Last items I like to add is a nice kit service set
I would go absolutely by price on this one because they are all made in China and I don't know any reason to believe that one set is different than another. Even Snap-On is just a rebadged kit.
I'd try hitting the sides of the arm on the knuckle before I started to strike the end of the tie rod. Usually one hammering on the side will do it, but sometimes two hammers hitting both sides at the same time helps. If you are to the point of a pickle fork, then you are at replacement.As a DIYer for over 50 years, I have found that I have not need any of those tools, except on one occasion. I need to pull a pitman arm off of a 20 yo truck. I bough an OTC 7310A but even though it has bolts to hold it on it would not stay.
Lots of heat (propane), lots of beating and lots of cussing finally got it off !
Tie rods are easy. Remove the castellated nut, re-installed upside down until the nut and the top of the stud are flush. BFH ! Or a pickle fork !!
If you are going to be doing this a lot, Big Nasty (Astro 4980) is a MUST HAVE !
I think mine is the OTC, but no matter which one you select you will love never using a pickle fork and hammer again.![]()
Never say never. There's some balljoints you ain't getting with any of the fancy gadgets in those kits. And hammers, or a pickle fork, are faster.
Two hammers always helps. I love watching people try to pop 'em with one![]()
I paid extra for a Gearwrench version of the lever-type tool. The first time I used it the forcing screw bent, or perhaps it came that way. I came to the same conclusion about the relative quality.
This is all you need for a Honda. You should have stopped when the screw becomes super tight, and then start hammering. I read it somewhere that is the proper way to use that tool.
Luckily, I never had to do that. The tool always popped the ball joints before getting too tight to damage the bolt. So much easier than those brutes who beat with a 10lb sludge, thinking it's faster. It's not: the tool takes 10 seconds to put on, and another 3 seconds with impact.
