Nobody’s project corner.
N
Nobody-named-Olli
I have two SAE ones that were former German military issue. One of them is in the picture (3/8 / 7/16), I used it to confirm it was indeed a 3/8” nut. The other one is - just like you pictured - the 1/2 / 9/16.
Then I have the metric set from 10mm to 15mm and 17 & 19, which I got off the truck years ago.
Reasons for purchasing them, I really, really like them. AND Tim Allen in his role as Tim Taylor in Home Improvement had them hanging on the peg board over his workbench in his home garage/ shop. That was a big influence in wanting to have them. And just like in his garage, mine are hanging on peg board over the bench as well. ;)
I use them whenever I feel like it. They have a very distinctive feel & sound, love that.
Kind regards,
Olli
N
Nobody-named-Olli
#29 Follow up on #23 Garden watering/ irrigation pump suction hose/line repair attempt. (FAIL.) No more!
With the arrival of spring edging closer and closer it was time to replace the suction line for the garden watering/ irrigation pump.
First step, as almost always, set up shop.
And then start excavating by hand. As usual my goal was to do this as minimally invasive as possible. But I had to realize two wheelbarrows alone wouldn’t cut it - so I laid out some boards & plastic for the last few scoops.
There’s the lid.
Some scoops later & with a little hosing down and a few taps of a hammer I got the lid off the IBC.
I was very happy to see this. After so many years the DIY build (and DIY connection between the two IBC), years before the whole “craze”started, is still holding water perfectly. (This is IBC 2, the other one is under the rose bush to the left.)
Then it was just a matter of two pairs of water pump pliers and replacing the hose.
Breathing pipe and suction hose back in & ready to go. New cover to keep the dirt out. Suction hose inside pipe for protection now.
Filling & compacting.
All done & works again. Pump sits in that little brown housing build from composite deck boards & is controlled via the switch box I have shown before.
Kind regards & thank you for your continued interest in my projects!
Olli
larry4406
Northern Virginia
There’s the lid.
Olli
Olli - is that just an underground water storage vault from rain, gutters, etc? What kind of water volume does it capture? Clever.
Also, is that a pizza oven in Picture 2 on the left side?
N
Nobody-named-Olli
Yes Larry, it collects water from 1/2 of the roof of the house (garden side) and from the roofed patio. Total storage is 2000l/ 528 gal (Two 1000l/ 264 gal IBC).
That is a classic BBQ, you can heat a stone in it to bake pizza on it, but it’s not an oven per se. Can’t close it.
Kind regards,
Olli
N
Nobody-named-Olli
#30 Gate to “very small farm road” makeover.
30.1
A couple of days ago I did some maintenance and re-adjusting to our old gate. Since doing that I felt that I needed to give it some more attention because it’s showing its age and my rookie mistakes from many years ago, when I purchased this gate made/built from pressure treated lumber and didn’t give it time to wither down before applying wood protective varnish/stain. I did it right away and paid my dues - and had to pay some more this time around.
After completing #29 on Wednesday and having the pressure washer out from cleaning tools, I quickly grabbed a screw gun and removed all the hardware from posts and gate and gave it a wash. Part of the decision to do it was that the weather is phenomenal right now, spring on steroids, so I knew it could completely dry on Thursday and thus enabling me to work on it on Friday, yesterday.
This is what the gate looked like on Monday when I did the maintenance/ re-adjusting.
Removed hardware, some debris from #29.
Two bolts I need/ want to re-use in some “rust remover” … So they could sit for some time.
Fast forward to Friday, setting up shop on a beautifully, ”springy” patio. :)
First I drilled two recesses for the main bolts, because I never liked how the nuts went directly into the wood. This not only provides clearance for the nuts (and socket) but also to add a washer.
Using my Swiss Festool Zobo 35mm drill bit with some Festool doo-dahs in the AEG mobile drill press.
And then giving the whole gate a once over. I didn’t want to go overboard with this, I could have spent hours cleaning it up - I just removed the worst and made sure one of my two sanders had touched it all at least once. Did the same with the posts.
Then it was time to get the wood protective varnish/stain on.
Will continue in 30.2.
N
Nobody-named-Olli
30.2
Two layers of wood protective varnish/stain on front, back & the posts.
While I let this dry over night, I sat down in the lair to “rescue” the two main bolts.
After rough cleaning, thread file as I had trouble getting the thread chaser started.
From there it was straight forward running the thread chaser on and off on the two bolts with a bit of cutting fluid.
And ratcheting wrench for the last portion.
Bolts are useable again. Nuts won’t be reused.
Will continue in 30.3
N
Nobody-named-Olli
30.3
This morning I went and re-installed the hardware. Using “little Thor” to convince the bolts to seat properly.
Washers and nylock nuts for the main bolts.
Greasing where needed.
And fitted.
This will be good to go for at least a couple more years - and who knows what I come up with fence wise anyway - as the ivy bothers me A LOT - and the original wire fence has seen better days as well. …
That’s the gate completed for now.
Thanks for your continued interest in my projects & kind regards,
Olli
