Hi all,
I am not a pro and may not use correct terminology. Feel free to correct me.
I need to install a new 200-amp service drop to my residence before I can connect my workshop's subpanel to the home. The reason for this order of operations is because my existing 1960s load center is out of circuits, and the service should ideally be upgraded from 100A to 200A.
I will have a pro install a new meter socket / cut-off switch to the exterior of the home. Before I hire a pro, I want to make some preparations to ensure that some of the finer points get completed to my satisfaction.
First, my existing triplex wire is connected to a clevis/house knob (terminology?) that just screws in to the eaves' subfascia. Photo below. This shoddy work was done by a pro and I want to properly install a new house knob for the new pro to connect the new triplex to.
I assume there is some relevant code on house knobs. Can anyone help me out? My searching so far has not been fruitful. In particular, what is the proper way to connect the clevis/house knob to the subfascia? I assume some sort of through-bolt with a large washer on the inside of the eaves/subfascia would be much stronger than the screw-in type. Specific links to a high-quality clevis/house knob would be much appreciated.
Note that I do NOT want to install the new weather head through the roof. I want to keep it on the side of the house.
Also note that the exposed wood to the left of the house knob is from a prior fastening location. A pro re-installed the same 1960s clevis a couple inches to the right of the original location, where you see it now. The tension in the cable appears to be pulling the house knob slighly away from the subfascia. Very shoddy!
Thanks for reading!
Thanks for reading!
