this project has been on hold for quite sometime. For some reason the local weld shops have not wanted to tackle the sleeper job I had. SO, I just got the call finally today that the sleeper has been repaired and that some changes to the front have been started. We will finish the front once the cab opening is changed and we know all the proper measurements for the sleeper opening.
Some of the last things done were to the front end. We needed to drop the front to match the rear which was only about 1.5-1.75 inches to level the truck. Well, we went a little further, we ended up starting like this...
I removed the front springs, had them dearched, 1.75 inches of arch taken out of each leaf then reinstalled. Since dearching is not an exact science we had to put 1 1/2" spacer back under the drivers side spring. I did some heavy research and with the help of a great spring shop in Pennsylvania I was able to work with the owner and locate a shorter rear spring hanger. For those that may not know, whatever the difference between the old and new spring hangers you will gain or loose roughly half that in a wheel well. Or new hanger was 3" shorter and we picked up roughly 1.5 in the wheel well plus about 2 in the springs and another 1" in the spacers under the springs.
This was before the dearch, these are low mileage springs made by Triangle!! top quality springs and we went ahead and altered them
The current wheel well!!
This is after all the parts changed and springs reinstalled, this does not leave much room for bounce on the highway....We got that covered, the owner is sending me an air ride kit for the front end, should add a few inches of lift and get it up to a safe ride height without hurting anything.
hopefully we will be pushing forward on the sleeper very soon, its been at the weld shop for a few months for only a few hours worth of work. unfortunately I cannot weld aluminum yet, but its something I'm looking to get into very soon. I hate being dependant on other people and shops.
