AntiqueBen
- Joined
- Aug 4, 2021
- Messages
- 1,442
Yeah, seems like a stretch on that theory. Why change tooling? Doesn't make a lot of sense. There's got to be a reason. Who knows, you could be right? Here's my Patent Pending no 9's.
Thanks, I looked at the former joint between the screw and the rod, not much signs of a weld or other attachment point. I think my first goal will be to try to break the screw loose, then worry about the connection point. Almost looks like it may have been a crimp or something that spun out when the screw froze.@RTM
I bought one in 2021 (post 57) that was jammed. I think there was twine or something similar wrapped around the screw. and inside the nut or whatever. I did eventually get it picked out, I think through the top opening.
I haven’t handled them in a while, but that post mentions a weld or braze, that may bear on what you’re asking about the indicator and knob.
Almost as if I conjured one into existence and placed it in my future path, the ol' GJ talk-about-it-and-it-will-come magic was in play this morning at my flea market, where I found this B.M.C. offset screwdriver with a Phillips bit! Looks like a #2....but I don't have any with Phillips bits and I have never seen one in the wild.
My other four grips are all 7”, but none bear the model number or patent number - all have “patent pending”.
