what happened to the 13 thenYesterday I finally swapped the water pump on my dodge Durango. Lost my 3/8" 10mm. Looked everywhere. I had mistakenly put it in the spot for my 13mm. I found it when I started putting everything back.
I know more than a few machinists who started up mills or drill presses with the chuck key still in it. They should be orange as well.
After seeing kind of hard to find, I probably shouldn't ask if you have a pictureThe best Iāve ever seen are the little metal clips that hold them stacked, kind of hard to find though.
I assume you do not mean something like this
KTC 6-Wrench Clip
Need to organize your on-board tool kit better? Tired of loosing that 10-12mm end wrench? Want to complete a OEM kit? Grab one of these awesome KTC 6-wrench clips! These are almost identical to the original blue clips found in the early FJ40 kits, but instead of only holding 5 wrenches they hold...cruiser-cult.myshopify.com
I like the size and form factor. I assume that those really do need six wrenches so it would be a problem if I tried to drop in five. And if I had two different sets of 11 I would end up needing 4...Exactly like that. I just ordered one myself, thanks for the link.
Back in the days of yore, damn near every parts store wrench set came with a little clip that held them all together, but these have gone the way of the dodo in favor of giant plastic things. Somewhere around here is a Blackhawk open end set that still have their original clip.
I do have the Tekton double and long flexible wrenchesLooks to me like you could just put in a piece of a stir stick and shim it up to take fewer wrenches.
You could use this as an excuse to buy sets of double open and double boxā¦..6 take the space of 12.
If you're in the market for combination wrenches and want an awesome mobile case for them, the V-series set at Lowes is the answer. They're WAY cheaper right now than they should be. They're essentially Facom/USAG professional wrenches.The final picture is a Craftsman set available at Lowes. This is a sat that stays on my truck. Iāve had a set of these for several years now and after thousands and thousands of miles of rough rural roads Iāve never had a wrench come out of the holder.
Yikes! Thats awful.
While there was dark humor in that shop there was also tool inventory after every job.
