Opener receptacle placement
va72mlibu
Alexandria, VA
Just starting the electrical rough-in. I will use a standard trolley opener on a 16x9' door. Is there a standard for where to place the box for the opener receptacle? I was thinking of adding 3' to the end of the door when up?
Hot Rod Grampa
Near Cooperstown New York
Opener rail plus 3', since there is no 9' rail it will be a 10' so 13' back from the header and 12" off center. You don't want the outlet to end up buried by the opener. Assuming you are placing the opener in the center of the door.
V
va72mlibu
Alexandria, VA
Yes the opener will be centered. This is great info, I never would have thought to place off center, thanks.
Barnabas
Raleigh, NC
It could be a gfci receptacle, gfci breaker, or you could mount a blank face gfci on the wall of the garage.
exranger06
CT
You're talking breaker not receptacle, right? Since it's up high?
The receptacle on the ceiling cannot be a GFCI, correct. However, you can connect it to another GFCI receptacle upstream that's located in an accessible location.
tfi racing
Cedar,BC
Just to muck this up, how about moving your tracks up to the ceiling and using a wall mounted opener so you don't have to look at all that junk hanging in the middle of your shop...
dscheidt
Connect it to the load side of a GFCI that is accessible. No do not put the gfci on the ceiling.
GFCI is cheaper than a gfi breaker.
"readily accessible", which means you don't need tools (other than a key) or a ladder or have to move installed equipment. Accessible just means you can get to it without demolition. The outlet for opener on the ceiling is accessible, but not readily accessible.
V
va72mlibu
Alexandria, VA
I hadn't seriously considered that (mostly just due to unfamiliarity), but I think I may go that route...
V
va72mlibu
Alexandria, VA
I owe you a beer. I already ordered my wall mount opener. It solved a bunch of other problems. Cheers!
