Smokeshow69
Yes that is up there
Agreed. I am out at that price
Yeah, it looks like the same box as mine. As far as the BAC, there was a generic toolbox for sale up in Seattle recently with the same BAC stenciled on the outside and the ad said it was an old Boeing box. So, I don't know, but I wouldn't be surprised that Boeing ordered them en mass, and that is why there is no label inside. Just a guess though.
This 3/8” drive socket arrived today from an eBay seller. The set screw is a bit of a mystery.
I would repurpose it for sure.I'm going to have to jury-rig the rest (knob, spring, screwdriver) of this valve adjuster, hang it somewhere like a novelty item, or possibly make a bottle opener out of it. Flea market find this morning. Scoured the box for the actual pieces. No dice. And slim to nil chance I will ever find them.
Looking good.I’m making a little progress in my attempt to put together a 4700R set. I found some 235 ignition pliers and sanded and started on the wrinkle finish repaint. It will be interesting to see what happens when I apply the green top coat over the black wrinkle.
Thanks,Should be fine don, just sand the krinkle off of the hinges before final coat.
Wow those are scarce roy. 17/32 is close to 13mm.
Here is an odd one. 1/4" drive 4749 ratchet marked Owatonna tool co. h-63.
Found these at a thrift store this week. The extension says “A. PLOMB”. The speeder just says “PLOMB” (with an “O”).
Do you think the extension is a tool modified by the owner, or “factory’ built?
A. EXTENSION
The extension is 20.2 inches long and has a 6-point hex opening for a bolt head that is 11/16” across flats (or a very sloppy 5/8”). The cross-bar hole in the other end is 5/8” diameter. The square area behind the socket has sides of 0.57” and 0.55” and the hex cross section behind that has across-flats dimensions of 0.535”, 0.520”, 0.525” and 0.535”.
The round-to-hex transition on this tool is fairly crude. Makes me wonder if it was home modified out of an A. Plomb male drive socket?
I’ve read the VanNatta page and various threads here on GJ – what is the latest estimate on when tools might have been marked “A. Plomb”? 1917-1931?
B. SPEEDER
The speeder socket wrench is 18.3 inches long and has a 6-point hex opening that is labeled as 9/16”. The square area behind the socket has sides of 0.53” and 0.51” and the hex cross section behind that has across-flats dimensions of 0.520”, 0.535”, 0.525” and 0.532”.
Alloy Artifacts has a similar speeder wrench, except theirs is marked with the earlier “Plomb Tool mfg. Co.” name and has a slightly different top knob. Theirs was a dual-purpose tool; working as a 9/16” socket AND used to turn 9/16” male-drive sockets. They date theirs to 1924-1927. I’m guessing this one must be circa. 1927-1933?
Both of these tools had the same owner; they both have “C.D.W.” owner’s marks.
A. EXTENSION
B. SPEEDER
I'm looking forward to seeing how that turns out Don. I've contemplated that technique a time or two but haven't pulled the trigger on it yet.
The interior came our okay but I think that I will start over on the cover. The wrinkle on the bottom came out best, of course.
Penens!
The 1/4 set came in the mail on Friday and I already had the ratchet, while the 3/8 set is one I picked up a few years ago in an antique mall. Neither box is marked, but it is clear that they are Plomb/Proto empire. I still need some things for the little guys, like a cross bar and some extensions. Somewhere I have a Penens pebble spinner for it, just have to figure out where I tucked it way.
I completed the repaint of the Plomb 5295 box. It’s not perfect but the wrinkle finish boxes weren’t perfectly finished from the factory. I did a small S-K box at the same time. Here is the box along with some pictures of Plomb boxes with original wrinkle finishes.
Looks great! Very impressive result.I completed the repaint of the Plomb 5295 box. It’s not perfect but the wrinkle finish boxes weren’t perfectly finished from the factory. I did a small S-K box at the same time. Here is the box along with some pictures of Plomb boxes with original wrinkle finishes.
No worries I should quit sulking. It wasn't meant to be.Sorry you missed the stud puller. Those wrenches look great! Don't see too many of those.
Mother of all Plomb tool boards, from one of my catalogs.![]()
Primarily for cleaning piston grooves the rings go in, IIRC.
Referred to as a Carbon Scraper.
I believe that scraper is for combustion chambers... the piston ring scraper is odd shaped and has a special protrusion for the ring indentation itself
