Catfishdan
Central coast, California
Yeah, it looks like the same box as mine. As far as the BAC, there was a generic toolbox for sale up in Seattle recently with the same BAC stenciled on the outside and the ad said it was an old Boeing box. So, I don't know, but I wouldn't be surprised that Boeing ordered them en mass, and that is why there is no label inside. Just a guess though.
That’s certainly the best explanation yet. Thank you sir.
Provincial
Near Salem, OR
This 3/8” drive socket arrived today from an eBay seller. The set screw is a bit of a mystery.
I believe that is a socket for aviation spark plugs. The set screw could have been to hold a protective insert to keep from damaging the threads on the upper end of the spark plug for the radio shielding harness connection.
I'm going to have to jury-rig the rest (knob, spring, screwdriver) of this valve adjuster, hang it somewhere like a novelty item, or possibly make a bottle opener out of it. Flea market find this morning. Scoured the box for the actual pieces. No dice. And slim to nil chance I will ever find them.
I’m making a little progress in my attempt to put together a 4700R set. I found some 235 ignition pliers and sanded and started on the wrinkle finish repaint. It will be interesting to see what happens when I apply the green top coat over the black wrinkle.
r_olson_06
SD
I would repurpose it for sure.
Looking good.
Looking for a Round Beam Plomb 1068 Double Box End Wrench
JoCoSawdust
Eastern NC
I'm looking forward to seeing how that turns out Don. I've contemplated that technique a time or two but haven't pulled the trigger on it yet.
I’m a little worried about the final result but my insurance policy is that VHT offers the wrinkle in red so if necessary I can get the box back to it’s original color.
r_olson_06
SD
2 more. Really excited for this U series tappet wrench as it my first U series and to get the 17/32 size was even better. Also picked up this Plomb woody for .99 plus shipping.IMG_20200925_211157362.jpgIMG_20200924_192728685.jpeg
Should be fine don, just sand the krinkle off of the hinges before final coat.
Wow those are scarce roy. 17/32 is close to 13mm.
Here is an odd one. 1/4" drive 4749 ratchet marked Owatonna tool co. h-63.
r_olson_06
SD
Thanks,
I have one of those OTC made by Protos but not in 1/4". That is a rare one.
Leviton
Oregon
Found these at a thrift store this week. The extension says “A. PLOMB”. The speeder just says “PLOMB” (with an “O”).
Do you think the extension is a tool modified by the owner, or “factory’ built?
A. EXTENSION
The extension is 20.2 inches long and has a 6-point hex opening for a bolt head that is 11/16” across flats (or a very sloppy 5/8”). The cross-bar hole in the other end is 5/8” diameter. The square area behind the socket has sides of 0.57” and 0.55” and the hex cross section behind that has across-flats dimensions of 0.535”, 0.520”, 0.525” and 0.535”.
The round-to-hex transition on this tool is fairly crude. Makes me wonder if it was home modified out of an A. Plomb male drive socket?
I’ve read the VanNatta page and various threads here on GJ – what is the latest estimate on when tools might have been marked “A. Plomb”? 1917-1931?
B. SPEEDER
The speeder socket wrench is 18.3 inches long and has a 6-point hex opening that is labeled as 9/16”. The square area behind the socket has sides of 0.53” and 0.51” and the hex cross section behind that has across-flats dimensions of 0.520”, 0.535”, 0.525” and 0.532”.
Alloy Artifacts has a similar speeder wrench, except theirs is marked with the earlier “Plomb Tool mfg. Co.” name and has a slightly different top knob. Theirs was a dual-purpose tool; working as a 9/16” socket AND used to turn 9/16” male-drive sockets. They date theirs to 1924-1927. I’m guessing this one must be circa. 1927-1933?
Both of these tools had the same owner; they both have “C.D.W.” owner’s marks.
r_olson_06
SD
A. EXTENSION
B. SPEEDER
A. EXTENSION
B. SPEEDER
The Plomb one I would guess to be pre 27 as it doesn't have a part number. The later version of this would be S179 or S199 depending in the OAL 17" or 19" respectably.
I am guess the A Plomb to be similar to a fixed head tee wrench that is missing the cross bar. Plomb made these as well under the T part number.
Over all amazing finds!
MR.X
A.Plomb...shop ( home) made or at least repaired. Cool finds and nice pics. What part of Oregon are you in?
The interior came our okay but I think that I will start over on the cover. The wrinkle on the bottom came out best, of course.
Edit. The last picture is the resprayed front base coat.
bmwrd0
Beaver Fever Oregon
Penens!
