Project `52 DiamondT towrig/RV
kent_323is
South Dakota
Strouty
its just a very simple stinger (i think it is sometimes also called "gin pole" ?!?)
made it for my Pete ...
... but i sold the truck without it so i duplicated the mounts onto the <T> chassis
its basically made of 3 heavy gauge 24' pipes with a 3 ton hoist to change angle and a 1 ton chain fall for lifting
works great for moving stuff around the yard :thumbup:
however, a backup camera is on my "to do" list ...
would make the reversing into a spot a lot easier
here is the stinger in action with the <T>
(setting up the solar panels and wind tower at my new place);
the potential legal problems of driving a class 8 without a CDL was one of the reasons why i sold the Pete.
i got tired of the whole "commercial or not" mess.
in theory it is completely legal, but not all the LEO`s know the exact rules and definition for RV
(or can identify the rig as private when you fly by the scales)
nobody will ever confuse the <T> for a commercial rig ;)
it is clear at first glance that it is a private and/or vintage rig
on top of that i`m under 26k lbs GCVW what does not require a CDL to start with.
I like the jin pole crane setup. How much does it weigh?
Have you done much testing to see the max weight capacity at the various angles?
Ive enjoyed seeing the progress on your build, thanks for taking the time to take pics and post.
Keep up the good work!
madoc1
spicewood, tx
gin poles used to be common here in texas. have not seen many lately tho. used usually to pull well pipe and pumps on water wells.
jim
Strouty
Southern Maine
I would call that a jib, I use gin poles when building towers. Either way, it is a great setup and looks like it works well for you.
As for DOT rules, they are so tricky, but as a personal use or RV you should be exempt regardless of the GVW of the truck. Just so you know you can have an under 26k truck and still need CDL A, it all depends on the trailer rating. It gets confusing, as you know even law enforcement officers get confused. I know the rules that apply to me and I keep a FMCSA handbook in the truck with bookmarks so I can reference it if there is an issue.
Can you register it as a motor home? That should take most of the DOT issues out of the equation. In Maine, it is very cheap to register a motor home.
Keep up the posts, it looks great.
PanelDeland
I would worry about the legals also. Not because you're doing anything wrong but because gen X is starting to choose careers and LEO sounds easy to them. I say that because my buddy got stopped in his bagged phantom dually and was ticketed for no CDL with air brakes. The LEO a very young county mounty would not believe that the compressors and tank were just for the suspension air bags. I guess a 70's truck with airbagged suspension and a trailer with another classic caused some confusion.
y'sguy
Tulsa, Oklahoma
great to see this project. I grew up in Tulsa, OK and so I remember the Spartan factory and my Dad had friends that worked there. We used to drive by it all the time on his way to work at the airport. I have seen many of those trailers from the old days, but recently as of a couple of years ago a guy nearby my neighborhood had about 4 of them parked by the side of his shop. I did a painting of I'll see if I can locate a pic of it.
Fyrme
Green country, Oklahoma
Believe it or not, there are several old Spartans still lingering around the Tulsa area. Just off the top of my head I could drive you to at least three of them right now. Sadly, they all have seen better days but could still be saved.
Radio Ron w4ron
Radio Heaven (near Charlotte NC)
That's right, this is a Jib Crane, a Jin Pole is primarily used for putting
up towers. We use them a bunch putting up ham radio towers or taking
down old commercial towers that companies want to get rid of :)
Maybe I say "we used to", don't do any tower work anymore what with
my screwed up back and bad knees :(
I hope everyone is having a great weekend.
Andreb
RoosterBooster is in New Hampshire right now, he's currently building another <T> with/for another PBB member. Lot's of budget involved; many parts from a couple Pete's donors, new custom frame rails, fully reman engine and a huge handmade (by RB) sleeper made from new (and THICK) aluminium.
Here's a link to the thread on PBB: http://www.pirate4x4.com/forum/tow-rigs-trailers/2096057-diamond-jim-diamond-t-923b.html
BTW, while in NH, Rooster's <T> is getting a new engine and some other goodies:
http://www.pirate4x4.com/forum/tow-rigs-trailers/1048598-fawk-i-think-i-m-building-vintage-truck.html
bullnerd
Jersey
Thanks for the tip Andreb.
I wish was working on the car he started here, but hes probably making good cash so good for him.
macgyver37
Pittsburg, Kansas
He mentioned that he will get back on the chevy pickup when he leaves NH for warmer weather. I think that they are going to get it dried in and of course they have to put his truck back together before he can leave.
