I'd go for a Ideal or Klein conventional. I kept trying to get the self adjusting or auto strippers because I HATED using the conventional ones. It turns out that was because I always used cheapo ones. I got these guys: http://www.use-enco.com/CGI/INSRIT?PMAKA=505-0465 and man are they nice to use. Cheap too when you get them with a 20-30% Enco code that comes up every month or so.
These are my two go to stripers. An ideal stripmaster and a blue point branded inline striped. Between these two, 99% of my needs are covered. I have couple standard style, mostly Klein, but they rarely get used. The blue point one is handy in tight spots like under dashes. Being one size fits all, it isn't always the best on really small wires. Stripers are one thing I don't think you can have enough varites of. Take that anyway your dirty little mind games it.
Should I go for a Self Adjusting type or the conventional type?
Generally, no.Are there any decent wire strippers that have a built crimping mechanism?
I use these, they are slightly longer more leverage , identical to the Channellock 908 http://www.sears.com/craftsman-electricians-tool/p-00982563000P?prdNo=5&blockNo=5&blockType=G5
Also, curious to know, how are these Channellocks?
http://www.amazon.com/dp/B00004SBDJ/?tag=atomicindus08-20
Why is there a discrepancy on the product description between the Ideal 45-092 and Ideal 45-292? Are they both the same? (10 - 22 AWG)
Amazon Description not Accurate, again. (Not 10-32 AWG)
I use the pwcs7 to crimp and cut and the stripmaster they are perfect together, the guys at work don't like the stripmasters but its because there blind.
Let us know how the Channelocks do for you. I probably would have gotten the Ideal 30-429 if I were in your position.
Sent from my SM-G920V using Tapatalk
Is this Stripmaster the same type of mechanism as on the Klein Katapults? I'm shooting for a 6-16ish AWG stranded wire, stripping in the middle without cutting using that technique you described.The nice feature with strippers like the stripmaster is the insulation can be separated, then by using a pick to separate the strands of wire a hole is made and another piece of wire is then inserted and twisted into the picked hole. Makes for a very good connection without any silly t-tap looking thing. Finish up with solder or in a pinch tape and go.
Amazon's descriptions can be badly inaccurate. They very well may be made in China but the ones I looked at in person today were Taiwan.I believe the Stripmaster and Katapults are the same. However, according to Amazon, the Katapults are Made in China
