Nut Drivers (new or old) show them here
A&P mechanic
FL
My most used nut driver size on my Toyota is (drum roll) you guessed it, 10 mm
I have the same Craftsman sets above from Sears. I did not want to modify one of my American made Craftsman drivers, so I picked up one from Ace hardware (nut driver is made overseas, not USA) and cut the handle down yesterday. I had seen stubby 10mm nut drivers but I like the bigger handle. For reference, the Ace handle is 1/2 inch longer than the Cman handle. I normally use my 10mm Cman driver for the bolts holding the plastic cover that hides the oil filter and drain plug. Anyway, now I have a shorter one with big handle and am looking forward to trying it out next oil change.
KnurledNut
n/a
I like the Craftsman version with the rubber handle and the clear acetate core. The metric version had a gray core.
It does not have the ball on the handle end. It's more comfortable to me. They feel similar to Klein but are color coded. Hollow shaft.
I don't know what manufacturer made them. They aren't as common to come across.
I don't like posting peoples eBay pictures without permission, so here is a link if you want to see what the set looks like:
https://www.ebay.com/itm/227264386667
YesIHaveAHammer
Recent arrivals.
At the smaller end, a screwdriver handle makes enough torque. At the higher end, they're good for spinning things in/out for tightening/loosening with a different tool.
Stahlwille 12500N nut drivers 5.5-7-8-10mm
I'd not been especially pleased with the smallish handles of my Felo ones, especially in some sizes, so I tried one of these and soon added the other useful sizes. The handles are well sized for my hand and the specific socket sizes, and they're all the same shaft length. No hex bolster or bar hole in the handle for additional torque though. Size markings on the sockets, and also the end of the handles but quite faint.
Beta 941 T handle nut/socket drivers 8 & 10mm
Partly just an excuse to have classic orange Ts. The bottom socket is 6pt and plenty deep, and the side one 12pt. They're not as ergonomic to spin as hex Ts as that socket is bulkier and protrudes further. The range is no-skip from 7mm to 13mm, but I can't see any need for the torque in 7mm, and they might be a bit unwieldy in the larger sizes (longer, wider, big sockets). The orange colour photographs oddly - on screen it looks quite deep and classy, but to the eye it's brighter, pastel, and flat.
NoahG
Detroit, MI
Picked up this set of Xcelite nut drivers today. I’ve been hunting for the smaller sizes. Someone munched on the 5/16” too hard, and it doesn’t have a handle any more. But I have a spare for that.
Also picked up this Brookstone branded set made by Moody
YesIHaveAHammer
Recent used arrivals
Facom 74 nut drivers 7,8,10mm
I got a 74T T-handle new old stock a while back. These are used and pretty good condition, just the handles are a little scratched up, and a few specks of rust on the shaft inside the handle on one of them. Some tools are still made with Isoryl handles, but most have been superseded by ProTwist handles.
genog
Silicon Valley
As several have commented.....I too, rarely use my nut drivers
They're good to have around, so should I run into a nut that's down behind looong threads that requires a hollow shaft, I'll get my ND's out
Dodge provides this 10mm nut driver for Challengers with a Shaker Hood Assy
It's for removing the Turtle Shell so that you can add oil