The 1/4 set came in the mail on Friday and I already had the ratchet, while the 3/8 set is one I picked up a few years ago in an antique mall. Neither box is marked, but it is clear that they are Plomb/Proto empire. I still need some things for the little guys, like a cross bar and some extensions. Somewhere I have a Penens pebble spinner for it, just have to figure out where I tucked it way.
Smokeshow69
Penens!
Nice sets!
I completed the repaint of the Plomb 5295 box. It’s not perfect but the wrinkle finish boxes weren’t perfectly finished from the factory. I did a small S-K box at the same time. Here is the box along with some pictures of Plomb boxes with original wrinkle finishes.
Smokeshow69
That looks really good! I have been experimenting with the wrinkle finish on my tool tote restoration and that paint isn’t easy to get right. Here is the underside of the socket tray that I painted before I will weld it back in! I have found it goes on best with light coats
r_olson_06
SD
Looks great! Very impressive result.
r_olson_06
SD
After sulking in the crushing defeat on a period correct MSY (stud extractor) for my 9/16" Y series tool board I ended up scoring a decent runner up another hog jaw. These seem really hard to find. Also scored a 5208 12pt with a pair of WF swivels on the cheap. Hopefully this turns my luck around.IMG_20200930_194621380.jpgIMG_20200930_194628057.jpeg
Sorry you missed the stud puller. Those wrenches look great! Don't see too many of those.
Smokeshow69
Update on progress on my tool tote...
I straightened out the sides and bottom as best as I could. The sides had multiple creases and most of the spot welds connecting the sides to the end sheet metal were broken over the years. In my opinion this tote was under built for the capacity of weight it could potentially hold. The sheet metal is 18 gauge so not super thick. The corners are maybe 1/4 of an inch wide and all the spot welds are stacked in a line. Not in a zig zag pattern which would have made it stronger.
To straighten the sides I had to cut a piece of wood the exact width to put on the in tote and then use clamps to tighten down on the creases and then follow up with hammer and dolly work. I tried to weld this with my spot welder but I couldn’t get the tongs in the correct angle to make good welds so I fabbed up 16 gauge 90 degree corner reinforcements. This is not original but I am going to use this and I made them to not be super obvious.
Smokeshow69
I dressed the welds in the original corners and then burned in the new corners with my spot welder and my wire feed
After I finished the welds I coated them with a thin coat of filler. I love the smell of that stuff [emoji23]
I currently have the interior in self etching primer and am currently filling the last few holes I had to drill in the side when I removed the socket tray
Smokeshow69
Interior in primer
I have fixed about 85% of the damage but I can’t fix everything. There were some prior vintage brazing repairs to the handle that I can’t remove without creating more damage to the sides where it connects. The repairs are a part of its story so I am ok with leaving them
. I am going to paint it and then do some light aging to it . Lugz has a fantastic thread about doing this to boxes. Here is the bottom of the socket tray with 3 light coats of wrinkle paint.
damon18
Memphis, TN
What job is this Plomb Scraper designed for?
I only know it's a scraper from eBay, so even that coule be wrong. Searched and didn't find one here on GJ so what's it?
Sent from my SM-G973U using Tapatalk
I believe that scraper is for combustion chambers... the piston ring scraper is odd shaped and has a special protrusion for the ring indentation itself
Smokeshow has it right. The carbon scraper is for piston tops and combustion chambers. In the early days of internal combustion with poor oil and ineffective piston rings, removal of carbon build up was a regular maintenance procedure requiring removal of the cylinder head(s). They were included in upper echelon military toolsets from 1938 to 1942.
-Don669FB133-6A6C-4F7D-A9F7-0135FF5C9084.jpeg33FCB8FE-618C-401C-B636-ACEF13CDD32E.jpg730FDE8A-BF60-4BAC-A0DE-7508DDCE907E.jpegA62A9016-4D44-4C1A-99A4-AC440805BFD8.jpegB192DECA-B8CB-47CE-AD28-5950F33E5A9F.jpeg131770C4-1BC4-4116-AED2-EFD22685A659.jpeg81B7BAE0-EA0A-4E20-8418-DE6422C86E44.jpeg
I doubled my Paschall hammer collection with the addition of this 5oz ball pein hammer head. I see another rehandle in the near future.
Maybe not. I did receive this variety of Plomb tools from eBay today. The 3/8” drive ratchet is from 1941, the 1-1/16 deep spark plug socket is from 1936, the other tools are just marked Made in USA.
-Don93AEC5F0-FA39-477D-BAA6-DA6B1886A63D.jpg8850494D-8763-437A-9248-C65292DBB0FE.jpg049C7CEE-1116-4B31-AC1B-0D3442B84A9F.jpg2C433372-1215-4387-BB0F-FA37263BDDF0.jpg
