New 30×40 pole building
Reit38
Iowa
Last month we worked on saving the small shed by putting it on a trailer and moving it out of the way. The new shed will be close to being in the same spot as the old one.
Last Thursday we had 30 loads of fill hauled in, leveled, and compacted. In 30ft I had 4.5ft of fall.
ddae8a3a22ce962dc4580632cf5f8ace.jpg1f9ff27323452da873295940060b0e54.jpg94432356908c6cce26d6cb2885d7ae1f.jpg09454d1e0d19230064afdb172338ee98.jpg2fad1a14bac6177398d638ed0e3989eb.jpg
The small shed was saved and will be turned to run the same direction as the new shed. Won't be dealing with that shed till next spring.
Sent from my SM-G930R4 using Tapatalk
R
Reit38
Iowa
Building was delivered on Friday.
Layed out post locations today. Hopefully drill holes by Tuesday
kbs2244
" In 30ft I had 4.5ft of fall."
It is amazing how common his is in the "flat land" states.
Now you know where your oversized gutters and downspouts should go.
R
Reit38
Iowa
10x8 garage doors. Already may be regretting not going 9 high
Holes will be dug Thurs [expecting rain next 2 days]
Hopefully footing pad will be poured Friday and set poles Sat
R
Reit38
Iowa
R
Reit38
Iowa
Right now we have another hang up because no where in the specs does it say the size of the holes for the post. They sent 14x4 cement pads but that's it.
R
Reit38
Iowa
Broke ground today. Hopefully inspector gets out tommorrow and everything is good to go
R
Reit38
Iowa
Got a little work done today. Hopefully having get everything ready for rafters which were plannin on the middle of the week
R
Reit38
Iowa
Had a pretty productive weekend overall. Plan on setting rafters by Weds.
89e5ca1a04b3e1f341a06b6d8a17da85.jpg9d53fa0b6e9318c1fec86f09b98e2808.jpg785a3ec0fdd2e089c8aa5ca793f7f864.jpg
rayra
Escaped from Los Angeles
particular reason the man door is hinged on the right rather than the left? It would seem to be better if it opens in against the side wall.
And no eaves / overhang on the roof?
R
Reit38
Iowa
Walk through door still needs framed in. It will open towards wall, left hand swing. No overhangs really due to costs. Saved $1500 by not going with them. Will still have gutters installed
R
Reit38
Iowa
Slowly starting to come together. Got the rafters set on Thursday night after work. Tyvek on Friday.
29aaa80dae1f0527a6eae2d59e4fc9d5.jpgd17e258df807b4b2ff437f25a2dfaa99.jpgb51e101ae64c9bcdb09b6d34b0907855.jpg
R
Reit38
Iowa
Perlins, wind bracing are now done. Tyvek will be finished in next day or so.Not sure how much will get done now after work with time change. 6b5ad277689cc4bfb031151585ce91ec.jpg
R
Reit38
Iowa
Got a little done the past 2 weeks. I've been gone past 2 weekends at deer camp and now with time change, doesn't leave much time after work. My dad took some time off of work to get wainscoting on an we got one gable end steel on and I hung windows last week
64a1a12c9f0d758d05f2da47cce398e3.jpg fb7024dcae05bb035bc2f81669e6a7e3.jpg8a7996818f2b2c7a940c0f3a0b226f80.jpg230d59bfa67333a2cf0a184c1c14bccb.jpg
R
Reit38
Iowa
Thinking of running water and having a sink in the building. Any pointers. On doing this? More along the lines of drainage. I already plan on having 1 or 2 floor drains in the parking area.
bikesandcars
Nice pole barn. Good to see you doing wrap, I wish I would have.
Before concrete I roughed in bathroom waste lines and a 4" corrugated tube to run future water lines. The water comes in 3' in to avoid a freezing issue if the heat is out, it will end up in a bathroom wall.
What you do on the outside is largely dependant on where you live and how you roll.
