That's a sharp 806!
That's absolutely ridiculous, what a bureaucratic overreach!!!Well well well. 170’ deep 8” casing irrigation well !! Crappy thing is it’s flowing over 100gal/minute out the top as an Artesian and is going to require more work to route that water away from the field so it isn’t constantly
flooding things when the 25hp pump is turned off. It’s a good thing because there seems to be lots of water there though. Tomorrow they’ll develop it and do the test pumping to make sure it doesn’t draw down other wells in the area. After that is done we submit the results and a pumping permit application to the state to see if we can turn it on and use it. Be sort of ****** if they said no but they do not give an answer until it’s drilled and the test pumping is done. So. We’ll be $40k into it and maybe can’t even use it but you gotta hope for the best !
@Firstram, across the US we're pulling water out of the ground faster than it's being replaced. It's hitting farmers harder but it's also affecting municipal and private wells. Drilling 170 feet to get water is expensive but it's a bargain compared to a 1,700 foot deep well. Some of the water coming out of the ground today seeped into the aquifers 10,000 years ago. I don't know if you can access the article from the NYT but here's one quote:That's absolutely ridiculous, what a bureaucratic overreach!!!
"The change is already happening in parts of Kansas, where 2.6 million acres of land no longer have enough groundwater to support large-scale agriculture. The western part of the state has seen some of the worst declines yet in groundwater levels. Corn yields have plummeted to levels last seen in the 1960s, erasing decades of gains."
Five Takeaways From Our Investigation Into America’s Groundwater Crisis (Published 2023)
Aquifers are shrinking nationwide, threatening supplies of drinking water and America’s status as a food superpower. Climate change is amplifying the problem.www.nytimes.com
I understand and can relate to all of this.@Firstram, across the US we're pulling water out of the ground faster than it's being replaced. It's hitting farmers harder but it's also affecting municipal and private wells. Drilling 170 feet to get water is expensive but it's a bargain compared to a 1,700 foot deep well. Some of the water coming out of the ground today seeped into the aquifers 10,000 years ago. I don't know if you can access the article from the NYT but here's one quote:
The need to verify what happens when we pull a bunch of water out of the ground is a good thing but is risky as we don’t know if we’ll get a pumping permit. That being said, we pumped at 450gpm for 24hrs and everything was well within where it needed to be during pumping and the recharge after we stopped was amazing. The water level dropped down 97’ from the surface and was back to 10’ 2.5hrs after we stopped pumping which the well guys said is unheard of.I understand and can relate to all of this.
My comment about overreach is the need to fully develop a well before the .gov might give you permission to use it!
Yes. Two. One larger that’ll do 40ish acres and a smaller one that’ll do 25ish acres.Center pivot?
Martin
Are you not using the integrated StarFire?Planted something more serious than sweet corn today!
Martin
Ooooo implement guidance!! Fancy but nice in the hills.I fill it, I don't run it. That being said, we use auto steer, and there is a globe on the planter. Is that what you are asking?
Martin
No, its not what I'm asking. That tractor has two receivers on it. The SF6000u snapped into the bracket, and what I suspect is a SF6000i (or possibly 7000i) under the yellow cap on the right side of the roof.I fill it, I don't run it. That being said, we use auto steer, and there is a globe on the planter. Is that what you are asking?
Martin
No, that isn't an issue.Ooooo implement guidance!! Fancy but nice in the hills.
@XJSuperman does the 7000/7500 not play well with implement guidance if they have a 6000 on the planter ?
I’d like to paint the cab some sort of other color, stick a 10-so in it and add a wet kit of sorts yet but yeah, so far I am really glad I went this route vs a 1-ton pickup. It’s a blast to drive and very capable !! An N14 Cummins would be fun in there !!You've been able to successfully achieve the vision you had when you bought Walter. It's taken a heck of a lot of work to get to this point, but it seems like it's been worth it. I really like the JD compact hydraulic power pack riding piggy back!
Just another way I’m justifying having it around to the MrsThat’s a pricy “wet kit”!
Martin
The 2nd one is Dads lol. I went shopping for a 455 from the 90’s and one thing lead to another and I bought the 2038r. I told Pops and he said “If my damn kid can have something nice like that so can I!” LolYou know having 2 of those 2038's really is a bit overkill, after all you can only run one at a time. You should just drop that second one off here, I'll give it a good home.
I never thought you'd have enough payback for irrigation where you are. Always figured that was more of a western/Southern plains thing.
The planter is separate, and yes I assumed you were running ATIG from what I see.
Why are you using the SF6000u on the tractor when it comes with integrated starfire already on it? You don't have an RTK radio on the 6000U, so the correction signals would be the same or close. I'm genuinely curious why a customer isn't using the built-in one that was paid for up front.
It’s all good, jumble away !!
No autopath on the 6000i maybe ?Well I'm still lost, but that helps a little. If I read that right, he still has 3 activated starfires total, two of em movable. He can certainly plant with the integrated on the tractor, and leave the extra on the sidedresser. But I must be missing something in the equation he sees. Carry on.
JB, what is happening up there? Did MN get the rain and storms that NE and IA did?
Just to clarify, AutoPath needs SF3 or greater, and the integrated receivers will do everything the universals do, its really the same guts kinda, just in the roof.It’s all good, jumble away !!
Yup. Almost 2” so far and it’s still raining.
The 7630 has a 4640 that we use for guidance with everything we can and will be used for section control on the sprayer. The 9420 has a brown box used for tillage. It sure is nice not to have to worry as much about overlap !!I'm surprised to see the irrigation up there as well, but can see it's benefit in the dry years.
We planted beans last week (northeast Iowa) and hope to plant corn this week. Autosteer is a new addition for us this year. This way I can plant almost as straight as my Dad.
How soon will you start planting? Aside from the tiling, are you using any GPS tech?
That is our thought as well. Similar to tile. It's not "needed" all year long but sure is nice in some years or certain times of the year.Irrigation is like buying insurance.
I don’t understand why anyone who could have it, would not have it. It’s much better to have and not use, than to not have, and be in need.
Martin
When I said no Autopath on the 6000i it wasn't referring to not able to do it as much as they don't have it unlocked. The traveling receiver has the unlock and since it can travel they move it around to save some $$$. The gold flake in the paint causes some of us farmers to do silly things sometimesJust to clarify, AutoPath needs SF3 or greater, and the integrated receivers will do everything the universals do, its really the same guts kinda, just in the roof.
Its exciting to see "work" being used and the different ways it all comes together for customers/users. Sometimes you see something that makes no sense, sometimes you learn something, sometimes we all learn something.
I think we just calculated that we got over 2" here as well. Its gonna be a muddy week.
Activations and licenses like that follow the display, not the receiver.When I said no Autopath on the 6000i it wasn't referring to not able to do it as much as they don't have it unlocked. The traveling receiver has the unlock and since it can travel they move it around to save some $$$. The gold flake in the paint causes some of us farmers to do silly things sometimes![]()
You better head over there with a new hybrid 8rx410 and all electric planter and let them demo it. Seems the only logical solution !!
That thumb looks sweet! Now I'm telling myself that I don't need one lol.
You know if you really want to make firewood handling slick, I think you need to get a mini ex. There's some guys on you tube with a slick setup, use the bucket with a thumb to hold them while you cut them, and then put a wood splitter on the end of the mini and split all the big rounds without ever touching them.
