedz4
Rochester, NY
No updates for a while here. I have about 1/3 of the wiring done, which isnt very exciting to look at.
Today they brought in gravel to make the parking area along the north side of the barn for my camper and landscape trailer. So I now have another 1300+sqft of driveway or so. Hoping this weekend to get some topsoil delivered so I can taper most of it into the lawn and get some seed going.
Dan
el Pedro
South East FL
Beautiful property and a great size barn/garage. Would love to build something like this one day with a separate part for woodworking.
Another idea with the sawdust on the laminate being potentially slippery would be to only wear socks upstairs and slide yourself around the room. :lol::bounce:
J
juicedz4
Rochester, NY
Finally got part of the driveway back filled last week. Took almost 4 yards of dirt to do that one little area. Im going to need a LOT more to do the north side.
Ive also been working a TON on the wiring. I think in another week or so Ill be basically "done", other than wiring in the final lights (which I cant do until the ceiling is in), etc. I dont really have many pics yet. Ill snap some when its finished.
Lights in the rear "rooms":
I also added a separate 100A subpanel box in the opposite rear corner. Its saving me a ton of wire and work as the compressor, welders, hot water heater, lift, and half of the upstairs outlets are closer to this point than to the main panel. Also if we ever get a generator I can put it behind the barn and have a full 100A run all the way back to the house.
Dan
J
juicedz4
Rochester, NY
Borrowed the neighbors Kubota yesterday and cleaned up the stones at the back of the building. When they put the parking area down the side it went a couple feet farther than I wanted (as shown by the larger dirt patch). I also had a pile of other gravel left over (from what I used down the south side) so I spread that out along the back as well. It only goes half way as I will eventually be putting up a "shed" back there to replace my current pos shed. Anyway, this stone area will be home to a 200 gallon rain "barrel" that Im working on as well as the propane tank for the heater and probably rusty car parts. *Yes, I realize the gutter is going up hill, this is only temp until I can get the rain barrel going*
I also started installing the upstairs lighting. I scored 14 these for $10 each with bulbs, plus he gave me a box of probably 15-20 spare bulbs. They are all 2-bulb T8 fixtures that were apparently removed from a local high school (some still had spit balls on them, lol). Charlotte HS for anyone local reading this.
I have 12 of them mounted and two wired up. These two turn on from the bottom of the stairs so that I can find my way to the storage area at night without having to turn on 12 lights. The other 10 will turn on via two switches at the top of the stairs.
Dan
J
juicedz4
Rochester, NY
Yesterday after work I cranked out more wiring.
- Installed 7 more outlets in the "fabrication area".
- installed a second outside motion light
- finished wiring up the upstairs lights, and boy are they niiiice. I cant imagine how bright it will be once there are nice bright white walls up there. These pics were taken at 1:30 am so it was def dark outside.
I just need to run two lines for ceiling fans, and add outlets for the TIG welder and compressor and I THINK Ill be done.
Dan
J
juicedz4
Rochester, NY
Just passed electrical inspection. woot.
Inspector asked "did you do this yourself? because it looks really nice" :)
Dan
J
juicedz4
Rochester, NY
Ran the vac duct for the table saw under the floor last night (still need to move the saw back over it). Was "fun" doing it by myself. Now I just need to come up with a funnel for inside the saw. I THINK Im going to use a transmission drain funnel, trimmed to fit.
Then I decided to finally try to get the rain barrel going, ya know, before all the rain stops. The wife's dad scored this 275 gallon container from Ithaca college when they replaced them a few years back (chlorine storage for the pools / fountain). Unfortunately they were originally installed before the building was finished and had to be cut in half to be removed. So here is my attempt to put it back together.
Two pieces
Had a friend of mine bend up these two pieces of 1/8" aluminum to use as a giant band clamp. can also see where I cleaned up the plastic near the joint
Inside, lined up and ready to be sealed.
And together with the new lid on. I still need to seal it and add a few bolts to keep the band in place, but I think it should work out pretty good.