Sent from my XT1585 using Tapatalk
R
Reit38
Iowa
No plans on a toilet just after a sink. I was thinking of having sink by small walk in door then having drain line to center of building where floor drain pit is. Then from there it would run outside
R
Reit38
Iowa
Yup was there all day. He had a single drum vibrating compactor. It's in the foreground of the pic. They would bring in 4 truck loads of fill, he would level it off then compact it.
R
Reit38
Iowa
Forgot to add, lp tank was moved to other side of the house so that is also now out the area. Really opened the area up and made it seem not so clustered
bikesandcars
That works.
Could you could throw a urinal in there too for light use?
R
Reit38
Iowa
Probably skip on that too, I have no issue walking out the door and goin around the corner [I have no close neighbors] otherwise if nature calls I'm only 30 ft from the house
R
Reit38
Iowa
Got alot done this week finished the back wall and the other gable end. Last few days we've had 30+ mph winds so Sunday was only other day to work and ended up getting the roof all on with some help.
Pics to follow, to dark once we were done for pics
R
Reit38
Iowa
e3a1c774006e7f24aa1573d6d439b9ee.jpg4080581ccf07eb5a2def1345d540aebb.jpg74d9a156df8d6a8fb4f4fba648d2d4e2.jpga3ada9578fe44aaeda13365818f4c97b.jpg
RyanEricW
Looks nice, surprised you have to deal with inspectors out there in the middle of nowhere
R
Reit38
Iowa
He's a pretty good guy. He came looked at post holes. And said let him know when we're done
CNGsaves
KS and OK
OP . . . not too late to upgrade those garage doors to 9 ft tall . . . or taller. :D
I sure would not build such a nice big garage with short doors.
Overall, coming along nice. LOVE the details of the different color lower skin of the building. Keep the pics coming. :beer:
NES
Illinois
Very nice looking garage. What do you plan on using the garage for? If I may ask.
R
Reit38
Iowa
thanks guys. no real need for a taller garage door. did cross my mind tho. ill have a vehicle parked in 1 bay. other then that itll be mainly used for a get away from the house, some storage and workshop
R
Reit38
Iowa
i know 2in is the most common under the slab for foam board, how would 1in work? i know its only an r5 value but also half the cost
Loose Ctrl
Upstate SC
I'm building a 12x16 workshop, with a full 4-inch slab,not 3.5 like traditional 2x4 sock. I ask this question to a local builder. He said thickness wouldn't matter as much if the foam has the mylar/foil covering face up and sealed with foil duct tape. Granted,this is in my area in the foothills of SC and my building isn't very big. It may be a different equation in your area. When,or if, I get to build my big garage, I will insulate under it and pour a full 6-inch slab.
bikesandcars
Half the cost, half the insulation. Pay now or py later right? Around me 1" xps is 20 and 2" is $32... So 2" is a better value.
I did 2" xps on the outside and 1" in the middle. I also did 2" on the skirtboard
Radiant barriers do not work against other objects like concrete, they need air space. The numbers quoted for radiant are as part of a system. 25psi 2" xps is the standard. also do the perimeter / skirtboard.
My experience with contractors is they try to sell you low cost because they look good and easy for them. They say I am always overkilling it... Who's right?
R
Reit38
Iowa
Knocked a little bit out today. Was pretty breezy tho so couldn't hang any steel.ended up being 6 foot short on tyvek so I had to make some phone calls the find some scrap to finish it off. Got all the trim around doors done and hung the last windows and walk through the door. Had a little time before dark to get some bushes in also. Hoping to get the majority of the last side done tommorrow but we're expecting rain in the afternoon.
5b0fe237d45931d9a6f62e4147037fde.jpgf757da2fc0840435aa3b0070aae9b7ab.jpge48f0afbc01480428dd932d066e00aa9.jpg
NUTTSGT
Northern Central Ohio
Great building that you should get some good use out of. The color combination is nice, the electrical suply shop next to the fire dept uses those colors and they go together quite well.
BTW, I have moved the thread to the Gallery Section.
