I made a similar request last year on another BBS. I will share their comments with you, Joe
Sent: 11/11/2004 4:02 PM
Joe, I am definitely not an expert on shop layout but I have made a few booboos and learned a few hard lessons. I put my welders close to the breaker box, but used a long enough extension cord to reach all corners of the shop. My air compressor is outside, but sheltered from the weather (also close to the breaker box). I didn't put any windows in the shop (except in the roll up doors) so my stuff would "stay put". I use my attic space for storage, (put some lights and an attic fan up there). I keep my "mess making stuff" (drill press, etc) close by the rollup doors so I can keep the floor clean. The top half of my walls are pegboard, if you don't like where you first hang something you can easily move it around. I would use plenty of insulation, seal & paint everything up (including the floors), plenty of light and make sure you can get a way out if you catch the place on fire. Did I mention fire extinguishers? Hope this helps some, I'm sure there are a gazillion ways to do it.
Freddy
Reply
Recommend
Message 3 of 9 in Discussion
Sent: 11/11/2004 5:26 PM
Couple things to add:
1) Make sure you set it up for water, gas and a 200 amp 220 volt main service.
2) Add a water heater - you'll be glad you did.
3) Setup the concrete floor with floor drains -- to help you wash the floors and not have to push all the water around with a broom.
4) Make sure you think about high-amp and high-voltage equipment --> like air compressors, arc/mig welders, etc. It is always best to have too much power and a bunch of open breakers than not. Wire everything with a dedicated ground wire and make sure your wires can handle the load of the equipment you plan to use.
5) If you're in a cold area, then you might want to section the building off into a well insulated work area (that you don't mind paying a heating bill for) and a general storage area for cars, parts, etc.. In the work area, use lots of insulation, cap the walls with something strong like plywood or chipboard and put plenty of power outlets, etc..
6) If you have multiple areas, then make a big sliding door that is wide enough to pull a car into the heated area - yet can be slid shut to conserve heat.
7) Build a loft area that you can use to store all those dang parts (like fenders, hoods, etc. -- that don't weigh a ton, but take up lots of space).
8) Maybe have a steel beam to support the loft area and potentially second as a place to hang a chain hoist -- can come in real handy.
9) Poor a thick concrete floor -- designed to handle the weight of what you're going to be putting in it.
10). When they poor the floor, you might want to include a couple large U-bolts on either end or sides of the floor -- where you can hook a come-a-long to winch heavy items (like pallets) along the floor. Can also be handy to secure a frame or something you're working on. Can also be used to chain/lock something down that you'd prefer to not "run away".
11) Consider putting in a half-bath as well as a wash basin -- makes it easy to clean up.
12) Run air compressor lines behind the wall caps -- with quick connects in obvious places.
13) Setup a heater with a digital setup thermostat -- can program the heat, times of day, etc..
14) When you wire the place, also run TV cable as well as CAT 5 network wire. If you're into TV or maybe a computer system, then you'll have all the wire built into the walls and ready to plug into.
15) Fridge and beer cooler . . . to aid in all "project" work.
16) Phone
17) Bed . . . cause if you're in the "Dog House" you just may want to sleep there. And after all . . . if you do all of the above, it might be the place you'll want to sleep!
Best of luck . . . hopefully my "dream" setup helps you along. Dale
Reply
Recommend
Message 4 of 9 in Discussion
Sent: 11/11/2004 5:52 PM
I can tell you what I've put in my shop, as well as what I wish I had put in my shop:
If you live in a rainy area, be certain to install a heavy-duty vapor barrier under the concrete before it's poured. There's nothing worse than a damp concrete shop floor! Add lots of 110V electrical outlets (they're cheap) as well as a couple of 220V outlets. A few overhead reel-type drop lights and extention cords will come in very handy, as well as a large reel air hose containing at least enough hose to reach outside the doors. Don't forget a phone line. Run some 1/2" copper lines for several compressed air stations at your benches, etc. with drops at each station to drain off condensation. I use radiator petcocks for this. As for windows, it depends on how isolated your are. They are nice to have. If your design permits, some skylights are a real bonus, and will definately brighten up the interior during the day. At least one nice, long, heavy-duty work bench w/ large machinist vise at one end. I like at least one large wood topped bench for working on items that would be damaged knocking around on a metal bench. I built mine from 2x4's on edge, glued and bolted together with long lengths of 1/2" all-thread. I also put several Craftsman cabinets with multiple drawers under the benches for storage. You just can't ever have enough storage for tools ,etc. Lots of wall shelving for parts strorage, and a nice cabinet with hanging plastic bins in the body and on the door interior for fasteners and other storage. Try and keep all dirty work (cutting, welding, grinding) in one area, as far from the clean work/assembly areas as possible. A slop sink with hot and cold water is a definate plus. One of those compact instant hot water heaters would work good, and take up minimal space. Where I live I need heat as well. There are different ways to go about this. I have a forced air upright propane heater on one wall and a 125 gallon tank to run it. One of my friends has hot water heating in the concrete floor of his shop, which is REALLY NICE! Warm feet, quiet and no dust/air blowing around like with my heater. If I ever do another shop, this is what I'll go with for sure. The drawback is the length of time it takes to warm the shop. If you're not using it every day, it can be a problem. Well, that's a few more things to think about. I'm sure you'll be getting plenty more as well...
Reply
Recommend
Message 5 of 9 in Discussion
Sent: 11/11/2004 6:56 PM
I'm in the midst of planning my shop/garage, too; good advice from Dale and Rodnut above, here are a few comments:
-- Codes in my area won't allow for floor drains in a garage (possibility of gas/oil going down the sewer) unlesss you do some pretty extreme stuff ($$$). Not a great idea on a septic system either, if you have landscaping near the field. Instead I will slope the floor to the big doors.
-- I was going for 100 amp service, for a 3 HP air compressor and a 220 amp/220V arc welder, the usual lights, etc. Check with your utility for the break points on Demand Charges and service capacity. (I have underground service, which is pricey)
-- don't forget ceiling outlets for electric garage door openers
-- A set of long welding cables (stingers) is a lot cheaper than multiple 50 amp 220v outlets (even if you're wiring it yourself) and allows you to weld out on the apron too
-- I am going to have a fair number of skylights and windows, and put bars over the inside to address the thievery concerns, you can never have too much light
-- I saw a setup like Rodnut's friend's with radiant floor heating, using solar heat. With the price of fuels, makes sense. It also costs no more to use all the time. I would worry if I thought I'd ever have to drill thru the slab for some reason, tho.
-- Don't forget outside lighting (possibly on motion detector)
-- If you have a choice, don't have the main doors facing the street, it's just like advertising your stuff to thieves; and if you can face it south, you won't have permanent ice on the apron if you're in the great north.
-- Ross
Reply
Recommend
Message 6 of 9 in Discussion
Sent: 11/11/2004 7:00 PM
PS, I also checked on waste oil heaters (old crankcase oil) for heating both my house and garage. People will give you the stuff just to get rid of it. Unfortunately, it's way too much $$ for the units to be attractive for a home/garage, although if you are at 2,000 sf maybe it would pay.
-- Ross
Reply
Recommend
Message 7 of 9 in Discussion
Sent: 11/11/2004 7:03 PM
There is a software program available on Amazon.com titled Instant Shed and Shop Design.I read the info on it and it may be of help in your planning.Sells for $9.99 + shipping.
Chuck
Reply
Recommend
Message 8 of 9 in Discussion
Sent: 11/11/2004 8:16 PM
I drew this up on a program called 3DHome, in less than an hour. Any similar program is worth the money 20 times over!
-- Ross
Final Garage.doc