Dan
J
juicedz4
Rochester, NY
Well its been a long time since Ive made any progress on the shop. The end of summer was busy with vacation, putting up a pool, doing some landscaping, building a fence etc. Finally getting back to it.
Decided it would be nice to actually use the upstairs storage area so I put up some osb monday night. Im not doing the ceiling since its just a cold storage area. Hoping to prime it up sunday.
I also bought some parts to get the dust collection system going as the table saw has been getting some use and is creating a huge mess.
Going to start insulating and sheeting the south wall of the wood shop this weekend.
Dan
J
juicedz4
Rochester, NY
Had the whole weekend to myself so naturally (for me anyway) that means two days of continuous work.
Decided to continue the sheeting from the storage area into the wood shop area.
I got the long south and short east walls insulated, sheeted those as well as the half wall by the stairs, and put two coats of oil based Kilz on (about 4 gals worth).
Next I need to caulk some of the joints, paint the walls and get some trim up. Then move everything over to this wall and get that north wall finished up.
Dan
Cjk
Wisconsin
They sealed and cut the floor today. Its still extremely dusty. I guess they are going to finish clean up tomorrow. They also brought in two loads of crushed stone to top off the driveway, still a load short. More pics tomorrow.
Dan
I have a question about cutting the concrete when heat tubes are installed. Do they keep the cuts shallow enough to miss the tubes?
JBourquin
New York
I was gonna ask the same thing. I plan to do most of my build myself but this part would scare the **** outta me. That and adding anything else (interior walls,. etc.) and having to lag it to the floor.
By the way, awesome garage.
J
juicedz4
Rochester, NY
Ya, I guess so. I didnt question it. They must just know how far up they pulled the tubes and how far down they can cut.
I made a very detailed map of the tubing layout so I can be sure I dont put a hole in a tube. Tubes are spaced 1' apart, so you have a pretty big window of error if you aim for the expected middle.
Dan
J
juicedz4
Rochester, NY
A couple weeks ago I insulated, sheeted and primed (only got like 1 1/4 coats on as I ran out) the north wall.
Built some shelves out of some old doors I got off CL for $5 ea for all the hand power tools.
Built 32' of shelving along the one wall of the storage room
I scored these two old desk tops from work and made them into a little bench upstairs. They arent awesome, but for nearly $0 itll get the job done for now.
Dan
J
juicedz4
Rochester, NY
Very nice build, what's you plans for the downstairs walls?
Im going to use the white steel liner panel with the bottom 3' or so either the lighter or darker grey that I used on the outside. It should keep it looking cleaner and the outside metal is a bit thicker so it shouldnt dent as easy etc.
Dan
KerryH
Ga
Forgive me, I'm not very experienced in large structure construction.
Where can I find more information regarding the construction used in this building where the framing was done prior to the slab?
I've only ever seen the typical slab first then framing so I'm curious as to why this build was done this way and am not sure what to research.
J
juicedz4
Rochester, NY
I havent updated this in forever, as I havent worked on it in forever. Until recently.
In the last couple weeks Ive been working on the insulation, finally.
Ceiling -
Im installing R30 under the upstairs floor area. The rest will be R49 blown-in once the steel is up.
Im currently at about 60% done. Hoping to have the rest done either tonight or by sat pm.
Walls -
Started insulating the front of the posts, to keep any cold air from getting between the 2x6s they are made from (no they arent glue laminated).
Also I had some 25" gaps between all the windows and the posts. I used some 2" foam along the posts to bridge the gap vs trying to fill in a 2" piece of fibergass.
Finally, capped the walls between each truss with some 1" foam to help prevent cold air from pouring down into the walls. The way Im insulating them, fiberglass between the purlins, I thought itd be hard to seal without doing this. Even if it doesnt make a huge difference Im only out the $15 for a sheet of foam.
South wall all ready for insulation. I actually have about 50sqft done, just no pics.
Progress will hopefully be alot faster now. I hope.
