Strouty
If you poke a hole in the filter, then you can't reuse it. I clean mine out with brake cleaner, The oil gets filtered with a doubled up coffee filter and I am good to go for another 15k miles!
Umm, how bout a drain valve instead of a bolt? Don't worry, I take checks..
Or there's alway the otc drain plug pro for less than the ONE glove I assume that listing is for.
$21 shipped - OTC Tools 5911A Drain Plug Pro Magnetic Remover https://www.amazon.com/dp/B01MSJEBBO/?tag=atomicindus08-20
Used motor oil is carcinogenic. You don’t want it on your skin if at all possible.
Opinions vary.
Used gasoline engine oil is carcinogenic.. used diesel engine oil isn't, so says the US National Library of Medicine. It's your tax dollars at work: Carcinogenic potential of gasoline and diesel engine oils.
More here: Here's How All Of The Fluids In Your Car Can Kill You
Poke a hole and drain the filter and what is above BEFORE loosening it... then loosen and spin it off... the pitstop glove won't do much for filters that are not vertical, horizontal and angled will still just run down the side of the block!