Dan
J
juicedz4
Rochester, NY
Pretty well done with the ceiling now. Just a couple pieces I need to toss in once I get ceiling fan boxes in place.
Ran hopefully the last few 110V lines, to the ceiling fans and to two locations for lights over the bench area.
Also, have about 75% of the south wall insulation done. I think the other walls will go MUCH faster. We shall see.
Dan
J
juicedz4
Rochester, NY
Have you ever stopped, stepped back, and said to yourself, "damn, it feels good to be a gangster."??
We're getting to that point, yes.
Saturday pm I worked on a little more insulation.
Sunday am a friend and I got the plastic up on the south section of the ceiling. It took some time, but wasnt SO bad. I still need to do a little taping but ran out of house wrap tape.
Then yesterday this showed up, along with a mountain of J and Z trim, about 1200lbs worth. I only had enough cash to get the metal for the ceiling, the south (window) wall - where my 18' workbench will go, and the west wall (overhead door).
Started putting up a few pieces last night because I couldnt wait. Im loving the look of the light grey, blue and white. the night pics sorta ****. Ill try to get one during daylight when I get home later.
Im hoping to get a good start on the ceiling tomorrow night.
Dan
J
juicedz4
Rochester, NY
Thanks!
Last night I finished up some plastic taping, a little insulation, installed a bunch of J trim, and I installed two wall panels over the man door.
Then a buddy came over and we got 8 ceiling panels installed, which took a little over 3 hours. We did spent a bit of time screwing with the garage door brackets. I cut about 10" off the piece that bolts to the ceiling to avoid cutting too many ribs out of the steel and just so it would look nicer. I think now that we are into the middle area it "should" go a little faster. Plus now we have a system down for pre-measuring where the screws are going etc.
Dan
J
juicedz4
Rochester, NY
Hmm... not sure what you mean exactly. However, if you mean a overhead door that literally rolls up, I dont know A. why I would need that and B. I doubt they make them with R19 insulation.
Dan
J
juicedz4
Rochester, NY
Saturday AM we got another 6 panels up on the ceiling. So now just over 1/4 done. I also got the first 4 light fixtures hung and wired (only two pictured, obv).
Last night I got the first panel on the front wall installed.
Closeup of grommet for speaker wire and outlet plate.
I would have started on the panels over the garage door but I need to cut up more flashing to hide the wood above the J trim. Im sure no one else would notice but it bugged me seeing the wood, and especially seeing the giant blue LOWES on the house wrap tape I used to seal the ceiling plastic. I only had enough to go just past that first panel.
Of course this pic doesnt really show how much better it looks white. oh well.
Dan
J
juicedz4
Rochester, NY
Thanks!
Didnt get a ton of time last night, but I did manage to get some more flashing installed under the end J channel, insulated and installed the steel over one garage door. I had to put one extra seam in over the center torsion support bracket, but its nearly impossible to see. I just overlapped the joint a tiny bit and added an extra screw.
Tonight its back to insulating the south (window) wall and trying to get some more steel up.
Dan
J
juicedz4
Rochester, NY
Got 8 more panels up last night. 4 more to be half way done. 30 to go total.
Going to pick up 3 more lights on the way home today so I can complete that first row.
Dan
rusty1
No. Illinois
...just read the whole thread; now I'm tired just thinkin bout all the work involved with your build; all top notch work.
It's nicer than my house, I could live in there.
..love the color combo also, mine's the same color.
J
juicedz4
Rochester, NY
Thanks!
Saturday pm I put up one more light and last night another. I now have 6 total, 9 to go.
Ran a couple of 220V lines for one of the on demand hot water heaters and a welder outlet near the lift area.
Put up a couple more pieces of insulation and two more wall panels.
Going to finish up the wiring tonight and likely hang more ceiling or wall panels on wed.
Dan
J
juicedz4
Rochester, NY
Thanks all!
Got another section of insulation up and 3 more steel panels up on the south wall. One more and Ill be half way!
Im hoping to get a ton done this weekend / monday.
Dan
